05 SLK Cupholder Replacement. - Mercedes Benz SLK Forum
#1 Old 09-05-2011
Vehicle: Diamond Silver 05 SLK350
Other Toys: BLK 05 VW PASSAT
I am trying to find out where I can find a cupholder replacement or if there is a way to disassemble the one I have to get it cleaned up. It seems to be sticking pretty badly and I am wanting to have that resolved. Any info is great. Thanks.
goober19 is offline
#2 Old 09-05-2011
Quoted: 6539 Post(s)
Do a search top right my friend. you can even get a cubby from slkstore.com
#3 Old 09-05-2011
http://www.slkstore.com/home.php?cat=271
#4 Old 09-05-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
Welcome, and easiest way is to remove it - loads of instructions here on the site, completely submerge it in warm, soapy water, and open/close it a few times.
Take it out, rinse if off well, let it dry, and lubricate the coil spring, hinges, and gears with white lithium grease.
Or replace it with the cubby! :-)
UK-C200 is offline
#5 Old 09-05-2011
SLKStore
Guest
Posts: n/a
Chats:
Quoted: Post(s)
We do carry the factory replacement Mercedes-Benz cup holder. Let us know if we can assist.
#6 Old 09-05-2011
As John suggested, it can be removed. When the cupholder is in the open state, you will notice 2 small round rubber covers (one on each side). The rubber cover can be removed using the fingers or small flat head screwdriver. This will then reveal two Torx screws that need to be removed. Thereafter, the cupholder assembly slides out. I don't think you need to disassemble the cupholder, just follow John's suggestions.
#7 Old 09-06-2011
Thank you all for you help on the subject. I got it out, washed it and waiting for it to dry. thanks!
goober19 is offline
#8 Old 09-06-2011
-1-
Don - Founding Member #4
-1-'s Avatar
That was a quick, easy, cost effective fix.
-1- is offline
#9 Old 09-06-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
Don't forget to lube it up when it's dry - if you have it in your hands, upside down, you will see the coil spring - open it, and kinda run your finger along the uncoiling spring with a light coating of white lithium grease. You'll also be able to see the hinge points and gear mechanism at the same time...
As with most things - a little goes a long way!
UK-C200 is offline
SLK 350 parts wanted: cupholder Delation125 Where to get R171 SLK Items 8 06-10-2010 04:53 AM
Piecha Mercedes SLK R171 Performance RS Cold Shot General Modifications R171 11 05-05-2010 02:56 PM
SLKWorld retreat 9/25-9/27, list of reservations made etyu SLK World Annual Retreat 92 09-24-2009 09:55 PM
Image of the SLK 2008 Facelift herve431 SLK R171 General Discussion 116 01-04-2008 04:57 PM
