Related question to the thread about tire pressures - Mercedes Benz SLK Forum
  • 1 Post By JonB
  • 1 Post By GeeJay
#1 Old 03-24-2012
Vehicle: 2012 SLK350
I can understand the confusion about the recommended tire pressures.
On all prior cars, I've always used the recommended cold pressures on the packard on the driver's side door panel. Now on my new 2012, the inside of the gas cap also has recommended pressures but it has two options: normal load, and max load.
It so happens the pressures on door placard are the same as the max load on the gas cap. So which which should I use? The max load pressures (which are the same on the gas cap and door placard), the the normal load pressures on the gas cap (the normal pressures are lower).
No idea why they would create this confusion. This is an SLK Roadster, which most of the time will only have one person in it.
Help! Thanks.....
ucla1981 is offline
#2 Old 03-24-2012
I would inflate it to normal load unless you have lots of stuff packed in the rear (e.g., traveling). Check the plaque on the driver-side door jamb. Mine (R171) states combined weight of driver and passenger should not exceed 525 lbs.
#3 Old 03-24-2012
would be surprised if "full load" would be very much on a two seater. Unless you fill the trunk with bars of gold
Der Flieger likes this.
JonB is offline
#4 Old 03-24-2012
Thanks for that input. Yes when 90% of the time there is only 1 person in the car; and you are right, the probability of me loading 300 lbs of gold bars in that small trunk, well, seems stupid to have two different tire recommendations. The difference between the 2 recommendations is fairly significant. I will probably go with the "normal" but add a couple extra lbs, which I tend to do anyway....
ucla1981 is offline
#5 Old 03-24-2012
during my many years of motoring we were always taught to inflate a bit more for long distance faster driving. Not sure if that has any validity especially with modern tyres. I keep mine at the normal pressure all the time.
JonB is offline
#6 Old 03-24-2012
Vehicle: 07SLK350
Under inflated tend to over heat tires may be due to air space not filled. Over inflated subjected to wear and tear much faster. But having a couple of psi over and inder will not make much different. Get digital tire gauge and not rely on dealers station.
QSHIP is offline
#7 Old 03-24-2012
I use an ancient Dunlop pop out rod guage. Its spot on every time.
JonB is offline
#8 Old 03-24-2012
Yeah I always check my pressures,. manually. I plan on inflating them a couple pounds over the "normal" load recommendation on the gas panel. That is lower than tha "full load" pressures on the gas cap and door placard. I think I'll be good with that. Btw......I love my SLK350. Best car I've ever had....
ucla1981 is offline
#9 Old 03-24-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Jon, glad to hear your pop out guage still working consistently.
FUN 4 2
Der Flieger is offline
#10 Old 03-25-2012
The tube it fits in is dented and tatty but the guage is great. I have a digital one that is erratic and untrustworthy. The dial guage on my compressor tank is accurate but Its too much trouble to drag it out to the car just to check the pressures.
JonB is offline
#11 Old 03-25-2012
GeeJay's Avatar
Chats: 91
Quoted: 70 Post(s)
Keep a careful eye on tyre wear, a tread depth guage is just as handy as a tyre pressure guage. Ideally the tread should be the same depth across the tyre. In practice it doesn't always work out like that. It's not unusual for SLK rears to wear a bit quicker on the inside due to a fair bit of negative camber in the back end. On our car the fronts were very even and the rears were not too bad last times they were changed.
Classically, if the tyre is over-inflated, the centre tread area will wear more quickly that the outer areas. The other way around if under-inflated.
If you keep a log of pressures and tread wear, you should home in on the right pressure for you and your tyres.
GeeJay is offline
#12 Old 03-25-2012
GeeJay's Avatar
Chats: 91
Quoted: 70 Post(s)
Maybe you should go and see the doctor? He probably has some cream for that
JonB likes this.
GeeJay is offline
SLK55 Tire Change Question, help effusion_01 Tires, Wheels, Brakes & Suspension 14 01-15-2011 12:19 AM
Tire Pressure Question Medescape Tires, Wheels, Brakes & Suspension 5 06-26-2010 06:02 PM
Tire Pressures piperkid SLK R171 General Discussion 12 06-22-2010 11:25 AM
Rear tire sizes & fitment question?? Catchmefucan Tires, Wheels, Brakes & Suspension 12 01-31-2010 05:27 PM
spare tire question Brian_74 Tires, Wheels, Brakes & Suspension 23 05-22-2009 02:58 PM
