tires (again) - Mercedes Benz SLK Forum
#1 Old 02-20-2007
V8SLK's Avatar
Vehicle: 05 SLK55 AMG
Other Toys: Chevy Silverado truck & Suzuki GSXR1000 motorcycle
tires (again)
i've been going back and forth trying to find a tire/wheel combination larger than stock that doesn't rub. i recently found this little piece that helped me get some insight into tire sizes (specifically total tire diameter).
Width x Aspect Ratio = Section Height
Section Height x 2 = Combined Section Height
Combined Section Height + Wheel Diameter = Tire Diameter
Example: 185/60R14 85H or 185/60HR14
185mm x .60=111mm
111mm x 2=222mm
222mm + 355.6mm(14")= 577.6mm or 22.74"
The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
The last number is the diameter of the wheel in inches.
To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
i hope this is helpful to anybody else looking to change tire sizes.
V8SLK is offline
Need New Tires jbanks15 General Discussion 6 03-29-2009 06:15 PM
Help with Tires noregret4life SLK R171 General Discussion 43 03-31-2008 11:09 AM
Tires SoCalSLK55 AMGs 12 02-20-2007 02:56 PM
