LED Reversing lights... - Mercedes Benz SLK Forum
 7Likes
  • 1 Post By savcom
  • 2 Post By savcom
  • 2 Post By savcom
  • 1 Post By Pictor
  • 1 Post By KoltSupa
#1 Old 04-09-2017
savcom's Avatar
Quoted: 604 Post(s)
Patiently waiting for darkness to see how effective the new LED Reversing lights are on Silkie....
Truely a two minute job to change the lamps over - but no way of knowing how effective the lamps are in the bright sunshine....
Sent from my Xperia while my back was turned
RLander likes this.
Also
Previous :
savcom is offline
#2 Old 04-09-2017
Vehicle: 2018 SLC 43
Other Toys: 2013 Lincoln MKT
Quoted: 134 Post(s)
Wonder'f that would help a 2102 SLK 350. Mine are so dim you have to hold a candle up to them to see'f they're on. I use the brake lights and rear fog light to see where I'm going. Guess they're for signaling and not illumination.
SLKomatic is offline
#3 Old 04-10-2017
devilman9050's Avatar
Vehicle: 2003 SLK230
Other Toys: ML280, CBR600
Quoted: 137 Post(s)
Hi, was it just a straightforward bulb replacement Savcom? What did you replace them with?
Thanks,
Dez
devilman9050 is offline
#4 Old 04-12-2017
savcom's Avatar
Quoted: 604 Post(s)
Initially it was, but I have the bulb warning light lit so I need to work out what resistors to put in place.
My goodness they're bright!
Also
Previous :
savcom is offline
#5 Old 05-08-2017
savcom's Avatar
Quoted: 604 Post(s)
I have been remiss. I've not updated this since completing the work.
I ordered these LEDs from eBay - apparently "2x Bulbs Reverse 15Smd LED P21W BA15S Bright White 750Lumen Canbus Mercedes"
The price has gone up since I bought them though....
That said, I've a few thoughts I'd like to share about them.
Firstly I looked long and hard and tried to pick a lamp that would put the most light out in the direction I wanted - i.e. straight back - owing to how the old lamp sat in the holder. These definitely throw the light where you want it!!
Secondly, having seen the bulb fail lamp light up I measured the power consumed by each lamp - this was a shade under 7W per lamp (the lamps drew 0.483A at 13.8V). That's not nearly enough to fool CANBUS logic - hence the bulb failure warning. However, the light produced is a marked improvement on the old incandescent versions and worth the upgrade despite the extra hassle of adding resistors. I added 2x 12R 25W resistors across the brown and grey/yellow cables in the rear lamp harness (see diagram below).
Finally, I suspect it would have been a bit cheaper buying non-CANBUS lamps and adding the resistors myself.
I've more photos of the resistor fitting so I'll pop those in a new post on this thread.
curro101 and Pictor like this.
Also
Previous :
savcom is offline
#6 Old 05-09-2017
savcom's Avatar
Quoted: 604 Post(s)
To finish this thread, I had to fit resistors to fool the car that the lamps had not failed. This took me 30mins - including photographs!
First the problem:
Next the kit (I made these - but you can get ready-made kits for a few pounds/dollars from most motor factors or Amazon)
I took out the nearside loom to do the install:
The wires you need are the Brown and the Grey/Yellow (see wiring diagram above - but don't forget my car is a facelift so check the colour codes for your car before crimping!)
Here is the resistor attached to the nearside loom:
I repeated this process with the offside loom (there is an extra cable on this loom for the rear fog lamp - but you will still need to put the other resistor on the Brown and Grey/Yellow cables) and tested the car again. That's better!
Note the before and after times on the clocks!
Also
Previous :
savcom is offline
#7 Old 05-09-2017
Pictor's Avatar
Quoted: 217 Post(s)
All mod posts should have before and after clock photos !
A nice touch.
savcom likes this.
Pictor is offline
#8 Old 06-18-2017
KoltSupa's Avatar
Vehicle: 2002 Mercedes Benz SLK 320
Other Toys: 2005 BMW X5 and 1979 Chevrolet Monte Carlo (Base)
Quoted: 8 Post(s)
I am on the same boat as you...thinking we need to get those None-CANBUS Error free LED bulbs everyone keeps talking about for our cars.
savcom likes this.
KoltSupa is offline
What are error free led bulbs and why are they needed? jbanks15 General Discussion 14 11-21-2018 12:44 PM
DIY : R171 Replacement of the original bulbs with LED pack michjul SLK R171 Class DIY 62 10-02-2018 07:35 AM
New Smoked LED Tail Lights Installed! Bassman62 General Modifications R170 4 08-22-2013 05:23 AM
How to have the main lights + the LED lights on at the same time? addictive SLK R172 General Discussion 7 08-09-2012 05:29 AM
