Rear window rubbing with top down - Mercedes Benz SLK Forum
  • 1 Post By etyu
#1 Old 06-19-2011
Vehicle: 2005 SLK 55 AMG
Chats: 4
Hey guys,
It's been awhile since I posted - sorry I've been a stranger.
A month or so ago I started seeing this wear on the passanger side of the rear window and it has now gotten pretty bad. It definitely has something to do with the plastic piece rubbing on something inside the trunk when the top is down but I wasn't able to determine specifically where.
Has anybody else experienced this? Is there an adjustment which can be made to stop the wearing? It looks like I'm going to have to replace the piece too at some point - which looks like it might be a chore. Any experience with this task?
garylight is offline
#2 Old 06-19-2011
nakulan7's Avatar
Vehicle: 08 SLK 55 AMG
Other Toys: Lexus IS250
Chats: 2
Quoted: 33 Post(s)
I have some scratches on the bottom edge. I have ignored it so far but i would be very interested in the changing option at some point.
nakulan7 is offline
#3 Old 06-19-2011
These are not scratches and not caused by rubbing. This plastic trim piece is actually suspended in the inverted position when it is stored in the trunk/boot after the roof is retracted.
MB calls it de-lamination and is a common occurence over time in the SLK as well as the SL's. Replacement is not easy and I've read the procedure many times, and it also needs some new butyl strip, lots of lubricant and skill (chance of leak if not done correctly). There's also the need to make sure the alignment of the rubber seal is correct as it abuts the black trim piece. Without the special tool to hold the roof at 75 degrees, it cannot be done (talked to the technician). Mine has been replaced 2x (left and right) under warranty and each time (as related by the master technician, who is really meticulous) the trim had to be removed, breaking the tabs on the piece and a second new piece has to be used (glad it was done under warranty).
Out-of-warranty, other members have applied 3M Di-Noc with good results. Another member has prepped the black plastic piece, masked and applied clear gloss paint on the same with good results (Do a search).
nikbynight likes this.
#4 Old 06-19-2011
Chats: 4
Thanks for the info Eddy. I could have sworn it must be rubbing but you're right - the way it hangs upside down had me confused. I was thinking it must have been hitting a piece of plastic or something.
I'll have to see how the extended warranty people handle this one
Good to hear from you - I hope all is well out West.
#5 Old 06-19-2011
MB calls it a decorative trim piece and as such some extended warranty may consider this a "cosmetic" piece. No harm in asking/checking, although I would label the piece as upper C-pillar cover as described in MB service manual CD, and avoid any reference to words as "decorative" or "trim".
All is well on the west coast -- no rain, partly cloudy early morning, sunshine, mid- to low-70's, and lower 60's at night, sunset at 8 pm (Pacific DST), top-down weather day and night
Top Seal replacement rear window bcsnave SLK R171 General Discussion 3 06-11-2016 04:19 PM
98 SLK230 Window & Top not working Mike Type R SLK R170 General Discussion 15 06-05-2013 04:28 PM
Window movement when top is put down ToddieDC General Discussion 19 08-01-2009 08:58 PM
