Component location .... - Mercedes Benz SLK Forum
#1 Old 04-20-2014
nimbusgb's Avatar
Quoted: 250 Post(s)
My GPS looses satellites and I'm pretty sure that it's the antenna itself or the connection to the control box. It usually happens after a visit to the clay pigeon club after a 1/2 mile of farm track ( at 1 to 2 mph I hasten to add ) the signal dissappears and will take either the return trip or a couple of days of driving on potholed Sussex roads to come back!
Found the GPS antenna behind the rear view mirror!
The GPS 'control unit' is contained within the DVD box in the boot I think.
Anyone know how to diagnose connectivity issues between the two? Is the GPS antenna a known problem?
i have a stack of GPS parts having worked on some other nav systems so I could probably fix or substitute whatever needs replacing.
nimbusgb is offline
#2 Old 04-20-2014
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
On an R171, it's just a straight (micro) co-ax cable from the antenna (in the mirror housing ), down an A-pilar to the back of the COMAND head unit. Unless you have a fault in the cable itself, the best you can do is check the terminals.
I won't preach to the afflicted, but, you're not parked up under any trees etc., that will stop the signal?
Woolly is offline
#3 Old 04-20-2014
nimbusgb's Avatar
Quoted: 250 Post(s)
Nope no cover and it sometimes takes days to recover. Usually after a bit of rough road. I suspect it's a poor antenna connection because I monitor it in the hidden satellite monitoring page and get long periods of 0 or 1 sat in view. Using a handheld GPS at the same time I can usually see 8 or more above the horizon at the same time.
nimbusgb is offline
#4 Old 04-20-2014
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
Evening..
Probably a duff GPS antenna or bad connection - may be worth popping the headunit (or DVD unit) out to check the connection
Sean
Seanhump is online now
#5 Old 04-22-2014
aka John
Chats: 1143
Quoted: 30 Post(s)
Ah, it runs to the boot to the navidrive, not the back of the head unit, but otherwise all the above suggestions are valid.
UK-C200 is offline
Location of ABS BAS ESP Control Module spacetiger SLK R170 General Discussion 7 10-25-2015 05:39 AM
location of outside thermometer martingie SLK R171 General Discussion 6 09-01-2013 01:59 PM
Mass Air Fow Sensor Internal Component . . . Buy One For Me Fyrelight SLK R170 General Discussion 9 08-12-2012 08:59 PM
Gearbox ECU location on RH drive SLK230 raygee SLK R170 General Discussion 1 02-17-2012 10:54 PM
Brake Lamp Switch Location RQUICK1 SLK R170 class DIY 1 08-20-2010 03:34 PM
