2006 Transmission slipping just now and then - Mercedes Benz SLK Forum
#1 Old 10-29-2011
Vehicle: 2006 SLK280
Other Toys: C230 Komp & Old Corvette
My transmission started doing this a couple of weeks ago. Here is what is does, while driving along it will start slipping and when I stop, put it in park, then back in drive, I only get first gear with no slipping....If I turn the car off, and restart it, everything is fine. I get no check engine or any kind of messages.
It did this twice a couple of weeks ago and again yesterday. The only thing in commom on these days was the outside temperature was considerably lower than the day before.
Anyone have these kind of issues? Thanks, cheers!
Newman is offline
#2 Old 10-29-2011
pete7485's Avatar
Vehicle: 2005 SLK350
Have you had any trans service done? what is the mileage on the car?
pete7485 is offline
#3 Old 10-29-2011
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Hi Newman, welcome from NE England. How about filling in your details (via the User CP button) - it makes it a lot easier for people to answer your questions if they know what car (and country) you are talking about. JB will be along shortly to read the riot act to you!!
Woolly is offline
#4 Old 10-29-2011
Chats: 2
Quoted: 13 Post(s)
Newman, get the car to an MB dealer and have them run a diagnosis on the trans. My guess is there will be a fault code 2767, Faulty Speed Sensor. I hope you have, at least, some kind of a drive train warranty...and do as Woolly suggests; the more we know about your car & location, the better
Think outside the box!
Galo is offline
The Following User Says Thank You to Galo For This Useful Post:
#5 Old 10-29-2011
Little over 60,000 miles on it, live in Dallas TX.
Newman is offline
#6 Old 10-29-2011
Quoted: 6546 Post(s)
update your profile please:
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
Thank you,
Founding Member/Moderator
#7 Old 10-29-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
I'm with Galo here - find someone - either a dealer or an Indy - and have them hook it up to Star Diag and do a TCU diagnostic. Don't waste you time with anyone using some other tool, Star Diag is key...
UK-C200 is offline
#8 Old 10-29-2011
As Galo and UK-C200 pointed out: need the correct diagnostic tool. This link may help: https://www.slkworld.com/slk-r171-gen...-behavior.html
Sounds like faulty sensor in the conductor plate (transmission).
#9 Old 10-30-2011
pete7485's Avatar
Going with a diagnostic check sounds like the way to go
On an older vehicle i had the slipping was due to low trans fluid,good luck with this
pete7485 is offline
#10 Old 10-30-2011
Can anyone tell me how to check the trans fluid level? 2006 SKL280. Thanks!
Newman is offline
#11 Old 10-30-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
It's a sealed system - electronic sensors only. See about post, as far as I know, Star Diag is the only system able to properly diagnose the 7g box.
UK-C200 is offline
