Command Center - Mercedes Benz SLK Forum
#1 Old 04-05-2012
Richard in South Carolina's Avatar
Vehicle: 2012 SLK 350 - Black
Other Toys: Honda CRV-2018 Ford Explorer - Two John Deere Gators & John Deer Tractor
Quoted: 19 Post(s)
Command Center
Have not been successful finding this in the book.
Can anyone tell me how to turn the radio off while using the GPS without turning off the entire unit?
Richard in South Carolina is offline
#2 Old 04-05-2012
Quoted: 6546 Post(s)
was not possible on my r171 09
#3 Old 04-05-2012
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Can't you just turn the volume down?
Woolly is offline
#4 Old 04-05-2012
PWSLK's Avatar
Vehicle: 2012 SLK350
Other Toys: 2019 Volvo XC60 T8
Quoted: 28 Post(s)
Can't do on R172 either (that I'm aware of).
Peter
2012 SLK350, European Delivery, Lunar Blue with Sahara Biege Leather.
Premium 1 Pkg, Command Launch Pkg, Lighting Pkg, Sport Pkg.
Dual Zone Climate Control
Parktronic w/adv parking guidance
Panorama Roof, Keyless Go, Chrome Hood Fins
Distronic Plus Pkg
Dynamic Handling Pkg
SmartTop v1.40
WindRestrictor
Akebono Front Ceramic Brake Pads
sold: 2006 SLK350 Caspian blue
other car: 2019 Volvo XC60 T8
PWSLK is offline
The Following User Says Thank You to PWSLK For This Useful Post:
#5 Old 04-05-2012
Vehicle: 2006 SLK280 MT
As far as I know you can't, but you can hit the Mute button.
Iridium is offline
The Following User Says Thank You to Iridium For This Useful Post:
#6 Old 04-05-2012
then u don't hear the turn by turn directions, no?
#7 Old 04-05-2012
PWSLK's Avatar
Quoted: 28 Post(s)
Go to Audio, change to a media that's empty (like Sd card), that way navi will be on, but no audio is active.
Peter
Distronic Plus Pkg
SmartTop v1.40
WindRestrictor
PWSLK is offline
The Following 2 Users Say Thank You to PWSLK For This Useful Post:
#8 Old 04-05-2012
that works? mine usually says no sd card present.
#9 Old 04-05-2012
For the R171:
If you just want the radio or music to fade out or go quiet when the Navigation lady talks, then you can go into the Navigation system menu and choose Maximum Fade Out.
Press Nav. Within the Navigation Screen, press Setting > Nav. Vol > choose Maximum Fade Out (by using the up and down on the cursor so that the radio button next to the Maximum Fade Out is highlighted or filled in). Press OK.
If you just want the music/audio to be off, while the COMAND screen shows the map and the music is sounding its thing, press MUTE button just below the COMAND screen. Music will be off and the Sat Nag Lady will still tell you the verbal instructions.
Maybe the function is similar in the R172 with COMAND Nav.
The Following 3 Users Say Thank You to etyu For This Useful Post:
#10 Old 04-05-2012
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
. . . and if you want the SatNag Fraulein to be louder, just turn the volume up when she's ordering you where to go (or, if she's keeping quiet, just hit the little speaker button, and she will repeat her last utterance, then turn the volume up ).
Woolly is offline
#11 Old 04-05-2012
can't find that setting eddy on my 09 2.5 comand. it does state to turn volume knob to make the nav voice louder than the radio.
i hit nav and then there is no 'setting' choice. no biggie. thanks
#12 Old 04-05-2012
Is it in the main system menu? Or it may be in the soft key menu within navigation?
#13 Old 04-05-2012
not in the main menu or any soft key. not too worried about it, just wanted to mention it. is it comand 2.5 specific? do u have 2.5?
#14 Old 04-05-2012
I have the NGT 2.0 (I know it's dated, but it works fine still )
#15 Old 04-05-2012
so that is why it is different from my 2.5. no problem. ty
#16 Old 04-05-2012
PWSLK's Avatar
Quoted: 28 Post(s)
Select Navigation and destination.
Select media which is not currently loaded eg SD card.
The audio portion of navi is still audible, but no music or radio is playing because I chose a "device" which doesn't have anything loaded.
Peter
Distronic Plus Pkg
SmartTop v1.40
WindRestrictor
PWSLK is offline
#17 Old 04-05-2012
I think you have to load an "empty" SD card.
#18 Old 04-06-2012
Quoted: 19 Post(s)
Wow, what a mountain of informatiion you folks have (and share). Thanks I'll try these today.
#19 Old 04-06-2012
SPW
SPW's Avatar
Vehicle: SLK 200 - 172
Other Toys: Aircraft, cars, electronics
shame you cant change the sat nag ladys voice
SPW is offline
#20 Old 04-06-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
Jeff - on the 2.5, you should have the options to fade, mute, etc. - want to say it was included in the 01/11 telematics update. I'll go poke in the '55 tomorrow - it's a bit late tonight!
UK-C200 is offline
