The pirates dilemma, which R for me? - Mercedes Benz SLK Forum
 7Likes
  • 2 Post By Mike6F
  • 1 Post By Idiot101
  • 1 Post By Avel Du
  • 1 Post By Mike6F
  • 1 Post By Mike6F
  • 1 Post By Mike6F
#1 Old 12-08-2017
Vehicle: White/beige 2012 350
Quoted: 81 Post(s)
I'm doing some research, and tending to favor newer models as a matter of course, but I don't want a turbo (I don't want to pay for a "performance" convertible as I only plan to leisurely cruise around in one). That had me favoring R171, but now I am hearing a lot of good about R170. Two basic questions for owners; 170 vs 171, years vs miles.
170/171 would be focused on the middle years not the mostly turbo earlier or later model years. I prefer the driving experience of the non turbo, and purchase cost and maintenance is higher for a turbo. IIRC 07/08 is the transition from 170 to 171.
This one has to be wife friendly, no wife annoying issues. That has me a bit spooked on anything older than 2005, with a preference for maybe 2011 ish. Should I pay less attention to the years and more to the miles or vice versa?
** Side note, dozens of flood damaged SLK are on the market right now, not a good idea almost ever. Google the vin at a minimum, even if you get a carfax etc.
LIL DON SLK and Yeravener like this.
Mike6F is offline
#2 Old 12-08-2017
Quoted: 6454 Post(s)
you already read this I assume
https://www.slkworld.com/slk-r171-gen...ook-guide.html
I had a 2002 SLK 320 and a 2005 SLK 350
I rate the 350 far above the 320 for styling and power
The r170 is at most a 22 year old car and at the least a 14 year old car
Rust has already set in
The r171 only had balance shaft issue/oil consumption early years 2004-early 2007
Get free datacards for all the cars you check out
years or mileage don't make a diff if taken care of
I have a 9.5 year old 108000 mile 55
Good luck
#3 Old 12-08-2017
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Condition is everything, age does not really matter, odo reading does.
My oldest car is a 1970, then an 88, 90, 01, 07, and 12. All have AC, all could go to LaLaLand tomorrow (70 would use A Lot of 93 octane).
All depends on the specific car and the life it has had (mine are all garaged in a no-rust climate).
Any 320 or 350 will have plenty of power for cruising and Interstate use. Manual trans is faster than automagic. (but a fast 1-2 is liable to trip the traction control with either.
The R171 has the best nose and tilt steering, the R170 is more DIY. For myself I specifically wanted a low milage SLK320 but a 350 with over 100,000 miles is probably past the balance shaft issue. YMMV.
Padgett is offline
#4 Old 12-08-2017
Idiot101's Avatar
Vehicle: 2004 slk32 amg
Other Toys: 69 GTX - Red!
Quoted: 252 Post(s)
Hmmmm...mine is an '04 and rust has NOT set in. I prefer the classic look of the 170. About everything that could go wrong is discussed by previous/current owners with diagnosis and DYI. Condition, mileage, and maintenance are the key. Not sure what wife friendly is, mine smiles every time we ride around 😀. don't know about yours, but the only thing that annoys my wife is my driving style, sometimes, 😈 And being stranded. Soooo, I got AAA.
Good hunting!
LIL DON SLK likes this.
The Toy
Idiot101 is online now
#5 Old 12-09-2017
Quoted: 2207 Post(s)
Mileage not so important.
Condition is everything.
Don't be put off by a lack of MB service.
IF the car has been loved, that far outweighs stamps in books.
Always work through the list:
https://www.slkworld.com/general-disc...checklist.html
Always get a datacard:
Vehicle Data Card - Mercedes Benz SLK Forum
Roof noise?
https://www.slkworld.com/general-disc...ts-hinges.html
Before you drive reset the adaptive learning.
https://www.slkworld.com/general-disc...-learning.html
[email protected] likes this.
Avel Du is online now
#6 Old 12-09-2017
Quoted: 81 Post(s)
Wife friendly, as this is "mostly" her fun car, means nothing "sort of" works, it has to work, as in start, lock, not make weird noises or vibrations. I've already used up all the tolerance points for old project cars I spend years fixing this or that on.
Two drivers in the family don't like shifting, which I love, but no arguing with it.
I had the date split wrong, as I read it, it is 03/04, which makes it much more likely I go with 171, unless a special car turns up.
Rust not much of an issue in SoCal unless the car is located very near the ocean.
I'm in general a big fan of very low mileage cars, less than 20k cars can be almost new in appearance, but some stuff does age even with care so I hope to keep below 100k. So far I note asking prices depend heavily on mileage, with 150k plus cars well below $5k
Thats all for now, back to looking until I find something promising.
Mike6F is offline
#7 Old 12-09-2017
55russamg's Avatar
Quoted: 664 Post(s)
Cool
As above, buy the best you can.
For cruising around I would go for a 55, so effortlessly achieving the burble.
The 170 AMG should hold its value as good ones are becoming rare.
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is online now
#8 Old 12-09-2017
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
The 170 230 is supercharged not turbo. The super charger only kicks in when you it hit. AS it is based on speed and how hard you hit the gas pedal. If maintained either one will last a long time. Condition is everything. There are many on here with hi mileage cars. I have a 2007 with over 100k and is still running strong and few problems over the years. For repairs look for a independent MB shop. They can save you money compared to dealers. Dealers have a high labor charge and some do mark up parts over MSRP.
Gbarringer100 is offline
#9 Old 12-09-2017
Idiot101's Avatar
Quoted: 252 Post(s)
Something special? Might look for an Slk32. Only automatics, supercharged, and perhaps an investment because of limited production. Manufactured '01 - '04. Good one 170/171's out there...just takes patience. 6 months to find mine.
The Toy
#10 Old 12-10-2017
Quoted: 81 Post(s)
Appeal of the 55 isn't lost on me, but it doesn't appear to be lost on anybody selling one either as reflected in asking prices.
I wondered about the super vs turbo thinking sellers might be confused, but neither one appeals to me for this car, V6 power is plenty for my uses, and either form of boost has more up front cost as well as longer term maint costs.
Mike6F is offline
#11 Old 05-01-2018
Quoted: 81 Post(s)
Happy ending, drove off from the dealer last night at 9pm in 2012 350 with 101k miles. I had no plans to buy it, just stopped in to let my wife see if she liked the seats, sport types with the nose on each side of your ribs. Unfortunately she liked them and a few minutes later I was in the hot seat coming up with an offer, double unfortunately they eventually accepted it. (humor, of course we are delighted).
More info in a new thread, but big part of decision to buy was the carfax showing regular dealer service.
Mike6F is offline
SLK55 Dilemma roscop AMGs 15 02-25-2016 03:20 PM
US Cargo Ship Surprises Somali Pirates With An Onslaught of Bullets jbanks15 Off Topic 7 08-24-2015 08:24 PM
Wheel Color Dilemma CT_SLK Tires, Wheels, Brakes & Suspension 28 01-02-2014 03:00 PM
Polish Pirates Berliner Heckflosse Off Topic 1 07-31-2013 11:47 AM
Delicious dilemma: 320 Manual or 32 AMG? jonathan General Discussion 6 08-19-2008 03:46 PM
