Car Show Help - Mercedes Benz SLK Forum
#1 Old 07-01-2011
Prof Wendy's Avatar
Vehicle: '98 Red SLK 230
Other Toys: BMW X5
Red face Car Show Help
Just for fun, I've decided to take Ruby to my hometown for a visit this weekend to introduce her to the family and enter her in our small-town car show. This is rural Midwest where Chevy and NASCAR rule,and women aren't expected to know anything about cars.
I do know cars, but I'm new to the Mercedes world so I could use some help. Fill my head with factoids I can share!
I figure I can point out the supercharger, but I'm not sure I can really explain how it differs from turbo, etc. Anything else I should be prepared to answer?
I'm a car show virgin, by the way. Attended many as a spectator. First time entering. Even if it's just small-town stuff, I don't want to look ridiculous!
Prof Wendy is offline
#2 Old 07-01-2011
Quoted: 6490 Post(s)
going to move this thread to general discussion
#3 Old 07-01-2011
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
If you post the vin number I will get you the Data Card for you SLK. This will show what was on the car when it was built.
Gbarringer100 is offline
#4 Old 07-01-2011
I suppose the easiest way to tell the difference between a supercharger and a turbo, is that a supercharger is mechanically driven and runs all the time the engine is running, whereas a turbo is driven by exhaust gasses and only cuts in at certain engine revs.
No doubt someone will explain it better
JonB is offline
#5 Old 07-01-2011
Vehicle: 2015 Ford Focus ST
Chats: 2
Superchargers blow air into the engine. Turbo's suck air through the engine.
SLK was the first of the modern day "hard top" Verts
Personally I was just sit back and look pretty. It's also okay to say "I don't know." But try to remember what they asked so you can look it up later.
thirteendog is offline
#6 Old 07-01-2011
Sadly Gregg has passed away
Gregg's Avatar
Vehicle: 2009 SLK 350
Chats: 5
Quoted: 17 Post(s)
Went to a show a few yealrs ago and saw a SLK with the hood up and roof open to midpoint. Very neat way to show off the car. Now I own one! The SLK pretty much speaks for itself.
Can't remember if they used a "John's Broomstick" device to keep the roof open to midpoint. If you search "John's Broomstick" you will see what I mean.
Gregg is offline
#7 Old 07-01-2011
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
No need - spot on explanation.
Nup, see Jon's explanation above. Both compress the charge air, but by different methods. A turbo uses the energy from the exhaust gas to spin the compressor, energy which otherwise would be wasted, whereas as Jon says, a supercharger uses the engine to spin the compressor, thus sapping some of the energy available from the engine. The disadvantage of a turbo is they are less efficient at lower revs, and suddenly 'kick in' when the exhaust gasses start flowing at a higher rate at higher engine revs. This leads to a phenomena called 'turbo lag' which used to be a major problem on early implementation, whereas supercharged engines give a smooth power delivery across the rev range,
Woolly is offline
#8 Old 07-01-2011
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Now that is spot on!
SLKs also have an independent rear suspension and high camber front end (turn the wheels to full lock to show it off and the tread) which gives the car improved stability and a very small turning radius at low speeds.
I'd put the top down and open the trunk...let them NASCAR boys figure out how you did that!
You could also wear a pair of heels with your jeans, and they won't ask questions about your car - just if you're free for dinner!
Der Flieger is offline
#9 Old 07-02-2011
Prof Wendy's Avatar
Other Toys: BMW X5
WDBKK47F3WF065126
Thanks!
#10 Old 07-02-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
WDBKK47F3WF065126
Thanks!
Here ya go - unfortunately, the early R170's don't have a lot of detail in EPC. Paint and interior color codes are correct, but incorrectly described on the datacard.
UK-C200 is offline
#11 Old 07-02-2011
where is it John?
#12 Old 07-02-2011
Quoted: 99 Post(s)
WDBKK47F3WF065126
Thanks!
Here it is, like John said it is a short list.
Chuck
#13 Old 07-04-2011
Vehicle: BMW M3 E46, Mercedes-Benz E250 CGI, Toyota Alphard V6 3.0MZG
Welcome from Wirral, via Malaysia
davidb is offline
Tags
car show, slk 230, supercharger
Garrett Jacobson Motorsports Car Show Pics Todd157k General Discussion 0 11-15-2010 11:55 PM
Press Release: Sonax Car Care coming to DetailersDomain DetailersDomain Caring for your SLK 0 03-09-2010 10:54 PM
6 Car Repairs You Can't Afford to Skip Eduardo General Discussion 7 07-07-2009 02:43 PM
I give you a dedicated thread to the CLK GTR AMG,built to prove AMG's dominance alroumi AMGs 0 05-04-2008 02:17 AM
Exotic Car Meet - Crystal Cove Promendade, Newport Beach, CA B55 SLK R171 General Discussion 6 07-08-2006 05:03 PM
