Coolant Odor? - Mercedes Benz SLK Forum
#1 Old 06-27-2011
Sadly Gregg has passed away
Gregg's Avatar
Vehicle: 2009 SLK 350
Chats: 5
Quoted: 17 Post(s)
Coolant Odor?
I have noticed a very, very slight coolant odor from under the hood after parking Challenge in the garage....usually dissipates within a couple of minutes. Can't smell it when the garage AC is functioning. No drips on the floor or loss of coolant level. Could this be the overflow container venting? Any ideas?
Gregg is offline
#2 Old 06-27-2011
Does the garage have a HVAC system?
#3 Old 06-27-2011
Gregg's Avatar
Chats: 5
Quoted: 17 Post(s)
Yes...it is temp and humidity controlled with a humidistat controlled exhaust fan that function occassionally.....other than the slight coolant odor there is no typical engine smell at all after operating the car.
Gregg is offline
#4 Old 06-27-2011
Chats: 2
Quoted: 13 Post(s)
How about the engine temp; is it "normal"? My Spyder had a coolant smell that eventually went away. One day I was under the car checking for an oil filter leak, and noticed the greenish crust of dried-up coolant from the "Drain hole" of the water pump. The pump was dying and I had to replace it.
Gregg, I think it would be a good idea to get this checked, and soon, just to be safe.
Galo is offline
#5 Old 06-27-2011
Gregg's Avatar
Chats: 5
Quoted: 17 Post(s)
Yep....good idea...I will....thanks! It is very minor and short lived....absolutely no coolant loss detectable.
Gregg is offline
#6 Old 06-28-2011
Chats: 2
Quoted: 13 Post(s)
That sounds just like what was happening to my Spyder. My episode was really very good timing; I had to drain all the coolant anyway, so I installed the new pump AND added all new coolant. "Burping" the sys.(longish story) was a pain, but all was good after.
I hope it's nothing serious.
Think outside the box!
Galo is offline
#7 Old 06-29-2011
Gregg's Avatar
Chats: 5
Quoted: 17 Post(s)
We have been on several short fairly max performance drives and no further odor (knock on wood). Der Fleiger suggested that I might have run over some lost coolant from another vehicle which is entirely possible.
Gregg is offline
#8 Old 06-29-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
Either that or you happened to vent some from the overflow line onto something warm. Given that the temperatures are getting warmer, may just be more expansion than it's used too. I'd personally not worry too much about it, just keep an eye on the overflow container and fluid levels to be safe. Car's pretty good about throwing up warnings if you go over temp.
I'd also suggest mentioning it on your next service just so they 1] take a closer look and 2] you have it documented if it ever develops into anything serious.
UK-C200 is offline
The Following 3 Users Say Thank You to UK-C200 For This Useful Post:
#9 Old 06-29-2011
Chats: 2
Quoted: 13 Post(s)
Gregg, like I stated, the "drain plug" was plugged by the dried-up coolant and the smell went away, BUT, the water pump WAS going out. It won't hurt to have it checked than run the risk of the pump going out and the engine frying. Hell, you might get stuck in Terre Haute !!!
Galo is offline
The Following User Says Thank You to Galo For This Useful Post:
Persistant Coolant Light!! mistergoodpepper SLK R170 General Discussion 35 08-17-2018 11:05 PM
Flushing coolant dukesbb37 SLK R170 General Discussion 5 01-04-2011 09:33 PM
Coolant light type-r SLK R170 General Discussion 15 05-04-2010 09:07 AM
