Technical question on engine oil - Mercedes Benz SLK Forum
#1 Old 05-25-2011
This is specific to Mobil1 0W40 but may apply to synthetic oils in general.
How high a temperature can Mobil 1 0W40 withstand and for how long (duration) without losing its effectivity?
I noticed my engine oil temp go up to 127C for perhaps 10 minutes while doing a run at Mount Wilson this past weekend, going up to 3rd gear only with the rpm between 3-5.5K rpm. This got me curious if the synthetic oil would "degrade" at that temperature.
Mobil 1 0W40 data sheet states:
HTHS Viscosity, mPas @ 150C, (ASTM D4683) value is 3.8
Viscosity, cSt (ASTM D445)
@ 40 C, value is 75
@ 100 C, value is 13.5
What does the above mean?
#2 Old 05-25-2011
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Mobil test it at 150degC ( Mobil Data Sheet ), so 127 degC should not be a problem.
Woolly is offline
#3 Old 05-25-2011
What do the values mean?
3.8 at 150C
75 at 40 C
13.5 at 100 C
Edit: found some explanation:
"High-temperature high-shear-rate (HTHS) viscosity is an indicator of a motor oil's resistance to flow in the narrow spaces between rapidly moving parts in fully warmed up engines. The most common test here is ASTM D4683, which simulates the conditions found in an engine's crankshaft and connecting rod bearings, as well as other narrow regions. This measurement has important implications for such factors as engine fuel economy, valvetrain wear and bearing protection."
ACEA Engine Oil Sequences: gasoline and diesel engine oils
A1/B1 Stable, stay-in-grade oil intended for use at extended drain intervals in gasoline engines and car & light van diesel engines specifically designed to be capable of using low friction low viscosity oils with a high temperature / high shear rate viscosity of 2.6 mPa*s for xW/20 and 2.9 to 3.5 mPa.s for all other viscosity grades. These oils are unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
A3/B3 Stable, stay-in-grade oil intended for use in high performance gasoline engines and car & light van diesel engines and/or for extended drain intervals where specified by the engine manufacturer, and/or for year-round use of low viscosity oils, and/or for severe operating conditions as defined by the engine manufacturer.
A3/B4 Stable, stay-in-grade oil intended for use in high performance gasoline and direct injection diesel engines, but also suitable for applications described under A3/B3.
A5/B5 Stable, stay-in-grade oil intended for use at extended drain intervals in high performance gasoline engines and car & light van diesel engines designed to be capable of using low friction low viscosity oils with a High temperature / High shear rate (HTHS) viscosity of 2.9 to 3.5 mPa.s. These oils are unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
#4 Old 05-25-2011
Vehicle: 07SLK350
Once upon a time, I remember during those muscle cars were still on the road I used a straight grade motor oil during the smmer months. so a Mobil 1 with 0w40 viscosity consider a straight grade?
QSHIP is offline
#5 Old 05-25-2011
PropDr's Avatar
Quoted: 18 Post(s)
Books have been written on Different types of viscosity.
In this situation viscosity of oil is its resistance to flow.
Oil has to be thin enough to be picked up by the pump and to get to the furthest component that needs it. Also it needs to flow at sufficient quantity to remove heat from these components.
The thinnest oil that will prevent metal to metal contact at maximum load will do the best job.
As long as the oil film is maintained your hotter oil will remove heat the best.
My Beautiful Black Walkre (Valkyrie)
PropDr is offline
The Following User Says Thank You to PropDr For This Useful Post:
#6 Old 05-25-2011
Vehicle: 2006 SLK 350 Designo (sold)
Other Toys: 2007 GL320CDI
With "straight grade" there's only one number. Like 30W (for your lawn mower). Or maybe 50W (for your Offenhauser).
Pretty obsolete stuff.
lkchris is offline
#7 Old 05-25-2011
Vehicle: 2006 SLK280 (Mars Red)
Other Toys: 1999 Harley Fatboy (FLSTF)
Chats: 3
Eddy -
From what I'm reading here, you're looking at kinematic viscosity measurements.
The lower the number, the faster it flows through the ports inside your engine due to heat.
The higher the number, the slower it travels.
On another note, 60% of your engine cool down is by the fluid in the radiator and that's only on the top half of your engine. The rest is cooled down by your engine oil.
I hope this makes sense.
Enjoy,
Dave
FLSTF is offline
The Following User Says Thank You to FLSTF For This Useful Post:
#8 Old 05-25-2011
Other Toys: 2008 C300
Chats: 15
I'd recommend bobistheoilguy site for crazy in-depth oil talk.
I will say this, you are WISE to use the Mobil 1 0w40. It far surpasses requirements of the major European manufacturers.
The Formula M that some dealers use was engineered to just meet Mercedes spec.
On the oil analysis I have ran, the 0w40 Mobil 1 is MUCH richer in protecting additives than the 5w40 Formula M.
mb911 is offline
The Following User Says Thank You to mb911 For This Useful Post:
#9 Old 05-25-2011
PropDr's Avatar
Quoted: 18 Post(s)
Not only that, it gives you much faster oil flow at start up, especially at low temperatures.
PropDr is offline
#10 Old 05-25-2011
Chats: 2
Quoted: 13 Post(s)
Very good recommendation
Castrol Euro Formula 0W-30 is an excellent oil also(and MB 229.5 rated). Don't be fooled by the "30"; it is almost a "40" and also has a fine additive package.
Eddy, have you had an oil analysis done? If not, you might check-out Blackstone Labs( http://www.blackstone-labs.com/ )...if you have, never mind
Galo is offline
#11 Old 05-25-2011
Chats: 15
I agree...I think I know that oil, and it is good. On paper it doesn't have as many goodies in it than M1 0w40, but there must be hidden things because it performs well in people's cars.
The *only* problem is that for North America, Mercedes tells us to use a 40 weight in anything above something like 80 degrees?
I know the 30w Castrol is very close to a 40, but just by "specs," if still under warranty, one might be careful.
mb911 is offline
#12 Old 05-25-2011
PropDr's Avatar
Quoted: 18 Post(s)
I dont think it is really about the brand but more about the new generation of oils.
I remember the time the first 10 w oils came on the marked, after that the first 5W, now the 0W
Im looking forward to the day a lubricant will be developed that will have the same flow characteristic at minus 50 C as at plus 200 C; almost instant perfect lubrication at startup.
PropDr is offline
#13 Old 05-26-2011
Nope, no oil analysis but have read on other forums specifically with the SLK and the oil analysis was excellent. The comment that struck me was that the oil analysis lab stated it seems the engine was assembled by technicians as if they were wearing white lint free gloves.
#14 Old 05-26-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
I think they were wearing blue nitrite gloves when I visited!
UK-C200 is offline
#15 Old 05-26-2011
FWIW, once upon a time I looked up cold pour points on Mobil's website and they were exactly the same for 0W, 5W, and 10W versions. The 15W-50 was maybe 15 degrees warmer, i.e. about 40 F below.
lkchris is offline
#16 Old 05-26-2011
PropDr's Avatar
Quoted: 18 Post(s)
Not much...
PropDr is offline
#17 Old 05-26-2011
Vehicle: 2006 SLK55 AMG (SOLD) & 2006 SLK 280 (SOLD!!!)
Other Toys: 2006 SLK55 AMG (SOLD),2015 Lexus RC-F, 2013 Lexus LX570, 2013 Lexus RX450h,2013 Lexus CT200h, gla250
Hello,
I wonder what elevation were you? I mean I had rev and drove hard at times both with my SLK55 AMG and also the SLK280 during very hot ambient temperatures and never had reached that high a temperature.
Were you driving for like an extended period of time in high revs and low gear? And going up a very long step hill?
Hummmmm.............
@ 40 C, value is 75
netmiami is offline
#18 Old 05-26-2011
GeeJay's Avatar
Chats: 91
Quoted: 70 Post(s)
Above 140 degC some components of the additive package start to breakdown which would considerably shorten the oil-drain interval. The 127 degC you mention should be no problem, it's not uncommon to see 130 degC oil temp on a modern engine. The synthetic PAO base oil material used in Mobil 1 will cope too, no problem.
GeeJay is offline
The Following User Says Thank You to GeeJay For This Useful Post:
#19 Old 05-26-2011
Chats: 2
Quoted: 13 Post(s)
I will be having Blackstone do an analysis very soon. I put Castrol 0W-30 in at 32,283 and it has a little over 3,000 on it now. I'll post the results when ...white lint free gloves as opposed to blue nitrile gloves(per UK-C200 )?
Galo is offline
#20 Old 05-26-2011
Chats: 2
Quoted: 13 Post(s)
Looking in my "Factory Approved Service Products" booklet, all of the oil "weights" are "good" to 86*(the graph goes no higher) and only the 0W-30 to 5W-50 are good to -13*. Also, something very interesting from this booklet is this statement; "Select oil viscosity according to the lowest air temp expected before the next oil change using the chart below." Very interesting(in my best Arte Johnson)."
Galo is offline
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 56 3 Weeks Ago 05:35 AM
Stupid question - engine oil terrylim SLK R171 General Discussion 24 09-12-2011 05:26 PM
