Brake pads and disc change - Mercedes Benz SLK Forum
#1 Old 05-11-2011
Vehicle: SLK 350 2007- BLACK
Hi, I have a Mercedes SLK 280 (2007) with SLK 55 bodykit and 18" wheels. I would like to change front and rear brake pads as well as to have bigger drilled brake discs. What do you recommend? Thanks in advance!
Luis
escolamd is offline
#2 Old 05-11-2011
GeeJay's Avatar
Chats: 91
Quoted: 70 Post(s)
Your profile says you have a 350.... ?
If you have a 280, with standard brakes (sliding caliper) as fitted to 16" rims? Then FWIW I think a fairly simple upgrade given that you know have 18" rims, would be to fit the 4-pot Brembo calipers and discs from a 350. Probably only need to do the fronts, the rears should IMO be good enough.
The rears aren't usually cross-drilled, though the 55 AMG may be (I try not to look at the 55's I get tired of wiping drool off my shirt )..
GeeJay is offline
#3 Old 05-11-2011
Quoted: 6490 Post(s)
Luis,
If you haven’t, please post an introduction in the ‘new members introduce yourself here’ section.
Thank you,
Sergeant-at Arms
#4 Old 05-11-2011
ponia003's Avatar
Vehicle: 2006 SLK280, 2005 E500 (W211)
Other Toys: Horses
Quoted: 29 Post(s)
Welcome from Los Angeles.
Hard to say without more details on your set up, but generally bigger discs require different calipers. You already have 18" (OEM I presume?) wheels, so you could upgrade to SLK55 brakes if you wanted. I upgraded my 280 brakes to 350 brakes, but again I'm not sure what's included with the "55 body kit."
You can go to ATE
http://www.ate-na.com
to view OEM pads.
ponia003 is offline
slk 200 brakes leetb Tires, Wheels, Brakes & Suspension 16 09-23-2014 08:55 AM
Akebono Ceramic Brake Pads tcrankwa Performance MODS for the R170 8 03-25-2013 06:20 PM
2006 SLK 350 Brake DIY Questions cflyer2000 SLK R171 General Discussion 5 07-08-2010 07:19 AM
Fitting brake pads on R170 beanie Performance MODS for the R170 0 03-29-2010 06:51 PM
