Messed up on touch up paint, will a paint correction resolve this problem? - Mercedes Benz SLK Forum
 3Likes
#1 Old 06-15-2012
Vehicle: 2006 SLK55 AMG
Today I accidentally applied too much touch up paint on my car hood, I tried to remove it immediately by a microfiber towel but ended up making it worse, which leaved a extremely thin layer of paint around that area. Will a paint correction do the job and resolve this problem?
Found a reputable car detailing shop offer a 29-stage paint correction/polish service, hope this help.
Thanks for everyone's opinion
li174 is offline
#2 Old 06-15-2012
Fanatical Member
Stinger's Avatar
Other Toys: yes
I see a few swirls in your finish so a good detail will probably make a huge difference in the overall appearance of your car. As far as the touch up paint goes, probably nothing more than a good compound followed with a wax will do the trick. Mind you I'm no expert but I have found rubbing compound corrects a lot of little things on the finish.
Steven
Stinger is offline
#3 Old 06-15-2012
Vehicle: 1998 slk 230 kompressor,wth 2inch dropp on 19 inch savini sv 2's stagered signiture edition
Other Toys: bmw m3,bmw 325 ci coupe,e 55 amg
if that dont wrk then reface area,,,,, good lk.
benzpwr is offline
#4 Old 06-15-2012
I think I'm going to try the Blob Eliminator by Langka to see if I can remove the excessive touch up paint,
found a old thread from etyu concerning the same product,
will give it a try prior doing the paint correction, since the shop is 125 miles away
Saw many good reviews on this product, hopefully it can arrive early.
I'll post some pictures for the whole process in case other forum member might encounter the same issue
etyu likes this.
li174 is offline
The Following User Says Thank You to li174 For This Useful Post:
#5 Old 06-15-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
I'd give some TLC with a bit of rubbing compound as Steven suggested as a first step - cheap and pretty easy, just take your time and go a bit at a time...
UK-C200 is offline
#6 Old 06-15-2012
gregotal's Avatar
Vehicle: 2007 SLK 280 7G AMG white
Other Toys: 2014 white Nissan Juke 2010 INFINITI FX 35 Blue slate
Quoted: 7 Post(s)
You can clean it with solvent i don't how you call it (tiner) or the one your wife uses to clean her nail polish (nail polish remover), take a soft cotton and put on a little solvent and gently wipe the surface where the exeed layer of paint is.
Regards Greg
gregotal is offline
The Following User Says Thank You to gregotal For This Useful Post:
#7 Old 06-16-2012
Vehicle: benzo on lorenzos draggin titanium
Other Toys: a few
wipe it off with laquer thinner use a rag that been washed new rags can bleed color and stain for fixing the spot right it needs paintbulled. theres a couple neutralizing steps between chemicals but really its easy and 29 steps from your detail shop is some b.s. that many steps of anything would wear the paint off
bstevens52 likes this.
unregisteredunregistered is offline
The Following User Says Thank You to unregisteredunregistered For This Useful Post:
#8 Old 06-16-2012
Chats: 2
Quoted: 13 Post(s)
I'd forgotten about Langka! I know a few people in other forums who've used it and were very pleased with the results. I just ordered the repair kit, so I'll give a report/review with before/after pics.
Think outside the box!
Galo is offline
#9 Old 06-16-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
Please do Galo - I've tried the Dr Colorchip, and was pretty pleased with the results. I think Steven (Stinger) was going to try it on some vertical surfaces as well - I only did chips on my hood...
UK-C200 is offline
#10 Old 06-16-2012
Chats: 2
Quoted: 13 Post(s)
My only real problem will be my earlier attempts at "filling" the scratches and "pot holes"; I put on just a bit too much t-u paint, and the Langka site states the process may not be able to totally correct this. I guess I'll find out soon enough!
Galo is offline
#11 Old 06-16-2012
Fanatical Member
Stinger's Avatar
Other Toys: yes
Sorry guys, haven't got around to it yet. Off tomorrow, and it's father's day so maybe I can get to it then. Next opportunity will be Friday, 06/16. If I can't tackle it all, maybe I can do a little to see how it comes out.
Steven
Stinger is offline
#12 Old 06-16-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
No worries, and no rush - key seems to be to take your time, so probably better to "plan" to have a couple of hours to play!
Stinger likes this.
UK-C200 is offline
#13 Old 06-18-2012
Other Toys: a few
the correct way is to paint bull them chips
#14 Old 06-20-2012
Update:
The Langka Blob Eliminator surprisingly work like a charm!!
Before:
After:
Everything is gone now! like it never happened! Highly recommend! It is even able to remove the touch up paint which is 6 months old!
li174 is offline
The Following 4 Users Say Thank You to li174 For This Useful Post:
#15 Old 06-20-2012
Quoted: 6546 Post(s)
Great to hear!!!! car looking great again!
#16 Old 06-20-2012
Fanatical Member
Stinger's Avatar
Other Toys: yes
I will try the Dr.Color but this could be a good alternative. I watched their video on their website and it says nothing about clear coat applications after the paint application. I wonder if you eliminate the clear coat all together or apply the clear coat after the paint and then use the blob eliminator?
Steven
Stinger is offline
#17 Old 06-20-2012
I just paint it with OEM touch up paint and wait for 30mins, then apply the blob eliminator!
li174 is offline
#18 Old 06-20-2012
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
Steven et.al.,
I had the same question. I love the results in the picture, but as the M-B touch up paint comes with the clearcoat I was wondering whether a second round with the clearcoat would result in a more durable repair? Or should I leave a depression after applying the paint and then go for the flat surface match with the clearcoat?
Let me know how the Dr. ColorChip works out. I think John started a thread on it a few weeks back. Does it address the clearcoat issue?
Regardless - I'm thinking that for $30 this is a great option. I am starting to get a lot of paint chips on the front of my car and while I have the official M-B Code 950U touch up paint - I haven't used it on the hood because of the blob issue.
Gene
REB_TN_06 is offline
#19 Old 06-20-2012
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 273 Post(s)
Hmm, that's some impressive results with the Langka. I'll have to get one of those and try that technique of overblobbing and then removing the excess with this stuff.
Durkatlon is offline
#20 Old 06-20-2012
Chats: 2
Quoted: 13 Post(s)
I received my Langka Paint Chip Repair Kit today!!! They shipped it Monday, USPS Priority; 1 day in transit...thank you former employer I will probably do this this weekend, so I'll have pics posted as soon as I can.
As for clear coat, this from the Langka web site;
1. The Two Step Method: After following Steps 1,2,3 above you may clear coat the repair if desired. Clear coat applications requires a microbrush . Simply dip the brush into the clear coat solution and wipe the brush on the inside of the container to remove excess clear coat from the brush. You are only trying to "surgically" apply a very light coat to restore the shine and provide UV protection to the larger repaired areas. You do not want to apply a blob of clear coat. (IF you apply a blob, you can remove the blob of clear coat with LANKGA...but it is best to be as "surgical" as possible). You may want to have your kids do this...better eyesight and all. TIP: rest your hand on the vehicle to stabilize your hand during this application.
2. Another more popular method for using clear coat is this: Mix the paint and clear coat in a 1:1 ratio (using a paper ketchup cup from a local fast-food restaurant for mixing in). Apply as directed. Allow to dry, then remove the excess "mixture" if necessary with The Blob Eliminator."
Now we know!!!
Galo is offline
The Following 2 Users Say Thank You to Galo For This Useful Post:
Detailer's Domain: 2006 Volvo XC90 - Paint Correction, Engine, and Interior DetailersDomain Caring for your SLK 0 05-15-2012 01:42 PM
Detailer's Domain: BMW 335 Paint Correction DetailersDomain Caring for your SLK 0 04-24-2012 10:26 AM
Detailer's Domain: MB SL500 - Paint Correction Detail DetailersDomain Caring for your SLK 3 03-16-2012 11:32 AM
Annoying Rock Chips AIR44 General Discussion 30 12-02-2010 12:09 PM
Detailer's Domain: Porsche 911 CS - New Car Paint Correction DetailersDomain Caring for your SLK 2 08-18-2010 11:45 PM
