cold tire pressure & tempreture - Mercedes Benz SLK Forum
#1 Old 03-14-2012
Vehicle: 2010 SLK 300, AMG Sport Pkg
Quoted: 25 Post(s)
I know tire pressure should be checked "cold".
but should there be any adjustment for ambient temperature?
manual says front 32psi rear 35psi
I set the pressure correctly at a colder ambient and looking at the dash pressure reading ( after driving 100 yards) fronts at 38 and rear at 40. ambient was about 20F higher from when I set them.
bobl is offline
#2 Old 03-15-2012
If you check tyres warm they will always be higher. I think the label inside the petrol flaps tells you by how much.
Just looked + 4 psi
JonB is offline
#3 Old 03-15-2012
Chats: 2
Quoted: 13 Post(s)
bobl, "cold" is "ambient". How much time had elapsed from your setting the pressure 'til you drove "100yds" and the ambient temp was 20* higher? When I check and adjust t/p(as needed), I do it just before I start my drive. Also, since apparently you have TPMS, did you compare the dash pressure reading to whatever gauge you used to set the pressure?
Think outside the box!
Galo is offline
#4 Old 03-15-2012
Vehicle: 07SLK350
is nitrogren bettter than regular air since race cars use this?
QSHIP is offline
#5 Old 03-15-2012
Chats: 2
Quoted: 13 Post(s)
Is it better? Well, if you have easy access to it, it seems to be, but since it isn't available from, say, your home compressor, imo, it isn't worth "switching".
Galo is offline
#6 Old 03-15-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
PV=nRT
as Temp increases so does Pressure...whether it's the air you're pumping into them (and the compressed air off a hose will be slightly warmer) or after you've warmed them up a bit (or a lot)
FUN 4 2
Der Flieger is offline
The Following User Says Thank You to Der Flieger For This Useful Post:
#7 Old 03-15-2012
Chats: 2
Quoted: 13 Post(s)
Originally Posted by Der Flieger View Post
PV=nRT
JJ, if that's aimed at my response, exactly That's why I suggested checking, and adjusting if necessary, just before the driving starts.
I take it you've gotten Kismet out of hibernation
Galo is offline
#8 Old 03-15-2012
Sadly Gregg has passed away
Gregg's Avatar
Vehicle: 2009 SLK 350
Chats: 5
Quoted: 17 Post(s)
PV=nRT
You gotta love a guy who knows his math and isn't afraid to use it! Atta Boy John!
Gregg is offline
#9 Old 03-15-2012
Quoted: 25 Post(s)
the tpms pressure was about the same (maybe 1 psi higher) the day i set the pressure and i drove the same distance,
it was several days days later i noticed the increase at about the same distance
bobl is offline
#10 Old 03-15-2012
Quoted: 25 Post(s)
PV=nRT
i understand that. an increase of 5 psi over a 20F increase in temp seems a lot. the pressure i saw seem to be what i see after driving an hour. i often check the pressure using theTPMS on a trip
bobl is offline
#11 Old 03-16-2012
Just walk round and kick them. If they feel hard get in and drive
JonB is offline
How do you know if your car has tire pressure sensors or not? sdshah3 General Discussion 17 02-07-2013 04:48 PM
Tire Pressure Monitor Questions Gregg General Discussion 3 11-01-2010 09:25 PM
Tire Pressure Question Medescape Tires, Wheels, Brakes & Suspension 5 06-26-2010 06:02 PM
New Tire surprise, recommendations ASAP Brian_74 Tires, Wheels, Brakes & Suspension 54 09-28-2009 12:09 AM
Tire pressure sensor Alec SLK R171 General Discussion 7 08-27-2009 07:58 AM
