Smarttop oops - Mercedes Benz SLK Forum
  • 1 Post By mr-lama
#1 Old 06-11-2012
Vehicle: 2006 slk55 AMG
Smarttop oops
Ok, put in my smarttop and wired in the valentine one detector today. It sucked, I hate working with plastic pieces and it seems like everything is designed to cut you, but after a while I got it, and I do love it, it works great.
However, during the process I did something that made my car think there is a SRS error. I did a search and found someone who did the same thing, he got his reset by some expert mercedes technician. Sounds like mine needs the same thing. I am not really sure about bringing it by mercedes, don't know what they will do or if they will dig around and find the smarttop. Went by another place and their little handheld computer wouldn't reset it, and they said it would be $50 to hook it up to their other thing they use to diagnose cars, and they could do it with that.
Any recommendations on what I should do? Would unplugging the battery for a while do any good for me? Do you think mercedes could do anything, hopefully without spending a bunch of money? I don't really want to buy my own code reader to reset it, I don't work on the car myself enough to warrant the money.
This smarttop is cool though. Didn't realize how much of a pain it was to hold that button. Now if I can just get this fixed it will be perfect!
mr-lama is offline
#2 Old 06-11-2012
Vehicle: SLK R171 200k 2005
I think that you could find an indy garage where they will manage to reset the error... Even here we have such garages...
SamuraiSpirit is offline
#3 Old 06-11-2012
Double check the wiring harness and connectors at the bottom of the seats to make sure they are well seated or connected tight and proper. Use a flashlight/torch as needed.
Make sure you "de-activate" the smartTOP (Function 1 is OFF ) before going to any garage/shop, otherwise you DAS will get error message.
#4 Old 06-12-2012
Ok, went to a local independent shop and they reset it for me. All is good, no issues.
Just to check, the srs light stays on for a split second after startup, then goes away. Is that normal? No error warnings or anything, just don't remember if it has always done that or not.
Thanks guy!!
SamuraiSpirit likes this.
mr-lama is offline
#5 Old 06-12-2012
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Thanks guy!!
It's normal for it to stay on for about a second on startup.
Woolly is offline
#6 Old 06-12-2012
Thanks guy!!
Per DansSLK, when doing the ignition process to start the R171, do the following:
1. insert key and turn to position 1, the SRS red warning lamp will turn on (brake warning lamp will also turn on if e-brake is engaged), wait for SRS lamp to turn off (usually after 5 seconds, this is when the car computer system is doing its checks and boot-up process), then ....
2. turn key to position 2, and wait 3 seconds, then ....
3. turn key to the right and release immediately (think of it as a spring-loaded switch, this sends signal to start ignition process and start the engine). Do not turn and hold (as this will send multiple signals to start the engine, may confuse the "car-puter", much like a keyboard sends a signal to type a letter)
.... so to answer your question: yes, it is normal for SRS to light up for a few seconds while in position 1.
#7 Old 06-12-2012
Sweet.
mr-lama is offline
Original Issue Piecha module vs SmartTop, personal impressions etyu General Modifications R171 41 11-14-2013 12:19 PM
SmartKey/Cartronics/Mid City, and SmartTop danieleik General Discussion 26 09-11-2013 08:59 AM
Problem installing SmartTop module Karl-Johan SLK R171 General Discussion 7 06-10-2012 05:57 PM
Faulty SmartTop? etyu General Discussion 3 08-21-2011 06:27 PM
