Has anyone ever had an issue with the crank sensor CONNECTOR? - Mercedes Benz SLK Forum
#1 Old 05-17-2018
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 348 Post(s)
This is for an AMG M113 engine, but the M112 and M111 use the same crankshaft position sensor so this question is for everyone. The issue I'm having is the car will only occasionally start. it will turn over but no firing. I replaced the sensor with a known good one and had the same no start issues. Now one time I was fiddling around down there and it started, and that's when I learned that I can get it to start by having someone turn the key while I fiddle with the connector on the CPS. It's either the connector, or the wires going to it.
my next step is to take the entire shielded wire (up to the ECU) from my donor harness and swap it.
but I'm wondering if anyone else has had any issues like this?
Turdo2 is offline
#2 Old 05-17-2018
nimbusgb's Avatar
Quoted: 249 Post(s)
Nope. I've been involved with2 CPS failures but replacing the sensor itself fixed the problem instantly both times. That having been said a bad connector would be just as terminal. The CS is not an intelligent sensor, it is a hall effect device that outputs an analog signal to the ECU where the signal is squared up and interpreted.
I've used one as the sensor on an anchor winch chain counter!
nimbusgb is offline
#3 Old 05-17-2018
Delucas's Avatar
Quoted: 1133 Post(s)
Changed many but use genuine parts as using pattern components usually fail after a while .
As said there simple devices .
Once gone fault occurs more and more but once cooled off can start back up but fails later on again internal electrics break down again ......
Delucas is online now
R170 200k Not starting, no crank, not K40 vjcx SLK R170 General Discussion 23 05-26-2018 07:59 AM
98 SLK Wont Crank - ECM Issue Elias Chocalas SLK R170 General Discussion 1 07-17-2017 05:58 PM
Acceleration Issue & Mix Issue Questions CO 4x4 SLK R171 General Discussion 5 03-22-2016 09:21 AM
R 172 Roof seal broken, not sure if same issue as others have had? evanlangley SLK R172 General Discussion 11 01-13-2016 04:24 PM
Roof Closing Issue dterry SLK R170 General Discussion 4 07-10-2013 06:35 AM
