Oil Drain Plug Crush Ring/Gasket/Washer Question - Mercedes Benz SLK Forum
  • 1 Post By sam8white
#1 Old 03-29-2012
Vehicle: 2006 SLK280
Hi I recently purchased a 06 SLK280. I am going to do my first oil change soon. I am trying to source the oil drain plug gasket/washer/crush ring. As I understand it many of you suggest going to a Mercedes dealer to get the proper ring.
a) Does anyone have a link for a proper ring that can be used in supplement to the Mercedes dealer ring?
b) or if you have a link/part number to an OEM crush ring? Is there a place I can get them online?
c) Also, have any of you used plastic ring/washers instead of the copper ones. I have always found they provide a better seal.
Any suggestions comments etc are much appreciated.
Thanks in advance
lastchild01 is offline
#2 Old 03-29-2012
Vehicle: 2015 Ford Focus ST
Chats: 2
Use the copper ones, and get them from Autozone or Advanced Auto Parts. 3 dollars buys you 3 of them.
13mm I think. Maybe it's 14mm, I can never remember.
I never liked the nylon ones. Always seemed too flimsy
thirteendog is offline
#3 Old 03-29-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
All of the online parts houses offer the sealing ring for about 20 cents. Most of them offer free shipping over $50, so buy a handful of them with your next order.
Len
Len
1999 E300D 215,000 miles
sokoloff is offline
#4 Old 03-29-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
Len
My dealer sells 'em for a buck, and gives me a cup of coffee as well. ;-)
UK-C200 is offline
#5 Old 03-29-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Are you going to drain from the pan vs siphon? Or is it already leaking?
FUN 4 2
Der Flieger is offline
#6 Old 03-29-2012
Its funny you said that. Actually I bought the car and after doing an inspection (once back in Canada, as I imported it from the States) I realised it had a slow leak. I was worried and took it to my mechanic. He said it was as if the washer used was improper or was reused when it shouldn't have been. Its a slow leak, but still a leak. So now that the car is registered and plated, I am looking to replace the front pads and do a full oil change.
I'm thinking about using AMSOIL or Mobil1, a MANN filter or Hengst filter, the crush ring (washer/gasket) from Mercedes (for $1.50 Canadian - what a rip off :P) and getting Akebono front brake pads as they have worn down.
I am travelling to the US in a week (Easter weekend) and I plan to send all of this to my relatives. I still haven't found a site that sells the oil online so I cant send it to their house.
I know this is changing the theme of the thread slightly, but any recommendations on oil? and where can I get it online in the US for cheap?
#7 Old 03-29-2012
Quoted: 123 Post(s)
I think you'll find most here are using Mobil 1 (5 or 0W40). I assume you're flying back and forth...or you'd carry it back yourself. I think you'll have issues "shipping" oil. What about a day trip to Buffalo?
FUN 4 2
#8 Old 03-29-2012
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
As Der Flieger has said. I would recomend Mobil 1 0W-40 European Car Formula. Around here it is available at WalMart for $6.50/qt. I have also seen on this forum where Pep Boys has it as well. I also looked on line and it was always cheaper locally. There is a 5W-40 Formula M (Not ESP) as well. The key is that it meets M-B Spec 229.5 (Mercedes-Benz Approved Oil Specifications) You should have an M272 engine, same as mine.
I have seen the crush washers on eBay, and the oil filters as well. I usually get them both at the dealer for less than $20. I use the Mann HU718/5x, and eBay has the filters at $10-$12 or so.
My dealer's parts department has been great at matching prices I have found elsewhere, so I usually give them the first chance at a part.
REB_TN_06 is offline
#9 Old 03-30-2012
Chats: 2
Count yourself lucky that you live in Chattanooga.
#10 Old 03-30-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
As opposed to Red Bank or Soddy Daisy? ;-)
UK-C200 is offline
#11 Old 03-30-2012
Chats: 2
As opposed to Nashville
#12 Old 03-30-2012
Thanks for all the awesome responses.
So far I ended up buying the washer at a Mercedes dealership in TO for 1.50 CAN and the official wear sensor (just in case I need it) for 14.50 CAN.
I will be purchasing the front pads, oil filter remover, filter itself (MANN) off amazon. Still on the look out for oil though ... 6.50 a quart is amazing, I wonder if It can be had for that price online somewhere?
@Der Flieger: I will actually be driving over to the states so no problem bringing things back ...
#13 Old 03-30-2012
REB_TN_06's Avatar
The vast and varied depth on knowledge on this forum never ceases to amaze me !
#14 Old 03-30-2012
Backpacker85's Avatar
Vehicle: 1999 SLK230 Sport
Oh, I don't know......I was working in Soddy and living in Hixson when I bought my SLK (in Dickson). But to be fair to all, I spent some time in St. Francisville back in the 80's as well.
Backpacker85 is offline
#15 Old 03-30-2012
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
The Akebono front brake pads i got for my 07 350 came with wear sensor as part of the pad kit. Check out Napa Auto Parts when in USA for the Akebono front pad kit for around $100 US if you have the Sport Package.
Gbarringer100 is offline
#16 Old 09-10-2016
Terentius55's Avatar
Vehicle: Mercedes 2005 SLK 55 AMG Gone but never forgotten(Formerly 2006 SLK 350)
Other Toys: 2010 Yamaha XJN Streetfighter (R6 Headers/SP Sports Can & Air Filter + Iridium Plugs) Renault Captur
Quoted: 261 Post(s)
I'm wanting to do an oil change on my 55 AMG. Can anyone tell me what the exact size of the "per Crush Washer's" are for the R171 55 AMG sump pan? There are 2 by the way, and I can get 10 for about 2.99 on fleabay if I have the size? Many thanks...
* K&N Air Filters
* X-Pipe
* 8.5 & 9.5 x 18" Black Rims
* Smoked Rear Lights
* Shorty Antenna
* Carbon Dash
* G - Paddles
* DRL's
* Speed Restrictor 'Taken Off'
Chrome indicator bulbs/LED number plate bulbs/MB 'SL' Side fins/5.5 Badges/Carbon wrap C-Pillars
Terentius55 is offline
#17 Old 09-10-2016
Vehicle: 2012 Black AMG55
Other Toys: 1930 Rumely 6 pulling tractor, Swift Formula, Crossle Formula, Malibu Skier, 28 Dodge
Quoted: 17 Post(s)
It's a 14mm. (1.50 thread plug)
Available at your local Carquest or Advance auto parts store in US low as .79
Sent from my SM-G900R4 using Tapatalk
Terentius55 likes this.
sam8white is offline
The Following User Says Thank You to sam8white For This Useful Post:
Do you perform your own oil changes? Sulley007 General Discussion 160 03-18-2014 07:32 AM
Oil pan drain plug leaking. poinde SLK R171 Class DIY 10 06-30-2011 04:04 PM
Blackstone Lab oil report - 2005 SLK350 fgwinn SLK R171 General Discussion 12 08-10-2009 06:11 PM
