Touch up paint help - Mercedes Benz SLK Forum
 9Likes
#1 Old 04-24-2012
Johnnguyenskyline06's Avatar
Vehicle: 1999 R170
Touch up paint help
I looked through a couple of thread about where to get touch up paint from. I just have small scratches here and there mostly some jerk drivers opening their door to hard and slamming into my door. I saw some place had top coat and base coat. There are some spot that has rust and I would like to clean that up before I apply the touch up paint. I have no idea what I actually need to get the job done. Your advice and insight would be greatly appreciated.
Johnnguyenskyline06 is offline
The Following User Says Thank You to Johnnguyenskyline06 For This Useful Post:
#2 Old 04-24-2012
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
I have an '06 R171 SLK 280. I went to the dealer and ordered a touch up paint pen (actually a small bottle with a brush) with my specific Color (950) as well as one with Clear Coat for $18. Well worth the $ IMHO.
For the 171's the Color code is on the Datacard as well as on the inside of driver's door frame.
Gene
REB_TN_06 is offline
#3 Old 04-24-2012
Quoted: 6580 Post(s)
dealer is a great place to start despite the price.
#4 Old 04-24-2012
Vehicle: 2004 SL500
Other Toys: Legos, tinker toys, blunt crayons, whiffle balls, and sponges...
Paint
Dealer, yes. Then maybe something like the Langka blob eliminator.
johnr43 is offline
#5 Old 04-24-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
I've just ordered one of the DrColorchip kits after seeing the results on a friends BMW here in Houston. I'll hopefully have time over the next week or so to try it out on the '350 where I've got 40k miles worth of rock chips from the wonderful La/Tx roads.
UK-C200 is offline
#6 Old 04-24-2012
Vehicle: 1999 R170
Any suggestion on best way of removing rust?
#7 Old 04-24-2012
06SLK-Noob's Avatar
Vehicle: 2006 SLK280 - Silver
Other Toys: 2014 CLA250, 2013 Nissan Leaf
Quoted: 28 Post(s)
I was just thinking about trying that! The ad claim is impressive. Please let us know how well it works
06SLK-Noob is offline
#8 Old 04-24-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
Will do, the "real life" on my friends BMW was pretty damned impressive as well - curious to see if I can achieve the same results.
UK-C200 is offline
#9 Old 07-10-2012
Airmousam's Avatar
Vehicle: 1999 SLK gone....2007 CLK550 & 2010 E550, now looking for a SLK55
Other Toys: 2009 Suzuki M109R
How were the results? Thx
Airmousam is offline
#10 Old 07-10-2012
Vehicle: 2001 Silver SLK230
Chats: 2
Check out this link: https://www.slkworld.com/caring-your-...int-chips.html and do a search for Dr. Colorchip on the forum.
GusSLK is offline
#11 Old 07-10-2012
Sadly Gregg has passed away
Gregg's Avatar
Vehicle: 2009 SLK 350
Chats: 5
Quoted: 17 Post(s)
I have used factory touch up and Dr Color Chip.......the Dr Color Chip is by far the best. I allows much more control and is almost imperceptible after application. Plus, if you flub up it can be easily removed and then you just try again. I'll never use factory touch up paint again.
Gregg is offline
#12 Old 07-10-2012
MidLifeSolution's Avatar
Vehicle: 2004 SLK 320
Other Toys: 2011 Mercedes E350
Rust stop
For the rust, if it's just surface rust, I have used a rust stop product I got from my local Napa auto parts store. I don't remember the actual name, but it comes in a small plastic bottle with a built in brush. You remove the surface rust flakes using a wire brush, or sand paper, then "paint" this stuff one. It cures pretty quickly, turning black and prevents the rust from returning. It claims it is safe to paint over it.
If there are surface pock-marks from the rust, you may want to apply some of that red finishing putty prior to priming and painting. Again, that comes in an over-sized tooth paste tube from Napa. You'll want one of there plastic putty knife kits and some 320 and 500 grit wet paper.
I've never painted over the rust stop, I've just used it to stop rust from spreading on the rear tailgate of my 1999 F-250.
I've used the red putty, spreaders and wet sand paper to fill in cracks in the fiberglass on my previous toy - a kit car that looked like a 1929 Bugatti T-35B, based on a 66 VW bug.
MidLifeSolution is offline
#13 Old 07-10-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
Quite nice actually - was very impressed with the system - here's the thread I posted the results in.
UK-C200 is offline
#14 Old 07-11-2012
Airmousam's Avatar
Ordering mine today, thanks for the posts!
#15 Old 07-15-2012
Airmousam's Avatar
Dcolorchip is awesome! Simple to use and the results were very good. Did mine yesterday...Used navel jelly to remove the little rust specs in the chips, washed the car, and applied the paint. Piece of cake
UK-C200 and Yeravener like this.
#16 Old 04-15-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Just ordered Dr Colorchip for the new baby. I am hoping all the rock chips in the front quarter panels on my Jeep will benefit from this too. I can't wait to see how it works!!
Loving the older threads...
slk320chick is offline
#17 Old 04-16-2013
Airmousam's Avatar
I think youll like it! If you have some rust in some of the paint chips use loctite navel jelly rust dissolver then wash and dry the car....will improve the results. Good luck
slk320chick and Yeravener like this.
#18 Old 04-26-2013
Minion
Quoted: 148 Post(s)
I ordered 2 of the Dr Color Chip sets. One for the new girl and one for my Jeep. I thought it best to experiment with the road rash on the Jeep before I touch the slk.
Things I learned
1. let it sit for 10 minutes to dry if its a deep nick
2. buffing the final solution like you were buffing the car takes everything else off the area - dont just buff once or twice then leave it, you'll see the residual paint outside of the nick, that can be taken off too
3. it works on long scrapes too
Gorgeous result! couldn't be happier. Ladies, its like getting your nails done, but in a much shorter amount of time. Smear it on, wipe off the excess, buff, done.
Before
After
Helix, AZ SLK and BCoolidge like this.
#19 Old 04-30-2013
Airmousam's Avatar
Glad it worked out!
#20 Old 04-30-2013
Minion
Quoted: 148 Post(s)
It's pretty amazing stuff. Now I just have to crack open the other package and do the slk with it, since the jeep was the guinia pig. TY
OEM wheel touch up paint... robster SLK R171 General Discussion 5 07-22-2011 01:00 PM
Interior Paint pictures - touch up, color not matching... HBK General Modifications R170 6 03-20-2011 05:01 AM
Annoying Rock Chips AIR44 General Discussion 30 12-02-2010 12:09 PM
Cubanite silver touch up paint GrubbyGirl SLK Parts For Sale 1 05-04-2010 03:23 PM
