NGK Laser Platinums on my 98 SLK - Mercedes Benz SLK Forum
  • 1 Post By overdraft
#1 Old 08-06-2015
Vehicle: 1998 SLK230 Black Opal Pearl
Dropped in a new set of Laser Platinum plugs in my 98 SLK230...
I love the quicker response now with these compared to the Bosch F7KTCR ones I pulled out... only 28k on the car, but I wanted to try this.
Must say it is feeling a lot quicker off the line than it was before!
I'll be running through a tank of gas or two this weekend to see if the gas mileage improves and if the pep is still there
NGK PFR5A-11 (Laser platinum) - 4588
Cost - $12.50 each or $56 CDN taxes in for all four...from an auto store in town.
I thought I had a problem with my plugs anyway as the insulator shell was turning yellow at the base of all the plugs, but turns out is normal for these engines...it's called corono stain
Strange as my C230 had only two plugs like that and not all four...
PLUG STUDIO / NGK
Corona stain | NGK Spark Plugs UK
thorn is offline
The Following User Says Thank You to thorn For This Useful Post:
#2 Old 08-07-2015
Vehicle: 1999 230SLK - Manual
Other Toys: Honda's: 08 CBR1000rr, 05 CBR600rr, 1970 CB350 Boats: Fareast 23R, Laser Truck: 08 Chevy Colorado
Quoted: 19 Post(s)
wow, that's awesome... I've never noticed a performance improvement on a plug change (talking other vehicles though, not an SLK)... thanks for the tip!
overdraft is offline
#3 Old 08-07-2015
Quoted: 6449 Post(s)
Try Techron
https://www.slkworld.com/general-disc...-tier-gas.html
#4 Old 08-07-2015
Quoted: 19 Post(s)
that's interesting too... although I'm pretty puzzled about the gas requirement in the first place... I think I read somewhere compression is 8:1? which certainly doesn't warrant 91 octane in a normal engine build...
#5 Old 08-07-2015
Whatever the owner's manual says for recommended octane is what should be used.
did u get a 1998 owner's manual with your car? manuals older than (earlier) 2000 are hard to find
#6 Old 08-07-2015
Quoted: 19 Post(s)
Ironically I have two manuals (but only one key )! Manual says use 91 octane.
I also have an inquiring mind...
Seems the compression is 8.8:1
here's a typical compression/octane chart so you can see why I'm curious of we're using 91at 8.8:1
I'd love it if someone chimed in and said 'use 91 even though you have 8.8:1 compression because (insert technical reason here)'
#7 Old 08-07-2015
You should use 91 if the manual says so. I have to use 93, I have a V8
#8 Old 08-07-2015
Quoted: 19 Post(s)
pretty sure the manual doesn't say 'install aftermarket Smarttop', but hey, some of us are tinkerers!
#9 Old 08-07-2015
Actually it does say install the SmartTop. Right here is the excerpt
https://www.slkworld.com/general-disc...ing-about.html
#10 Old 08-07-2015
Quoted: 19 Post(s)
oh, you mean THAT manual!
#11 Old 08-09-2015
Quick trip mileage results
When I changed the plugs I also decided to drop in a new set of wires and a new set of coil packs... (when I changed the plugs one of the coil boots would not pull up and I ended up tearing the boot so decided to just put a new set of wires and new coil packs in). They supplied me a set of NGK 54001 wires, but the wires weren't long enough if I used the plastic loom so I just ran the wires right beside the coil pack to the ignition coils. Thicker silicon casing wires so hopefully no problems with running the wires over the coil packs.
Results:
First fill up
375kms
7.985 L/100km
29.46 MPG (US)
35.29 MPG (CDN)
2nd fill up
521kms
7.813 L / 100km
30.10 MPG (US)
36.01 MPG (CDN)
Country driving on windy, twisty and hilly roads... speed limit was 80km/h (50 mph) which means 100 km/h (60 mph) for 75% of the trip until the last stretch of the trip and then 100km/h limit which means 120 km/h (75 mph)
City driving - will report back, but guessing with my heavy foot in town there won't be much of a change.
thorn is offline
#12 Old 08-09-2015
91 and 93 octane
I normally use 91, but dropped in a full tank of 93 tonight after my long distance runs. No reason to do so, but thought to give it a try...
thorn is offline
#13 Old 08-09-2015
Use that techron and be surprised.
SLK 280 VS others HwoALanG Driving Stories 1 03-31-2011 09:25 AM
Image of the SLK 2008 Facelift herve431 SLK R171 General Discussion 116 01-04-2008 04:57 PM
