Confused about tire pressure - Mercedes Benz SLK Forum
#1 Old 03-22-2012
Phil.UK's Avatar
Vehicle: SLK 350
Other Toys: C250 CDi AMG Sport Coupe
Hello everyone,
been to my local MB dealer today and while I was talking to one of their mechanics I thought it's a good Idea to ask them to check fluid levels and tire pressure which they promptly did but when the guy returned he said the tire pressure were too low (35psi) on all four wheels. He said MB would recommend 39 psi on all four tires
This confuses me because the sticker inside the petrol flap suggests otherwise
perhaps someone can shed a light on this
thanks
Phil
Phil.UK is offline
#2 Old 03-22-2012
Quoted: 6570 Post(s)
they are always wrong and always adjust mine even after i drove 30 mins to their shop! just check it cold and put what the plate by the door recommends
#3 Old 03-22-2012
Anyone aware of any change in the cold tire pressure? What is it for the R172?
39psi may be for a warmed-up tire (cold tire pressure + 4 psi).
#4 Old 03-22-2012
Phil.UK's Avatar
Vehicle: SLK 350
R171,and Yes I'm aware of that. The car stood for about two hours.is that enough for the tires to cool down? What I don't understand is why a Mb mechanic would recommend 39 psi and inflate the tires to 39 when it is clearly stated that the pressure should be between 34- psi 36
Phil
Phil.UK is offline
#5 Old 03-22-2012
they all have their own ideas on what to set it at. 3 hours is what i usually wait or first thing in the morning
#6 Old 03-22-2012
and if they are nitrogen, that's another story!
#7 Old 03-22-2012
Vehicle: 2006 SLK280 (Mars Red)
Other Toys: 1999 Harley Fatboy (FLSTF)
Chats: 3
From Continental Tires company website: (for ppl with continental tires)
The air pressure listed on the side of your tire is NOT the correct air pressure for your vehicle. That number is the maximum air pressure for the tire.
The correct tire pressure can be found in the following places:
  • in the car's owner manual
  • gas tank lid
  • driver's side door's edge
  • door post
When checking and adjusting tire pressure, the following should be kept in mind:
  • Check the air pressure when the tire is cold - tires become hot even after driving just a mile. If you must drive to add air, check your air pressure before you leave. Air pressure changes 1-2 pounds for every 10 degrees of temperature change. Air pressure goes up in warm weather and down in cold weather.
  • Tire pressure must be the same on the tires of each axle, but may be different on the front and rear axle.
Enjoy,
Dave
FLSTF is offline
The Following 3 Users Say Thank You to FLSTF For This Useful Post:
#8 Old 03-23-2012
Vehicle: 07SLK350
Get a better tire gauge pressure and check it yourself and follow what is says on the sticker. What is good about nitrogen is you don't to check your tires more often because it has bigger molecule and the pressure stay thesame longer than air. The life of the tires last longer since it don't over heat.
QSHIP is offline
The Following User Says Thank You to QSHIP For This Useful Post:
#9 Old 03-23-2012
Vehicle: Late 2016 SLC 300 Polar White
Quoted: 26 Post(s)
OMG!
Glad this subject has come up! The sticker on our car has a guide of 31PSI on the front and 33PSI on the rears.
I making a quantum leap with the following and supposed MB approach, when I made inquires about shocks and pads with the distributor about 6 months ago, I got the usual type of response which was 'we rather not fit the sought after (item*) because' .......blah, blah. In this instance it was stated that all the additional extras added to the standard car would have been put into the calculation to set the height of the car!!
If that is true then I would have to assume that in addition to the tire type the tire pressures for each and every single SLK will have it's own specific tire pressure. Hence the various stickers indicators on each car. So it may be possible that the PSI of the initial inquire could be 39 PSI, particularly if the spec of the car has been changed over time.
Seyley is offline
#10 Old 03-23-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
That's laughable... I would imagine the spec'd tire pressure will take care of the range from ZFW (ie the empty weight of the car) up to the GVW (maximum load the car is rated for...plus some...cuz they ARE engineers).
FUN 4 2
Der Flieger is offline
#11 Old 03-24-2012
Originally Posted by Phil.UK View Post
Hello everyone,
thanks
Phil
39 psi is far too high. Be guided by the sticker inside the fuel filler flap
JonB is offline
The Following User Says Thank You to JonB For This Useful Post:
How do you know if your car has tire pressure sensors or not? sdshah3 General Discussion 17 02-07-2013 04:48 PM
Tire Pressure Monitor Questions Gregg General Discussion 3 11-01-2010 09:25 PM
Tire Pressure Question Medescape Tires, Wheels, Brakes & Suspension 5 06-26-2010 06:02 PM
Tire pressure sensor Alec SLK R171 General Discussion 7 08-27-2009 07:58 AM
Tire Pressure Monitor question katsfarm1 SLK R171 General Discussion 6 05-17-2009 02:23 PM
