How to check/change the spark plugs on Slk 350 - Mercedes Benz SLK Forum
#1 Old 06-20-2011
Vehicle: Slk 350
Send a message via Skype™ to Darkic
Hello,
Im new in this forum and a new owner of a slk 350 ,2007.
Ive had th 170 before and i just love the slk cars!
Mt questin is if somebody can post a guide or pictures of how to check/change the spark plugs on a slk 350..
Darkic is offline
#2 Old 06-20-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
It's pretty straightforward, and I thought was covered in the DIY section, but I can't find it at the moment.
Basically 5 years / 100k miles is the recommendation - remove the air cleaner, and prepare to get your hands dirty. Pull the coil covers. It also helps to have a valve wrench to help remove the .plug boots, the last ones (nearest the windscreen) are a pain in the arse to get off..
UK-C200 is offline
#3 Old 06-20-2011
Quoted: 6498 Post(s)
Darkic,
Thank you,
Sergeant-at-Arms/Moderator
#4 Old 06-20-2011
Chats: 2
Quoted: 13 Post(s)
Darkic, have you done plug changes before ? It really is fairly easy, but one must have patience unfastening the plug wires from the coils. I used a small bladed screw driver to free the "clips"... you'll see. Also, I had to use a 15" breaker bar to get the plugs free(those things were tight) . Hopefully you won't need to do that. IF the plugs ARE tight, do not strike the wrench(spanner?) with anything (like a hammer), just use steady "muscle" to get them free.
Good luck.
Galo is offline
#5 Old 06-21-2011
Vehicle: Slk 350
I have changed plugs on many cars before but when i opened the hood on my slk 350 i was just lost.. haha and that they are 12 spark plugs it just confuse me but i will give it a try!
Thank alot for the tips!
Darkic is offline
#6 Old 06-21-2011
here is another tip:
#7 Old 06-21-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
M272 has one plug per cylinder, so you only need 6, unlike the M113, which does have 2 per cylinder for a total of 16.
UK-C200 is offline
#8 Old 06-21-2011
Chats: 2
Quoted: 13 Post(s)
Did I miss 6 when I changed mine... Sorry, I couldn't resist, especially since John had already answered. Most people who haven't changed plugs are a bit nervous, and that's why I asked. It's the air-filter/intake box that is a real pain. Make sure you get the "hoses" off and unclip the "stay" on the back of the box(heavy silver "wire" thingy), then give it a good pull! Be careful putting it back on; it IS a bit tricky(again, you'll see).
My pleasure! I can't remember having a set of original plugs being that tight; darn near pulled a muscle getting the first one out ...after that, the breaker-bar made it a good bit easier.
By the way, where ARE you located?
Take care!
Galo is offline
#9 Old 06-22-2011
Vehicle: Slk 350
Hello again!
I have now been updated my info.. and i put up a picture of the car.
Thanx for the tips.. i was confused of the info a read on the net about 2 sparks/ cylinder thats why i started this thread.
Darkic is offline
#10 Old 06-22-2011
Chats: 2
Quoted: 13 Post(s)
Cool! I guess you're a little too far away for me to drop by and "help" you in person
Enjoy!!!
Galo is offline
#11 Old 06-23-2011
Vehicle: Slk 350
Thanx everybody!
I just got confused when they told me in Mercedes service that the car has 12 spark plugs i culdent understand where the rest 6 was.. Haha
Darkic is offline
#12 Old 06-23-2011
Chats: 2
Quoted: 13 Post(s)
Thanx everybody!
Mercedes service told you this? I think I'd try to locate a new service or make them a wager; If they can't find the other 6 plugs, the next service is free!!!
Take care!
Galo is offline
Video showing how to change spark plugs in SLK 230 bayshield SLK R170 General Discussion 12 05-11-2014 08:45 PM
SLK 350 vs SLK 55 (South Africa) benigma SLK R171 General Discussion 14 10-19-2009 01:34 PM
My Facelift SLK 350 Review. Twisted SLK R171 General Discussion 7 08-06-2008 09:47 AM
