H&R springs, installed. - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By onixxf
  • 1 Post By Marctoast
  • 1 Post By SirClass
#1 Old 07-18-2015
onixxf's Avatar
Vehicle: 2001 SLK 320
Other Toys: 2005 Toyota X-Runner, 99 Pontiac Trans LS1
Just finished installing a set of H&R springs and things went well for a DIY in the garage. Fronts were pretty straight forward using the Mercedes coil spring tool but had to drop lower control arm for the rear's because the tool simply would not compress enough to get the job done. Finally got all things buttoned up and had a nice test drive. Ride is stiffer for sure! This leads me to this question; with a 1.5 drop, using # 3 pads up front and # 1 pads in the rear, which shock will work best for this set up?
File Type: jpg 11143501_981492211882882_1465835857878756399_n.jpg (55.1 KB, 179 views)
File Type: jpg 11173367_981492151882888_3136206318140820782_n.jpg (37.7 KB, 34 views)
File Type: jpg 1375261_981196325245804_7481852220251292670_n.jpg (23.1 KB, 34 views)
Mancuso likes this.
onixxf is offline
#2 Old 08-08-2015
Vehicle: 2000 SLK 230K
Hey, I've been on my H&R springs for about a year. I also noticed the stiffness of the ride and was thinking about changing my shocks out.
I've heard that Koni Sport shocks are a good shock to go to after lowering on the H&R springs and what i was probably planning to do for my suspension
Marctoast is offline
#3 Old 08-09-2015
onixxf's Avatar
Thanks, what's your ride height like? I sort of had hoped that the car would settle down, "lower" after a while but this is the final look. I added the 18" slk 250 wheels from a 2014 model. I love the wheels but I just wish it was a bit lower. I have to change the # 3 pads up front to # 1 pads but I'll do that when a add new shocks. You got pictures of your car, if you don't mind sharing. Thanks again!
onixxf is offline
#4 Old 08-09-2015
So currently I'm on 18in wheels as well as the H&R springs. I'm on size 1 pads in the front and i believe 2 in the rear (i never changed them out and i believe it comes on size 2).
So here is how my car is sitting now, My wheels have stretched tires though. Either way i'm not rubbing anywhere.
I actually really like the 2014 wheels on the R170, almost ended up doing that actually.
Anyways, here are some pictures.
Bill98 likes this.
#5 Old 08-10-2015
Quoted: 34 Post(s)
needs spacers
SirClass is offline
#6 Old 08-10-2015
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Originally Posted by onixxf View Post
... I added the 18" slk 250 wheels from a 2014 model. ...
The wheels look really good. Were they a straight swap? I thought I remembered that the R172 uses different bolts or whatever? It looks like you were able to fit them just fine.
Durkatlon is online now
#7 Old 08-10-2015
Originally Posted by SirClass View Post
needs spacers
Working on it! need to find the right sized lugbolts and measure it all out
#8 Old 08-13-2015
Quoted: 34 Post(s)
it looks like you would need something small, 5mm or 10mm, from there. you can call ESM.com and they'll be able to help you order the correct length lugs. they even sell spacers too i believe. i've worked with them before for ordering lugs and spacers, they're very knowledgeable and will definitely be able to help
Marctoast likes this.
SirClass is offline
H&R Springs (R171) Swap or Sale in UK MrADeveci SLK Parts For Sale 3 12-28-2014 07:10 AM
R172 H&R Lowering Springs - 2013+ SLK350 / SLK 250 turbox3 SLK Parts For Sale 0 09-27-2014 08:58 PM
R170 H&R Lowering Springs & Bilstein HD Struts SirClass SLK Parts For Sale 2 08-16-2014 10:32 AM
Lowering an SLK55 on H&R springs Boris_Balkan AMGs 15 07-07-2014 11:21 AM
Eibach vs Brabus vs H&R Springs midget fidger Performance MODS for the R171 20 11-06-2011 06:07 PM
