LED Indicator Hyperflash - Mercedes Benz SLK Forum
#1 Old 05-21-2015
Vehicle: 1999 SLK230 R170
I've read a lot of threads about the subject. This post was a good read, but alas, no independent relay to replace for me. I have the good-ole old style indicator relay as part of the CCM/pcb.
Is there a solution that doesn't involve load resistors? My thoughts are probably not. So next question, where do I attach the load resistors? I understand they go across the cables prior to the socket - easy to do on the front, but less so on the rear which is where I need some insight.
All help greatly appreciated.
Max10128 is offline
#2 Old 05-22-2015
Quoted: 20 Post(s)
Did you try replacing the black turn signal relay in the engine fuse box to an led relay? The thread post is in the DIY forum.
Joeb77 is offline
#3 Old 05-22-2015
The turn signal relay mentioned in the linked post, doesn't exist on my motor. The clicking comes from the one of the relays on the CCM module (I've watched the relay click whilst trying to resolve a different issue - which ended up with me replacing the multi-control-stick doobry).
I have a single black relay where the yellow one is and that's it.
Max10128 is offline
#4 Old 05-22-2015
Quoted: 20 Post(s)
ok. I can't help, but hopefully others can. My guess would be to find which wires are for the turn signal from the wire harness plug into the tail light. Once you find the wires you can t-tap into those wires with your resistor wires. 50watt 6 Ohm is very popular these days. I would look for 50watt 8 Ohm (more resistance), I got some from the UK two months ago. Need to mount them on some metal to get rid of the heat they generate.
Joeb77 is offline
#5 Old 05-22-2015
Quoted: 20 Post(s)
usea multimeter to determine which wire is for brake light and turn signal
Joeb77 is offline
#6 Old 05-22-2015
The alternative I've found, albeit a little more expensive are a pair of bulbs which (apparently) don't generate the hyperflash - they're save having to add load resistors which get incredibly hot:
Amber Error Free No Resistor Required 1156 7506 7527 LED Turn Signal Light Bulbs | eBay
It would mean I'd have to return the LED bulbs I've already got - 2 pairs are cheaper than 1 pair on the link...
....or I opt for the chromed non-LED bulbs. Probably the easier and cheapest solution.
Max10128 is offline
#7 Old 05-22-2015
Quoted: 20 Post(s)
Could try to use a canbus led bulb. I was not successful yet. Refer to my post on LED's and wiring my halos. You need enough resistance in the circuit to not hyper blink and get rid of the bulb out indicator light. Isn't the rear signal a JY type bulb (pins are no 180 degrees from each other). The pins should look like 4 or 5 o'clock from the bottom. Will try this weekend to add LED's to the rear signals. I have swapped out my back-up lights with canbus LED's. I get the bulb out signal when I go in reverse.
Joeb77 is offline
#8 Old 05-22-2015
Canbus LED;'s already installed - both front and rear are 1156 (not opposing bulbs). I don't get any warning lights, just hyper-flash.
Max10128 is offline
#9 Old 05-22-2015
Quoted: 20 Post(s)
Load resistors are your hope unless you can wire in some other lighting (LED light bars in front). You just need more resistance to trick the computer to think it is a regular bulb. wire in from the signal plug. It is on the same circuit. You can probably get away with resistors under the hood in front as the signals (rear and front) are on the same cicuit.
Joeb77 is offline
#10 Old 05-22-2015
So your thoughts are load resistors on the front ought to take care of the entire circuit. Not sure adding more light is the way forward, so have purchased a couple of 50W 6 ohm load resistors for a couple of quid delivered. In your money, $3.50.
Max10128 is offline
#11 Old 05-22-2015
55russamg's Avatar
Quoted: 660 Post(s)
Cool Led indicators
Check what I have put into mine.
No errors at all and a regular flash
I don't know how to do a link
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is offline
#12 Old 05-22-2015
55russamg's Avatar
Quoted: 660 Post(s)
Cool link to Cree
https://www.slkworld.com/amgs/232633-...ndicators.html
Cheers Russ
SmartTop
#13 Old 05-22-2015
Do CREE bulbs have greater resistance?
For the short-term, I've put standard chrome bulbs at the front in the halo'd headlights and standard orange jobbies at the rear (seeing as you can't see them, it doesn't make a huge difference).
Max10128 is offline
#14 Old 05-22-2015
Quoted: 20 Post(s)
The resistors in front would put resistance in the circuit. Did you try looking for 8 Ohm?
Joeb77 is offline
#15 Old 05-23-2015
I had already bought 6 ohm resistors before your suggestion - should arrive Thu/Fri next week (due to public holiday Monday). The 8 ohm variant are 5x more expensive.
Max10128 is offline
#16 Old 05-23-2015
55russamg's Avatar
Quoted: 660 Post(s)
Cool
I don't know about any increased resistance, I just put them in and they work a treat. The rears are slightly visable and when parked next to another 55 you can see a slight difference as there is no orange now.
#17 Old 06-29-2015
Quoted: 20 Post(s)
Why is some one that has a 2007 slk55 posting to the r170 forum? Many updates to the newer models do not apply to our older models.
Joeb77 is offline
#18 Old 06-18-2017
KoltSupa's Avatar
Vehicle: 2002 Mercedes Benz SLK 320
Other Toys: 2005 BMW X5 and 1979 Chevrolet Monte Carlo (Base)
Quoted: 8 Post(s)
This LED conversion has taken alot of trial and error from me until I discovered this forum! Error free led bulbs it is.
KoltSupa is offline
DIY : R171 Replacement of the original bulbs with LED pack michjul SLK R171 Class DIY 62 10-02-2018 07:35 AM
John's 3rd Brake Light Adapter UK-C200 General Modifications R171 551 04-25-2018 10:30 AM
DIY - Under Hood LED Lighting PapCan514 SLK R171 Class DIY 1 04-10-2014 07:52 PM
