Lubricant used on seals leaving marks on windows - Mercedes Benz SLK Forum
#1 Old 10-06-2009
Vehicle: SLK280
Hi there all.
Just wondering if anyone else is having same problems I have. I'm finding that the lubricant that MB uses on the rubber seals on the windows is leaving "streak" marks on the window glass?
Because its the rubber seals on the top of the door window thats lubricated, every time I put my window up, it touches the seals, and hence the lubricant. Then when I put the window down, it brings some of that lube down to the bottom of the window(top of door) and contaminates the "feelers"(the bits at the top of door which stop outside contaminants from getting inside the door), and then when I put the window up,
the rest of the window then gets part of the lube on it from going past the feelers, causing grease or streak marks..
I've tried using the stuff that MB uses(i think they call it sliding compound) for lubricating seals and also Carbaflo, and they both seem to exhibit the same behaviour ie. marks the windows. Haven't tried Gummifledge yet, but I'm assuming it'll do the same thing.
Am I the only one experiencing this?
ghostdunks is offline
#2 Old 10-06-2009
Vehicle: 06 SLK 55 Iridium Silver, two tone (Black/Red) interior
Other Toys: Paintball Markers (guns) :)
Chats: 123
nope. i recently had mine lubed from MB dealer and having same problems. Been cleaning it every third day or so....its annoying.
d3athr0w is offline
#3 Old 10-06-2009
You're not the only one. The smudging gets less over time. Do use a clean microfiber cloth for glass or 100% cotton cloth to wipe the smudges down.
#4 Old 10-06-2009
Cavman's Avatar
Vehicle: 2006 SLK280 Black
You can't go wring with Gummiphlege. I used it on my Z4 and it stopped the window squeaks I had and left the seals looking brand new and soft. No residue.
Now I have the SLK I am about to use some Gummiphlege on the seals too, jutst o keep them supple.
No residue.
CM
Cavman is offline
#5 Old 10-06-2009
aka John
Chats: 1143
Quoted: 30 Post(s)
They over lubed the seals IMHO - I've done mine a number of times, and little to no streaks They should *barely* be touching the seals where the windows touch, there's not a lot of value (eg little noise) generated there... Gummiphledge seems to have more margin for error...
UK-C200 is offline
#6 Old 10-07-2009
Vehicle: SLK55AMG
Other Toys: Triumph T800
I used Gummi on my z3 and it worked well. I paid out for the MB stuff and cleaner at high price, it took me ages to do on the slk and I got the streaks as well. I just grabbed my old gummi tube and did the whole job in 5 mins and the results are better imo. Gummi is the way to go
Legin is offline
#7 Old 10-07-2009
Vehicle: SLK280
Phew! I thought I was the only one experiencing this since I never saw this posted anywhere that I could find. For me, someone(pretty much anal-retentive!!) who likes to keep their car clean and shiny all the time, those streaks were really starting to piss me off.
Hmm...seems Gummi might be an option then. Might get a tube and have a go with that if it dries with no residue. I like to keep my seals lubed but I hated having the windows marked all the time!
#8 Old 10-07-2009
Cavman's Avatar
Tube??? Mine came in a bottle with a foam applicator attached, like the shoe shine bottles. I just pumped it a few times to moisten the foam and started wiping it along the seals. Quick and easy, no mess and nothing on my hands.
CM
Cavman is offline
#9 Old 10-07-2009
Vehicle: SLK280
hmm..did some more googling on gummi...and found this, and other similar stuff on forums :
" Why it was discontinued
I searched the web mercilessly looking for information, and what I found is that Gummiphlege was most likely a silicone grease. This is why BMW discontinuted it. A BMW TSB indicates that silicone has been detrimental to the rubber weatherstripping and actually hastened its ultimate demise while first appearing to help."
Thats not good....
#10 Old 10-07-2009
Vehicle: SLK280
Hey cavman, does your gummi look like this?
#11 Old 10-07-2009
Cavman's Avatar
Yes it does. I got it from QLD over the net.
Carbaflo from UK is about $80 AUD plus $100 AUD Postage
From BMW
Carbaflo KSP 105 lubricant
Part number: 83 23 0 309 627
Supplement
50GM STIFT
Carbaflo KSP 105 is a colourless, Fully synthetic, solvent-free perfluorated High-performance lubricant / coating agent.
Unit of quantity: Piece
Weight: 0.056 kg / 0.123 lb
Price: 26.30/ $38.7
Apparently it is not to be used on NEW door seals.
Cavman is offline
#12 Old 10-07-2009
Vehicle: SLK280
Ah....did you get it from Waxit? I found they were one of the suppliers of einszett products in Oz. I might try that. Wrote to Einszett and they confirmed that the version of Gummi Pflege they produce has no silicones in it. The BMW Gummi stuff that got withdrawn must have been a silicone version - that one, I want no part of!
Yup, I got Carbaflo shipped to me from the UK...at a very prohibitive price, but I was willing to try it if it stopped the squeakiness of the roof. That it did, but also left marks all over the windows. Its quite good on the rest of the seals but just looking for an alternative for the seals that contact the windows.
#13 Old 10-07-2009
Cavman's Avatar
Well I am glad the new stuff has no Silicones.
Cavman is offline
#14 Old 10-08-2009
Vehicle: 1999 SLK 230 - Silver
Other Toys: VW Passat 2.0 TDi 170; MB A170 (W169) ; Vauxhall Corsa; Harley-Davidson 1200 Sportster
I have found that Gummi Pflege leaves some residue on the window. It cleans off but returns.
All in all though a small price to pay for curing the creaks.
John
jst_at_home is offline
#15 Old 10-08-2009
Vehicle: SLK200 Sport MT Facelift
I had this problem after 2 years ownership but in the winter I did not clean off the residue on the glass. When I finally did clean it off it left a mark where the seal touched the glass all the way round. I could never get off.
The SLK is the only car I have ever owned where the glass stained, surely it is poor quality glass ?.
I now have a new SLK so will be careful this time.
I have also seen comments on this forum about rear windows pitting. This is a sure sign of what we in the glass industry know as soft glass. Whilst not a fault as such it is a sign that the chemical mix of the glass from that factory could be changed to stop this.
Jiveman is offline
#16 Old 10-10-2009
WhiteRabbit's Avatar
Vehicle: 2012 SLK 350 (R172)
Quoted: 67 Post(s)
John
Same here.
2012 SLK 350, Mars Red, Ash, 7G Automatic, Premium Pkg I, Lighting Pkg, Multimedia Pkg, Sport Pkg, Digital Dual Zone Climate Control, Panorama roof, Air Guide Windstop, Chrome Bonnet Fins, smartTOP roof module v1.42, Akebono ceramic front brake pads, TRW ceramic rear brake pads, DIY Backup Camera
Other Ride: 2016 GLA 250 4Matic, Cirrus White, Ash, Premium Pkg, Multimedia Pkg, Panorama Sunroof, Bi-Xenon Headlamps, Blind Spot Assist
WhiteRabbit is offline
#17 Old 10-10-2009
Other Toys: 2008 C300
Chats: 15
When my car was new it did this. Now at 9 months or whatever not so much.
So yeah, I think it's something you have to leave with whenever it gets re-greased.
mb911 is offline
#18 Old 11-12-2009
Vehicle: SLK280
Got a bottle of Einszett Gummifledge coming to me in a month's time, and I'll test it out then. Its like 6 pounds in the UK, which comes to something like 11 dollars aussie... If I buy it here in Oz, including delivery, it works out to be close to $30..... small diff, but I hate paying extra just because we're on the south side of the earth
Its really annoying...I just washed and waxed the car and had it looking pristine. The moment I put the roof down, and windows retracted and then went back up, i had the marks again.
Keeping rear side windows or quarter windows down with roof up OutEast SLK R170 General Discussion 21 07-23-2016 11:21 PM
