2002 SLK200 Auto gear lever locked...help! - Mercedes Benz SLK Forum
#1 Old 08-02-2011
My Wife has the above, an 2002 SLK200 with the auto box.
This morning the gear lever wouldn't shift out of park. No matter what we tried. I can't hear any solenoid operating around the gearstick when the brake pedal is depressed either. The brake lights are also operating normally. I understand that the locking solenoid operates from the brake light switch? If so it must have two circuits, one for the lights and another for the solenoid? Is this correct?
Is this a common problem?
Alex.
alex.mc is offline
#2 Old 08-02-2011
Quoted: 6496 Post(s)
Alex,
Thank you,
Founding Member/Moderator
#3 Old 08-03-2011
Fixed!
I spoke with Mercedes, and got a helpful parts guy. The brake light switch was in stock and reasonably priced at Ł11.52! It had two banks of connectors, and when I stripped back the lower dashboard to reveal the switch, there were two seperate connectors.
Replacing the switch cured the problem, and the gear lever releases properly now as it should.
Also, there is a small semi-circular flap at the bottom end of the gate for the gear lever. Using the allen key tool in the tool-kit, or a suitable rod of screwdriver, the gearstick can be manually released for moving the car.
As usual under dashboard jobs are a bit of a squeeze, but it took 45 mins and was ultimately very cheap to fix!
alex.mc is offline
#4 Old 08-03-2011
Great!
Thank you,
#5 Old 08-03-2011
richard_leeds's Avatar
Vehicle: 05 350 Auto
Other Toys: Volvo XC60, Panda 4x4, mountain bike, kite, toddler
Chats: 4
Quoted: 8 Post(s)
Glad you got it sorted.
In my experience auto boxes usually have a manual release for this event, it'll be described in the manual.
For the record in case anyone stumbles across this in future -On the R171, the process is to pull up the gear stick gaiter and press a yellow button. Best look at the manual for of pics. No tools needed.
It'd be annoying to be stuck in an R170 knowing how to release it but needing a tool to access the release!
richard_leeds is offline
The Following User Says Thank You to richard_leeds For This Useful Post:
#6 Old 03-09-2014
Vehicle: SLK320
Other Toys: SLK230
2001 SLK320 Auto gear lever locked...help
I have replaced the brake light switch under dash. It's still stuck in park. Any other suggestions??
brawls is offline
SLK200 Manual or Auto PaulMark SLK R172 General Discussion 9 06-08-2011 05:00 PM
Worn gear lever hertfordshire1 AMGs 1 02-09-2010 07:51 AM
Rear Break Lever problems - Can you do that test for me? Daniele SLK R171 General Discussion 75 11-15-2008 06:23 PM
Gear lever leather cover.. mazeka SLK R171 General Discussion 8 08-04-2008 01:04 PM
Gear Lever Badge KTownAMG General Discussion 8 06-23-2008 01:36 PM
