350 Exhaust ? - Mercedes Benz SLK Forum
#1 Old 06-07-2007
Post 350 Exhaust ?
Been looking over the site and cannot find info on the standard system on the 350 ---- mine has the cats upfront then the pipes back to an X pipe then out to the mufflers located at the very rear just before the tips --- is this the stock arrangement ?
cruzer 8 is offline
#2 Old 06-07-2007
Yes Gene, that´s standard
Banned is offline
#3 Old 06-07-2007
Thanks Gero
cruzer 8 is offline
#4 Old 06-07-2007
Ynot's Avatar
Quoted: 23 Post(s)
Yes, I have pics of it somewhere on this site, two cats, straight into an x-pipe, then the dual exhaust tips, so it's stock arrangement.
edit:
found one pic towards the rear but I have another one showing the cat's, I think it's at benzworld.
997 TPC turbo C4S
981 Boxster S
06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR. (Gone but not forgotten)
Ynot is offline
#5 Old 06-07-2007
Bernd js's Avatar
Vehicle: 2014 SLK 55AMG Driver's Package, Performance Package
Other Toys: watches, E63 AMG 4M (W212)
O.k., Ynot himself was little bit faster.
But here is the thread of the Supersprint installation.
https://www.slkworld.com/performance-...installed.html
And here the arrangement of the cats. But the car has four, two on each side that you can easily see, the other two vertically near the engine.
Bernd js is offline
#6 Old 06-07-2007
Link to Ynot's supersprint exhausts install (before and after piccies): https://www.slkworld.com/performance-...installed.html
#7 Old 06-07-2007
Vehicle: SLK350
so the 2 visible ones are the cats? and there is no resonataor on the car?
Wallance is offline
#8 Old 06-07-2007
Resonator (muffler) is located aft of the catalytic converters and X-pipe. It is visible on Ynot's photo to the right lower side of the photo.
#9 Old 06-07-2007
Im soooo jealous, that zaust pipe system is purfict. Makes the car sound better too I bet. Me an Bubba is cipherin on my new system tonite. Bubba says luminum is the best so we bought two cases of Bud. After 2 six packs I realised Bubba waz right, now I think the stock muffler sounds perfict,,,,,, 2 cases Bud $30.00 zaust $2100.00, dang I saved $2070.00 an didn't even have to git tha bumper jack out. Thanks Bubba, you are my hero(((((wonder what the car will sound like tomorrow,,,, probably be too loud after all that beer))))))
doug " MASTER POST HO"
" VILLIAGE IDIOT"
412driver is offline
#10 Old 06-07-2007
Vehicle: SLK350
is that the resonator? I was looking at the slk55 exhaust system, and there is an extra box b/w the cat and muffler, wut's the difference b/w that? and I see ppl cutting off that resonator b/w the cat and mufflers.
what happens if i de-cat the slk350? would it make a difference?
Wallance is offline
#11 Old 06-08-2007
There is a difference between the 55 and 350 exhaust. Resonators are used to get the right sound. The 350 has it OEM and don´t need one, the 55...
Banned is offline
#12 Old 06-08-2007
Vehicle: SLK350
uh hhuh! i see now! thankss
so would it be any diff. if i de-cat it? would it haf loss or gain anything?
Wallance is offline
#13 Old 06-08-2007
I believe you´ll lose your warranty and you´ll win tickets from the police if they catch you.
Banned is offline
#14 Old 06-08-2007
DansSlk
Guest
Posts: n/a
Chats:
Quoted: Post(s)
You can't de-cat the 350 its OBDII will be in limp mode all the time and wont pass any emissions tests.
You could install sports-cats if you wanted but any mods would void the warranty.
On the 55 the resonator is the box roughly where Ynot's X pipe is
#15 Old 06-08-2007
Ynot's Avatar
Quoted: 23 Post(s)
As mentioned before de-cat will not pass emissions, not a good idea, there are options, you can get free flowing sports cats on ebay for $95 each (link on mbworld in the SLK55 section), go to a muffler shop and get it welded along with a new x-pipe and quad tip mufflers, it should sound very good, not sure how much power increase/decrease, should run you about $800 USD. I thought about it but decided to go with something proven. Good luck.
997 TPC turbo C4S
981 Boxster S
Ynot is offline
#16 Old 08-11-2010
Vehicle: 2009 SLK 300
Send a message via AIM to aznflightfreak23
Does the R171 SLK 300 have primary cats and then leads to secondary cats? Can I just remove the secondary cats and replace with the X pipe?
aznflightfreak23 is offline
SLK R170 350 modifyd with the SLK 55 AMG exhaust System... chrome-tec SLK Videos 16 07-02-2011 01:51 PM
Selling:Eisenmann Exhaust System for R171 Mercedes Benz SLK 350 280 (Toronto, Canada) big_willy Where to get R171 SLK Items 6 04-28-2008 10:17 AM
exhaust? Wallance Where to get R171 SLK Items 3 07-20-2007 01:22 PM
SLK 350 Exhaust is to quiet ? Mike Hampshire SLK R171 General Discussion 17 01-19-2007 07:37 PM
New Exhaust Steve SLK R171 General Discussion 11 12-12-2006 03:46 PM
