Trunk won't latch? - Mercedes Benz SLK Forum
#1 Old 10-06-2011
Vehicle: Silver '99 Sport
Trunk won't latch?
I test drove an R170 last night that I might buy but it had a problem with the trunk/top. I know that's a common problem area on these cars but I didn't find this particular version of it in the search.
Before there was a problem... I opened the trunk just to have a look, see things are in check, spare tire, water, etc, and closed the trunk.
Then I went for a drive drive and tried to bring the top down but the light blinked instead. So I stopped the car, put in neutral, applied the parking brake and still wouldn't convert. Then I remembered the divider to limit the storage area, and opened the trunk and pulled it out. Then the trunk wouldn't latch closed. I tried harder, then slammed it and it seemed like it wasn't even close to latching. Ideas?
foilman is offline
#2 Old 10-06-2011
Quoted: 6547 Post(s)
car must be completely stopped unless u have the smarttop module. there is a sensor in that cover that must be worn or broken
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
Thank you,
Founding Member/Moderator
#3 Old 10-07-2011
I'm not so sure about that... it seems the trunk should still close. The top never moved from the up position.
foilman is offline
#4 Old 10-07-2011
so your issue is with trunk or roof or both?
update your location and model please to start. thanks
Thank you,
#5 Old 10-08-2011
toph2o's Avatar
Vehicle: 2005 SLK 350
Other Toys: Nitro 189 Sport boat
I see you're here in Atlanta, if you're looking to buy an r170, I'm actually getting mine detailed today to take pictures and put it up for sale... it's got the SmartTop module already, too.
toph2o is offline
#6 Old 10-08-2011
you gonna buy another toph20?
#7 Old 10-08-2011
toph2o's Avatar
For sure, thinking hard about looking for a SLK 55.
toph2o is offline
#8 Old 10-08-2011
Most excellent choice!
#9 Old 10-08-2011
2x on an excellent consideration for next vehicle.
Trunk Rattle Solution! B55 SLK R171 General Discussion 100 02-19-2017 07:54 AM
Loose trunk lid latch post atebit SLK R170 General Discussion 11 09-30-2012 04:03 PM
Trunk lid latch bolts? tcrankwa SLK R170 General Discussion 5 10-22-2010 11:08 AM
Dome light will not turn off / trunk latch related? new2slk SLK R170 General Discussion 9 01-11-2010 08:08 AM
