Correctly adding an accessory using an 'add-a-fuse' to an SLK - Mercedes Benz SLK Forum
 8Likes
  • 5 Post By mike350
  • 1 Post By Avel Du
  • 1 Post By mike350
  • 1 Post By Eeyorewolf
#1 Old 12-05-2017
mike350's Avatar
Vehicle: SLK350 r171, 2007, factory fitted sports/AMG body kit & suspension, Airscarf, S200 Android head unit
Other Toys: Triumph Spitfire/GT6, Lexus IS250
Quoted: 206 Post(s)
Following the fitting of my smart-top and a pair of USB feeds for my dash-cam and phone charger, using an 'Add-a-fuse' or 'add-a-circuit' device, it became clear that these can be fitted incorrectly.
2 -Add A Circuit Fuse Tap Piggy-Back Standard Blade Fuse Holder ATO ATC 12v 24v | eBay
The correct way is so that each circuit is protected by it's own fuse.
The incorrect way has your new accessory drawing its power via both fuses.
It's therefore important to check that you plug the 'add-a-fuse' in the correct way round and there's a very easy test you can do, even if you don't have a meter.
Simply remove the lower (original) fuse, leaving just the new fuse for your accessory and see if you still have power to the new device, if the power has gone off then the 'Add-a-fuse' is the wrong way round.
See pictures for more details and note the +12v feed is different in the two pictures.
Hope this helps.
jbanks15, Trev5, dbgrn and 2 others like this.
Mike
It's the journey that matters, not the destination.
Modifications ..
Tinted rear lights, Chrome bonnet fins, LED DRL/fog lights,
S200 Android head unit, Paddle shift installed, dash cam,
Resonator boxes (2nd Cats) removed, smart top.
mike350 is offline
The Following User Says Thank You to mike350 For This Useful Post:
#2 Old 12-05-2017
Quoted: 2204 Post(s)
Great tip, Mike.
mike350 likes this.
Avel Du is online now
#3 Old 01-21-2018
Vehicle: 2005 SLK 55 AMG Silver
Other Toys: 07FLHX, 10Harley Edition F150, 10Lincoln MKS AWD Eboost, 14 Edge Limited AWD, 06 Chevy 6.6 Duramax
Quoted: 107 Post(s)
It looks like WRONG WAY installation would bypass one of the fuses leading to a potential dangerous situation. Good tip! I'll be needing some of these to correct some issues the previous owner of my vehicle created while adding some custom lighting.
Eeyorewolf is offline
#4 Old 01-21-2018
mike350's Avatar
Quoted: 206 Post(s)
No, youíre still safe if you fit the wrong way round, itís just your power feed comes via both fuses in series. So if the original fuse has a low rating, it could blow with a higher rated add-on.
Eeyorewolf likes this.
Mike
Modifications ..
mike350 is offline
#5 Old 01-21-2018
Quoted: 107 Post(s)
Thumbs up
-It looks like WRONG WAY installation would bypass one of the fuses leading to a potential dangerous situation. Good tip! I'll be needing some of these to correct some issues the previous owner of my vehicle created while adding some custom lighting.
-No, youíre still safe if you fit the wrong way round, itís just your power feed comes via both fuses in series. So if the original fuse has a low rating, it could blow with a higher rated add-on.
Can't seem to use Multi-Quote so I copied and pasted:
OK I see it now, the writing is very small and my eyes are old but I see it, the lower fuse replaces the original fuse and the upper fuse is for the new device so it comes down to how you plug the "add a fuse" into the fuse block, the prong opposite the new device wire goes to the hot side and the other prong goes to device (whatever that may be). Thank you for clarifying, it's easier to see also if you click on the picture. I could see how someone could miss that so good tip. Thanks again.
cobaltproductions
R171 Fuse Allocation Chart Puffin Where to get R171 SLK Items 34 05-22-2018 04:48 PM
Fitting Daytime Running Lights (DRLs) plus LED fogs and how to wire them. mike350 SLK R171 Class DIY 14 10-30-2017 01:53 AM
SmartTop Roof module Install for the R171 etyu SLK R171 Class DIY 13 09-29-2017 09:49 PM
DRL wiring / fuse box question for techies / DIYers JMG General Modifications R171 3 10-02-2016 07:04 AM
location of fuse for interior fan jsc6546 SLK R170 General Discussion 7 08-04-2011 10:17 PM
