Glove Box and Center Console Storage Locked - SLK280 - Mercedes Benz SLK Forum
#1 Old 07-23-2011
Vehicle: 2006 Slk280
Glove Box and Center Consol storage are both locked and won't open. I've read all the threads on this subject and tried it all. Pressed against left side of glove box while internally locking and unlocking (many times), sprayed WD40 into handled latch, reset remotes to factory setting...nothing works. The Center Console also won't open. They both occured at the same time. Is it a fuse problem??? None of the threads here worked, can anyone share some light on this subject. Also, does anyone know what schedule C entails?
Thanks so much.
Bob Wilson is offline
#2 Old 07-23-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
Hey Bob - try this. Sit in the car, and lock the doors with the keyfob in your hand. Unlock with the keyfob, and check to see if they will open. You can actually "hear/feel" the lock on the center console engage/disengage if you have your arm resting on it.
UK-C200 is offline
#3 Old 07-23-2011
The center console and glove box lock/unlock is controlled by the remote key as John stated.
#4 Old 07-24-2011
Quoted: 6490 Post(s)
Bob,
Schedule C. Have you a maintenance manual? schedule c refers to the time it takes to complete and usually matches the maitenance around the 39000 mile maintenance schedule. do a 'search' top right for it also.
Thank you,
Founding Member/Moderator
#5 Old 07-24-2011
Thanks so much John, I've tried sitting in the car and locking and unlocking with the keyfob...as the manual states. Wierd problem here. I have a good Mercedes Mechanic who will probably figure it out...I'll post the results when I get it to him...thanks again.
The Following User Says Thank You to Bob Wilson For This Useful Post:
#6 Old 07-24-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
Please do - interested to see what he finds. Normally the locks don't both fail at the same time, so I'd still expect you to be able to open one or the other!
UK-C200 is offline
#7 Old 04-08-2012
Vehicle: 2007 slk 55 AMG
Bummer that Bob never replied-- I'm having this happen intermittently in my 55 (both console and glove boxes remain locked).
I've found that pressing lock, immediately followed by two quick unlocks from the fob will get the console/glove boxes to unlock. I think I might have a failing solenoid or the hose may be coming loose.
juiceyman is offline
#8 Old 04-08-2012
Chats: 2
Quoted: 13 Post(s)
Don't know about the locking problem, but go here, http://www.mbusa.com/vcm/MB/DigitalA...ls_non_amg.pdf , find the mileage/years on the car and see what is stated as needed.
Think outside the box!
Galo is offline
#9 Old 04-26-2012
John and juiceyman,
Sorry it took sooo long on this issue, life happens. I've had it in 2 shops and finally found a good SLK mechanic that found the problem. The fuse to the "Signal acquisition Module" had blown. Not sure which fuse box but I believe it's the one in the trunk area. Now both the center console and glove box function normally. Thanks for your input.
Bob
The Following 3 Users Say Thank You to Bob Wilson For This Useful Post:
98,99,00,01... Entire Center Console for sale... ucmagic Where to get R170 SLK Items 3 05-13-2011 09:12 PM
Center console removal BikerDrew SLK R170 General Discussion 3 03-06-2007 11:42 PM
