Change Automatic Transmission Fluid? - Mercedes Benz SLK Forum
#1 Old 09-22-2009
Other Toys: Boats
I'm kind of surprised that this hasn't been ask before, but should the transmission fluid be changed on an MB automatic transmission? I have seen some recommendations on the web to do so at 60,000 miles. As far as I can tell MB doesn't recommend changing the fluid at all.
I see parts and fluid at some of the MB aftermarket parts suppliers so obviously a number of people are changing the ATF fluid.
ClemsonB is offline
#2 Old 09-22-2009
IIRC, on the R171 it was at 50,000 miles on the auto tranny fluid.
#3 Old 09-22-2009
Other Toys: 2008 C300
Chats: 15
I think on my 2009 it might suppose to be done at 36,000 miles and then never again unless needed.
mb911 is offline
#4 Old 09-22-2009
Vehicle: 06 SLK280
my MY06 SLK280 states it need a AT oil and filter change only once at 39K miles,
it is in the maintenance booklet page 63, US service 20 (2702)
cx872 is offline
#5 Old 01-22-2011
Vehicle: Mercedes Benz E220 cdi
some engineer in stuttgart (germany) posted on an german forum that if the automatic transmission is not leaking or doesn't make any troubles changing gears ....the fluid doesn't need any change....it can go on like this about 600.000km . If you had troubles and the fluid was changed once you should change it periodicaly at 50.000-60.000km
denis880312 is offline
#6 Old 01-22-2011
Vehicle: SLK55AMG
Other Toys: Triumph T800
Pretty clueless engineer then. Im one and would recommend changing every 30k and certainly by 40k.
Legin is offline
7G tranny fluid change DIY Legin SLK R171 Class DIY 83 10-01-2018 07:20 AM
transmission fluid check graveyard SLK R171 General Discussion 20 04-14-2015 11:35 AM
How many miles need get Transmission Oil change? ferrari5666 General Discussion 3 08-09-2009 09:16 AM
NEED HELP! Transmisson fluid change sikslk99 SLK R171 General Discussion 6 04-18-2009 10:07 AM
Test Drove the SLK350 with Automatic Transmission fastnfurious SLK R171 General Discussion 20 11-23-2006 02:57 PM
