Bad Mercedes Benz representation in Costa Rica - Mercedes Benz SLK Forum
General Discussion Topics must pertain to all 3 generations of SLK - R170, R171 and R172 only.
#1 Old 06-28-2012
Vehicle: 2000 230K blue
Other Toys: A Prius! Yes... that's right... a f.... Prius!
I bought my SLK 230K in the US an exported it to Costa Rica... Well.. a few days ago the "check engine" lit up. As the manual instructed, I called the nearest MB representative, a company named AutoStar, the only authorized MB agency in Costa Rica. To my surprise they asked me if I bought my car from them, and as I didn't they said they couldn't service it, nor recommend any unofficial shop!!! So basically There is NO official Mercedes Benz representation in Costa Rica, as my car clearly IS a Mercedes Benz, an no one can service it. I seriously doubt this is a Daimler policy, as a MB is a MB no matter where you buy it, no matter how old or which model it is!
Oh and BTW They said they can service my car if I pay $10.000 fee (For not buying the car from them... absurd and ridiculous!)
mchaconcr is offline
#2 Old 06-28-2012
AZ SLK's Avatar
Vehicle: 2007 MB SLK 280, Remus Exhaust, TSR 17" wheels, Pirelli PZero tires
Other Toys: '15 Z51 Corvette, '12 Cadillac Escalade EXT, '11 MB GLK350, '04 Honda GoldWing, '13 Craftsman VT4000
Quoted: 25 Post(s)
Wow, talk about a captive audience that is being taken advantage of. Sorry to hear of your woes, however, a lot of things can be fixed by using the Search function and wealth of knowledge of those that have gone before you. Best of luck.
Michael --
AZ SLK is offline
#3 Old 06-28-2012
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
It's probably not as bad as it seems. AutoStar certainly doesn't act like they want your business! As your car is after 1996 it has a common On Board Diagnostic (OBD) port. Most common OBD Readers (small hand held device) will plug into your car's port and can tell you what the Check Engine Light (CEL) code is and what it means. Hopefully it is a minor one, like the last one mine threw at me (P009A-High Ambient Air Temperature). You should call around and see if any of your local repair shops have an OBD reader. In the states the Auto Parts stores like AutoZone etc. have the readers and will read the codes for free.
It doesn't sound like you have a warranty on your car, so if not you are now in the "find a repair shop you can trust that has some experience with M-B cars" mode. Another advantage you have is this site. The more you know about what's wrong (CEL Code, other things the car is doing out of the ordinary) the easier it will be to find on here what may be wrong with the car and how you may fix it.
Regardless, I hope that you find what you're looking for. Once you know more feel free to post it here. There are lots of smart experienced people on here with your model car, and they are usually glad to help out a fellow SLK owner.
Best Wishes
Gene
REB_TN_06 is offline
The Following User Says Thank You to REB_TN_06 For This Useful Post:
#4 Old 06-29-2012
Thanks! Well... I had a pretty damaged alternator... for some reason the cover was cracked and the magnets were exposed. I had no clue about this until I had the oil changed, and the guy changing it called me to point that out.... Nothing seemed wrong with the car, but anyway I ordered an Alternator (As this is Costa Rica, orders may last up to 3 weeks to be delivered). A few days after having the oil changed the battery light lit up on slow revs... like at stops... but on the go it slowly faded to normal (unlit) until the next stop... So I pretty much figured out it was the broken alternator asking to be replaced... But then at some point the check engine was also on, but the next day it was off...
And then on again... the alternator finally arrived... I took it to the nearest shop and a guy replaced it for me ($40 only). The check engine was off by then... and he said I better check the transmission fluid as it seems to be a small leak.
And at night the check engine lit again.... but this time I have the new alternator installed! so... it wasn't that! :/
Oil change -> Bad alternator discovered
Alternator replacement -> Transmission Fluid leak discovered.
I wonder what will be the next discovery! haha.
Has anyone tried something like: http://www.amazon.com/goPoint-Technology-OBD-II-Accessory-iPhone/dp/B00336S7KS/ref=sr_1_7?ie=UTF8&qid=1340940542&sr=8-7&keywords=OBD-II
To diagnose the "check engine" light? Any recommendation? $98 seems to be slightly less than the $10.000 AutoStar wants!
#5 Old 01-23-2013
Hi Mchaconcr,
Sorry to hear aobut your issues there. I was researching the same thing as I was curious about relocating to the southern part of CR and was not sure if I should bring my vehicles down, either by driving stright thru Mexico or shipping them. However I came across this fellow on another site and he may be able to help.. I just don't where he is located comared to you..? http://www.linkedin.com/pub/hans-roetzer/7/667/92b I have a 1990 500SL and 1972 GMC 4x4 Jimmy convertible that I would definitly keep..
amcgeh01 is offline
#6 Old 01-23-2013
Quoted: 6614 Post(s)
amcgeh01,
Moderator/Founding Member
Tags
check engine, costa rica, service
My 2012 Mercedes Benz SLK 350. malc410326 SLK R172 General Discussion 21 12-07-2016 07:19 PM
Defective Mercedes Benz Vehicles Class-C-E-CLK-SL-SLK-ML HwoALanG SLK R171 General Discussion 7 12-17-2011 08:54 AM
Pistonheads Sunday Service at Mercedes Benz World QuickSilver Exhausts United Kingdom Region 2 01-05-2011 07:55 AM
Mercedes Benz DiesOtto Engine MarkR171 Off Topic 3 07-26-2007 09:05 PM
