Weird Plastic Trim Issue... - Mercedes Benz SLK Forum
#1 Old 10-12-2009
RacerCub68's Avatar
Vehicle: 2006 SLK350 - All Opts. ('cept AMG Pkg & Auto) 6-speed manual, YEAH!
Other Toys: '11 Prius II w/ Leather
Chats: 31
Unhappy Weird Plastic Trim Issue...
I took my car in for service for multiple things. I have this weird thing that to the right of my volumn knob, the plastic top surface appears to have "melted" and bits of it was hanging off, and coming off to the touch.
The dealer called, and they said Mercedes denied the warranty claim. That the part was "scratched" and that it is not a trim piece, but would necessitate the $900 replacement of the whole command unit if I wanted to pay for it myself.
I almost never use the volume knob, I use the steering wheel controls instead. Those have scratches, but I use them. I never have my hands by this part, so can not imagine how this part got this issue. Has anyone expierenced anything like this? It is between the volumn knob and the other buttons of command.
RacerCub68 is offline
#2 Old 10-12-2009
Founding member #7
mtiede's Avatar
Vehicle: 2017 SLC 300R
Quoted: 25 Post(s)
Use the cigarette lighter?
mtiede is offline
#3 Old 10-13-2009
aka John
Chats: 1143
Quoted: 30 Post(s)
Post up a picture - I'm having a hard time visualizing the piece you are talking about. On my first C class, the "rubber" coating on the volume knob melted over time - which MB wanted to fix by replacing the COMAND as well - or you could spend two hours stripping it and $.35 on the replacement cover...
UK-C200 is offline
#4 Old 10-13-2009
Cavman's Avatar
Vehicle: 2006 SLK280 Black
I have a small piece near the #1 button on the RHS of the Audio 20 module. Look s a little like the coating has bubbled. Not enough for me to worry about yet.
CM
Cavman is offline
#5 Old 10-13-2009
Vehicle: 06 SLK 55 Iridium Silver, two tone (Black/Red) interior
Other Toys: Paintball Markers (guns) :)
Chats: 123
You know the stearing wheel cluster where the buttons are (for volume etc), i'm having a similar problem there where the skin seems to be peeling of (real tiny). Would that be covered under warranty?
d3athr0w is offline
#6 Old 10-13-2009
Other Toys: 2008 C300
Chats: 15
Write MBUSA.
They are suppose to take a condition inventory when you take a car in, so that you can't blame them, if something was already there. If it's not on the paper, you should be believed. I mean, honestly you'd know if it was there before.
mb911 is offline
#7 Old 10-14-2009
Vehicle: SLK 350 Iridium Silver
Chats: 3
Could it be a result of condensation from drinks on your cup holder?
boogie is offline
#8 Old 10-15-2009
RacerCub68's Avatar
Chats: 31
No to all. I will post up pics, there are actually two places where it's starting to happen again at the top corner's of the screen. I think it is because there is something wrong with the plastic and the heat from the screen is causing it to "delaminate" or something.
The plastic literally comes off, like little balls of lint, and you rub your finger and the top coat comes right off. When it first starts, the plastic looks white, like it has wax on it.
The marks are too low to be from drink condensation, I rarely if ever use the drink holder, if I do it is only to transport the drinks home. The cigarette lighter comes out to make way for the air pump after events to put the tires back to "gas milleage" inflation.
#9 Old 10-15-2009
RacerCub68's Avatar
Chats: 31
Here are the pictures.
I admit, the top part does look like scratches, but that I do not remember seeing and did not tell them about. Even still there would not be scratches there, I never touch that area.
You can see the plastic has come off not only in the area to the right of the volumn control, but also on the bevel for the screen. It arcs along the volumn, but that is because I was cleaning with a soft towel and water to get the little nubs of plastic sticking up off.
#10 Old 10-15-2009
Do not try to clean nor scrub any more, other than light touch/dabbing with damp & clean microfiber cloth. I have some thing quite similar near the down menu button on the steering wheel controls but I believe it's from me pushing the butons in that area several times a day. My guess is that the skin oil, sunlight with roof down and heat over time may degrade the flat paint used.
If you're handy, you can mask around the area and use an air brush to spray clear flat in several coats to protect it from getting worse.
Plastic Trim Not Fully Aligned - Roof? buckster General Discussion 6 08-04-2009 02:56 PM
Help with removing trim where roll bar sits!! MDS General Modifications R171 4 02-20-2009 09:58 PM
SLK World Site Issue: Album Images Cold Shot General Discussion 4 07-10-2008 01:59 AM
Plastic cover for Engine...? DansSLK...??? SuzaFan SLK R171 General Discussion 7 03-06-2008 08:23 AM
