Loose part I found floating. around in trunk - Mercedes Benz SLK Forum
#1 Old 03-15-2009
Vehicle: SLK280
I found a piece of black plastic just floating around the trunk, with the part code on it marked A171 684 0618. Its just a flat rectangular piece of plastic about 4 cms x 3 cms, and with two prongs sticking out of it.
anyone have the necessary tools to look up this part number and figure out what its for?
ghostdunks is offline
#2 Old 03-15-2009
Other Toys: Jaguar XKR, Omega Elite 3.2L
If it's the loose part that I also found floating around when I bought my SLK350 it's to remove the aerial, I think. I won't tell you how long it took me to figure it out!
bjohnson is offline
#3 Old 03-15-2009
Over 100,000 miles!!!
SLKman's Avatar
Other Toys: Just my SLK
Chats: 59
Post a picture if you can.
That would be a good thread... "Guess what this part is and where it goes."
SLKman
SLKman is offline
#4 Old 03-15-2009
aka John
Chats: 1143
Quoted: 30 Post(s)
A1716840618 is listed as "Cover : Hand Brake Lever". See attached, gotta admit I can't visualize where this part actually goes....
UK-C200 is offline
#5 Old 03-15-2009
DansSlk
Guest
Posts: n/a
Chats:
Quoted: Post(s)
It goes in front of the handbrake mate
#6 Old 03-15-2009
Based on UK-C200 and DansSLK's response, my guess is it's the part as indicated by the yellow arrow.
#7 Old 03-15-2009
DansSlk
Guest
Posts: n/a
Chats:
Quoted: Post(s)
Yes sir, it is.
The Following User Says Thank You to For This Useful Post:
#8 Old 03-15-2009
Vehicle: SLK280
Aha, thank you very much, kind sirs! no wonder that part looked familiar, I remember seeing it when I was taking the car apart while installing a new headunit. How it got around to floating around in the back of the trunk is another question altogether...
#9 Old 09-04-2013
Vehicle: 08 SLK 350
Other Toys: MB
Chats: 6
Sadly I found mine floating around under the passenger seat today. I'll post some pictures.
Anyway , should I worry in any way or should check for a replacement ?
bogdanmb is offline
#10 Old 09-04-2013
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
It appears to be intact (are either of the ears/prongs broken?) so just reinstall.
FUN 4 2
Der Flieger is offline
#11 Old 10-03-2013
Vehicle: 08 SLK 350
Other Toys: MB
Chats: 6
One "ear" looks broken , maybe that's why it went loose . I hardly know why since almost never use the handbrake since I always put my car in Park mode. Anyway is there a guide to reinstall it back ?
bogdanmb is offline
#12 Old 10-03-2013
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
Evening
It can be replaced when the gear lever surround has been removed .. (it just clicks 'home')
The lower cubby needs to come out first (I think - it's been a month or two since I took mine out) - lift off the gear lever gaiter, lift up the silver gear surround (you can then disconnect the wiring under the gear display) and then prise up the whole gear surround assembly (I usually lift if using the newly created 'hole' where the gear lever gaiter was)
You'll be able to refit the plastic piece - it goes backwards and up till it clicks into place around the base of the handbrake...(You may need another pair of ahnds to hold the bit it clicks into to stop it moving around)
There was another thread on here a while back about this..
Sean
Mods so far...
Airscarf Retro-fit https://www.slkworld.com/general-modifications-r171/27470-project-airscarf-starts-here.html
Parktronic retrofit – using all factory parts
https://www.slkworld.com/general-modifications-r171/33412-parktronic-retrofit-not-2-minute-mod.html
Alpine double-din touchscreen head unit with Bluetooth, Nav, DVD, reverse camera and iPod with a ‘Small’ sub in the boot
https://www.slkworld.com/slk-r171-general-discussion/26915-amplifier-location.html
Mercedes Genuine rear Windscreen
https://www.slkworld.com/general-modifications-r171/32951-new-windscreen-one-back.html
Display& steering wheel integration for the head unit.
Digital Climate control panel, Sun sensor and Pollution sensor fully working
https://www.slkworld.com/general-modifications-r171/30240-climatronic-retrofit-digital-climate-control.html
Hat-shelf mounted solar charging panel
Rain Sensor for Auto-wipe retrofit
Various coding changes to the Instrument cluster – see below
AMG Aluminium gear change paddles instead of the buttons
https://www.slkworld.com/general-modifications-r171/31587-amg-aluminuum-gear-change-paddle-retrofit.html
Facelift SLK Antenna https://www.slkworld.com/general-modifications-r171/32272-facelift-antenna-tick-otherwise-known-two-minute-mod.html
Harman Kardon speaker upgrade – All 11 !!
https://www.slkworld.com/general-modifications-r171/31530-hk-speaker-upgrade.html
Custom dimming LED DRL’s https://www.slkworld.com/general-modifications-r171/32992-looking-drls.html
LED’s… in various places…[x] - Map…[x] – Dome…l [x] – Number plate…[x] –Side…[x] – Puddle https://www.slkworld.com/general-modifications-r171/33120-leds-were-all.html
Full blown TPMS…
https://www.slkworld.com/general-modifications-r171/33263-tpms-retrofit-its-started.html
Auto Dimming rearview mirror with integrated GPS Speed Camera detector BEHIND the glass….
https://www.slkworld.com/general-modifications-r171/35096-my-solution-dimming-interior-mirror-look-away-if-you-dont-want-see-things-getting-cut-up.html
Power Folding mirrors… https://www.slkworld.com/general-modifications-r171/33942-folding-mirrors-making-start.html
Designo style Alcantara head lining and various other bits, plus s smattering of Carbon fibre in there too
Johns 3rd brake light gizmo
https://www.slkworld.com/general-modifications-r171/15456-johns-3rd-brake-light-adapter.html
Smarttop – all fitted and working
Illuminated Sills –All done and installed… https://www.slkworld.com/general-modifications-r171/88994-illuminated-sills-scratching-itch.html#post860810
Mods in progress
TPMS - STILL
Mods on the wish list
Magic sky OR a pano roof … this may take some time!!
Coding Mods… https://www.slkworld.com/slk-r171-general-discussion/31073-my-adventrures-star-diag.html
[x] - Enable those pesky phone buttons on the steering wheel - FINALLY DONE - WOOHOO
[x] - Enable Auto-wipe – done
[x] - Add temperature display to the lower MFD - done
[x] - Enable tyre pressure Loss Warning - done
[x] - Enabled Folding mirrors – done
[x] - Enable Gallons Remaining in the MFD – done
[x] - Enable Cornering Fogs - done
[x] - Enable both rear fogs - done
[x] - Enable Alarm 'chirping' – done
[x] - Enable TPMS display in the upper MFD – done
[x] - Enable Parktronic - done
[ ] - Enable Highline TPMS – proving tricky!!, but we have some great brains on the case….
Seanhump is online now
I found a car.... Adamantium General Discussion 22 03-11-2009 10:59 AM
loose exterior antenna R170 leeco SLK R170 General Discussion 0 03-21-2008 12:04 AM
loose boot latch BAZ SLK R170 General Discussion 0 09-28-2007 11:40 AM
R170 Vs a Truck guess who loose... benz General Discussion 17 05-25-2007 01:28 AM
from where can i found it ? no-way General Modifications R171 3 11-23-2006 02:07 PM
