battery - Mercedes Benz SLK Forum
#1 Old 01-08-2009
battery
Hi everyone !
Replacing the baterry on the SLK R170/2002 with one of higher than original
Amp/hour rating can put the car electrics/electronics in danger someway?
Thanx in advance for any replies !
CNC44
CNC44 is offline
#2 Old 01-08-2009
DansSlk
Guest
Posts: n/a
Chats:
Quoted: Post(s)
It can put additional stress on the charging system but in general no, so long as the voltage is correct and you don't go overboard with the battery you should not have a problem
#3 Old 01-09-2009
Thank you DansSlk!
Although my english is not good enough to understand what you mean by...go overboard with the battery...could you explain this to me please?
regards !
CNC44 is offline
#4 Old 10-01-2009
dee101's Avatar
Vehicle: 2004 SLK 350
Chats: 2
Hi Dan
This evening I tried to unlock my Slk R171 350 and nothing happened. Tried the spare key and still nothing. Released the manual key to gain entry into the car and tried to turn my key but the igition would not respond, I mean, the key would not even turn over. Could this be the battery you think?
If so the battery, I was thinking of using my Halfords battery charger on it. Would I need to disconnect the battery links first or can I connect the charger upto the battery with it still hooked up to the car and charge it that way?
Also, would charging the battery ruins any of my audio, sat nav settings?
Thanks in advance.
dee101
dee101 is offline
#5 Old 10-02-2009
DansSlk
Guest
Posts: n/a
Chats:
Quoted: Post(s)
Depends on the charger mate, if its smart enough it wont go overboard on the voltage but to be safe you might want to disconnect it anyways, it wont do anything major to the car you will just need to reset the windows and the clock if you dont have COMAND
#6 Old 10-02-2009
Other Toys: Boats
I think what DansSLK is saying is that some chargers have electronics or other mechanism to detect when the battery is fully charged and stop charging. Many cheaper chargers will continue to try to charge the battery after the battery is fully charged which is not good for the battery.
I would not expect charging the battery to cause a problem with the electronics unless something is seriously wrong with the charger. The battery is charged by the alternator each time you run the car. You may have lost nav and radio settings because the battery voltage dropped before you charged the battery.
Are you sure your battery terminals are clean?
As for higher ratings on the battery, my experience is that you are pretty much limited by the size of the battery to something close to what MB put in the car when it was new. MB puts in a pretty good battery from the factory.
ClemsonB is offline
#7 Old 10-02-2009
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
I have 3 bikes and an SLK in my garage, most of which don't get used through our long winter. Each one is connected to one of THESE. Every time after I take a bike out or drive the SLK, I'll hook it back up. It's max charge rate is only 750mA so if the battery is flat, it would take forever to charge it up, but it keeps a 'fit' battery fully charged, and it can be left connected and switched on indefinitely. It's 'intelligent', so it wont ruin the battery. On the bikes, I use the 'eyelet' cable permanently connected to the battery, and I've placed the socket in a convenient place so I can just connect the charger without having to open/strip down anything, on the SLK, I use the supplied croc clips, and just pop the hood, connect one clip to the 'shock 'turret'' bolt and one to the +ve terminal under the red flap/connector thingy adjacent to it. Never had a starting problem with any of them yet.
Woolly is offline
#8 Old 10-02-2009
Vehicle: 96 SLK 230K
Other Toys: Samurai
Chats: 39
It would not only take forever to charge a flat battery, you would probably damage it........
What are they made of Wooly? Lead or gold ? 7,1 kg!!!!
Gabus is offline
#9 Old 10-03-2009
dee101's Avatar
Chats: 2
Thanks Danslk, I've got a Halfords automatic charger - http://www.halfords.com/webapp/wcs/s...1750&langId=-1 that should switch to maintenance mode once the battery is fully charged.
Would you happen to know how long my battery should normally take to charge?
dee101 is offline
#10 Old 10-03-2009
dee101's Avatar
Chats: 2
Sorry DanSlk, forgot the finish my comment... In some previous posts you've mentioned how to reset the windows which I should be ok with. However I do have command therefore would there be any other settings I'd need to re-establish?
Thanks again mate.
dee101 is offline
#11 Old 10-03-2009
dee101's Avatar
Chats: 2
Hi woolly, I am currently performing the same task as you've mention for the Slk. Lets hope it works for me too.
dee101 is offline
#12 Old 10-03-2009
It all depends on the state of the battery at the time you hook it up to the trickle charger.
I use the Battery Tender brand, which I think works the same way. With a reasonably functioning battery, it takes about 2 hours for the trickle charger to give me a flashing green LED (indicating about 80% full); this is the rapid charge mode and the charger has now switched to trickle charge mode.
I usually connect the trickle charger at night on a weekend, at which time the green LED is flashing; by morning, the green LED is constantly lit, indicating a 100% charge and is on maintenance mode. This is prolly another 6-8 hours after reaching the 80% mark.
I did have one incident where I discharge the battery down to 11 volts, perhaps less (considered no power by the electronics in the car), and it took roughly 8 hours to get to the 80% mark and another 10 hours to reach the 100% mark.
#13 Old 10-08-2009
Vehicle: Silver '07 AMG 030
Other Toys: 2003 BMW K1200RS
I stand by Ctek.
zich6 is offline
What to do when the Battery is unplugged?? SuzaFan SLK R171 General Discussion 10 06-24-2013 03:33 PM
Flat Battery - what to do? mcat SLK R171 General Discussion 5 03-10-2007 08:06 AM
