New Projector Headlights - Turn signals stuck on when headlights turned on - Used existing socket to fit - Mercedes Benz SLK Forum
#1 Old 02-05-2017
Vehicle: 1999 SLK230, Recently acquired at 49k miles. Great condition, but still 17 years old.
Other Toys: A motorcycle and hopefully soon a small 4x4 truck for utility purposes.
I recently got around to installing a set of projector headlights on my 1999 R170 that I obtained from ebay. They didn't have a brand listed. The installation went smooth up until it came time to install the turn signal connector. The plug on the projectors didn't fit the wiring harness of my car. There are 3 electrical pins on the stock connector and harness and only 2 electrical pins with the projector connector. There is a split on the bulb side of the connector as well. I reused the stock yellow connector with the projectors and everything seemed to work at first. That is to say my turn signals work fine until I turn on my headlights. When my headlights are on my turn signals are stuck on and won't blink and the hazard light on my my dash stays lit solid. Based on the stock connector it looks like I am shorting my hazards to my low beams or something similar.
Has anyone encountered this before? Is there an easy solution? Right now my priority is getting my turn signals to work at night as this car is my daily driver. My guess is cutting one of the wires leading to the harness might offer a temporary fix, but what one? If this is correct how about a permanent fix?
Thanks!
tubeamps is offline
#2 Old 02-05-2017
After a bit of digging I think I found the answer. I used the bulbs from the projectors in the stock sockets. The original bulbs and the bulbs that I need are dual filament 2357a bulbs. I have no idea how old the bulbs in the stock headlights are, so I'll pick up some new 2357a's tomorrow.
Someone please correct me if I'm incorrect.
Thanks!
tubeamps is offline
#3 Old 02-18-2018
Vehicle: 2003 SLK 230
Other Toys: HD Sportster 883 Custom
Did the bulb replacement resolve your issue? Im having the same issue.
Chewy44 is offline
#4 Old 02-18-2018
Vehicle: 2005 SLK 55 AMG Silver
Other Toys: 07FLHX, 10Harley Edition F150, 10Lincoln MKS AWD Eboost, 08Edge SE AWD, 08Ridgeline XL 4x4
Quoted: 103 Post(s)
You're on it, the original dual filament bulb is markers and turn signals apparently the "plug and play" model gave you only turn signals that were somehow wired to both marker lights and turn signals so when you had your lights off turn signals would work but when you turned your lights on you had constant power to the single filament. What you need to do is sort out which wire is which and go back to the dual filament setup, it sounds like you have both leads there so that won't be an issue.
A single filament bulb will have once contact point in the center and the bayonet connector has equal side pins because orientation doesn't matter, the dual filament will have offset pins on the side to align two contact points properly in the socket, your bulb is currently making contact with both points in the socket so powered by both turn signal and marker lamp power.
Eeyorewolf is offline
#5 Old 02-20-2018
Vehicle: 2003 SLK 320 and 2012 SLK 350
Had the same problem when i installed the spyder halo lights on my r170. Use the stock yellow plugs in the new headlight housing and use the stock bulbs. The color on the bulbs was coming off the original bulbs for my headlights so i just picked up some replacements from the auto parts store for ~$5.
R170Driver is offline
#6 Old 02-20-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Yes, had to do the same thing with mine.
Padgett is offline
Selling my 1998 slk230 OEM headlights / OEM bumper park light / OEM side marker light (turn signals) afr00t SLK Parts For Sale 1 04-17-2012 03:23 PM
