R170 Blind Spot - Mercedes Benz SLK Forum
#1 Old 09-22-2008
Chats: 5
R170 Blind Spot
I notice with the top up that my driver's side (left) has a horrible blind spot. I can't turn my head to see there because the strut (term?) is right behind me. And the mirrors don't seem to see it all. Unless I remember who I've passed, and when, I'm taking a risk by changing lanes to the left. What do you guys do about this?
J
jd320 is offline
#2 Old 09-22-2008
I played with the adjustment of the inside mirror and the left outside so that as the car on the left leaves the inside you can just see the front in the side mirror
cruzer 8 is offline
#3 Old 09-23-2008
Other Toys: Hunter 25 Sailboat
Get a small (2" or so) diameter convex mirror at auto parts store to eliminate the blind spot.
SLKCop is offline
#4 Old 10-10-2008
Blind Spot Fix
I've used this method for many years with great success:
1. Center your rearview to the rear window.
2. With your head leaning on the driver's door glass,
position the outside mirror to just be able to see
the side of the car.
3. Lean into the middle of the interior and do the same
with the right hand outside mirror to show the same
view of the passenger side of the car.
This eliminates any blind spots. When a vehicle exits the
rearview mirror, it will show up in one of the side mirrors
depending on location.
This generally takes a few days to become accustomed to
as you are no longer seeing the sides of your car when
in the normal position behind the steering wheel.
Note: If no cars are showing in your side mirrors, you can
go there with impunity as an avoidance manuver.
Good luck
reynard is offline
The Following User Says Thank You to reynard For This Useful Post:
#5 Old 10-18-2008
Vehicle: 2004 SLK320 Special Edition
I guess I just like to see the sides of my car so I put one of those small rectangular convex mirrors on my outside mirror and I love it. I put it in the top right hand corner and it doesn't obstruct the view and I can see what's in my blind spot with just a quick glance. To each his own I guess but this works well for me.
steviestevie is offline
#6 Old 10-18-2008
HBK
Vehicle: 2005 Diamond Silver - SLK 350
I would always reccomend to use a diameter convex mirror and added to your driver side mirror. It makes a huge difference,regardless if you had the blind spot to begin with in your car or not...
I would always advice and thats what I used to do to...before I made my left turn or anything. I would not only look over my left shoulder, I would lean forward then turn my head to eliminate the blind spot and once u do that,you'll get used to it and its all normal.
But those convex mirror make big big difference on any vehicle!!!
HBK is offline
#7 Old 10-18-2008
I wonder why OEM mirror suppliers can't/won't just manufacture mirrors with the convex part built into or premolded unto one corner of the outside rear view mirrors?
#8 Old 10-18-2008
Thread Hijacker
dmjonez's Avatar
Chats: 1599
Saab does. My 9-3 has a split mirror that does just that. It's a little weird at first, but is really nice after you get used to it.
dmjonez is offline
#9 Old 10-18-2008
I didn't know that. I'll take a closer look at the next SAAB 9-3 I see.
#10 Old 10-19-2008
Founding member #7
mtiede's Avatar
Vehicle: 2017 SLC 300R
Quoted: 25 Post(s)
These extra mirrors etc. are not needed when following Cruzer 8 or Reynard's suggestions.
The only reason to see the side of the car in the mirror is to admire it. And I know the SLK is fun to just look at, but the mirrors can be put to better use.
mtiede is offline
Found perfect cup holder spot SLKman SLK R170 General Discussion 12 08-16-2015 06:07 PM
Blind Spot Mirrors KTownAMG AMGs 16 03-30-2009 01:06 PM
R170 fun Tslick SLK Videos 16 09-29-2008 05:41 AM
Best parking spot for an SLK. alroumi SLK R171 General Discussion 22 02-09-2008 02:04 PM
