Ceramic Brake Pads - Mercedes Benz SLK Forum
#1 Old 09-07-2009
Other Toys: Boats
Ceramic Brake Pads
I have two questions that I haven't seen addressed in the forum regarding replacing the MB OEM brake pads with ceramic pads.
1. My experience is that ceramic pads do stop better than semi-metallic pads. However this extra stopping power generates more heat. Has anyone had problems with warping rotors due to increased heat?
2. The brakes on an SLK are carefully balanced by the MB engineers. Does changing the composition of the front brakes upset the braking balance between the front and rear of the car? Has anyone who puts SLK's on a track had a problem with ceramics on just the front?
ClemsonB is offline
#2 Old 09-08-2009
Vehicle: SLK55AMG
Other Toys: Triumph T800
1/ No issue with discs but then i found ceramics to be no better than semi metallics but they make much less visible dust
2/ A lotus has brake balance by design ie no load limiter and yes I could tell the difference in front /rear pad selection. The SLK is nothing like as sensitive so pad selection isnt going to make much difference to brake balance unless you put real rubbish in then it just wont stop anyway. Most ordinary motors are over braked at the front and the slk is no exception like black series slk.
Legin is offline
#3 Old 09-08-2009
RacerCub68's Avatar
Vehicle: 2006 SLK350 - All Opts. ('cept AMG Pkg & Auto) 6-speed manual, YEAH!
Other Toys: '11 Prius II w/ Leather
Chats: 31
I am pursuing PAGID yellow endurance pads as recommended to me be a hardcore Boxster S racer as a great replacement that offers stock street longevity but a lot better performance on the track. He assures me that properly bedded in, they will last as long as the stock brakes on the street and not assult my discs.
According to Pagid's web site, the R171's front brake system is Brembo and the rear is Teaves.
Looking them up at RennStore, I find:
RS 14 BLACK
This is a medium high friction value ceramic type compound with very good modulation, high fade resistance, low heat conductivity, and a good wear rate up to a temperature of 650°C (1.200°.
It is kind on discs, with visible grooving, but a limitation of hairline cracks.
Applications: NASCAR, CART, F3, Touring cars, GT cars, WSC, Trans Am and Rally.
RS 19 YELLOW
Best compound for endurance racing on the basis of the RS 14. A slight reduction of the friction value improves the modulation. Nevertheless, the friction value is enough for cars without power-assisted brake system and ensures comfortable low effort on the brake pedal. Constant temperatures up to 600°C (1.100° are possible. The combination of friction value, fading stability and low wear rates on pads and discs realised with this pad compound is unmatched up to now.
Due to its outstanding wear rate and driveability also used at many sprint races.
Application: All endurance racing cars from group N (Speed-WC, Grand Am Cup) up to GT and Sport-Prototypes.
A multiple winner of Daytona 24h, Le Mans 24h, Sebring 12h, Spa 24 h, Nürburgring 24h, often with no pad change and usually no disc change.
RacerCub68 is offline
The Following User Says Thank You to RacerCub68 For This Useful Post:
#4 Old 09-08-2009
Vehicle: SLK55AMG
rs 14 eat discs and can deposit causing judder issues. The best Pagid I have found for road and track is rs 42 blue. I havent tried the ceramic so cant comment.
Legin is offline
#5 Old 09-08-2009
RacerCub68's Avatar
Chats: 31
Have you tried the yellows?
#6 Old 09-08-2009
RacerCub68's Avatar
Chats: 31
Found this scary line about the Pagid pads....
"Since Pagid pads tend to "out-gas" we recommend using these pads with a new gas-slotted or cross-drilled rotor for the best performance. Pagid brake pads are not compatible with previously used rotors, especially if used with a carbon or Kevlar based race pad."
#7 Old 09-08-2009
Vehicle: 350 6MT. Retrofitted 55 AMG body wheels seats cluster, Airscarf, Comand & UCI, Digital Climate.....
Chats: 171
RacerCub,
Do you have details of the exact application of the pagid pads. Or are they simply SLK fitting pagid yellows?
I ask because I would like to get hold of the pads specs in order to see if another brand stock the shape requied for the specific brembo caliper without realising it is applicable tp the slk.
Adamantium is offline
#8 Old 09-08-2009
Vehicle: SLK55AMG
No I havent , the only other I tried was the orange on my Fezza and they really worked well.
Legin is offline
#9 Old 09-08-2009
RacerCub68's Avatar
Chats: 31
Fezza? You a shriner with one of the funny caps?
#10 Old 09-08-2009
RacerCub68's Avatar
Chats: 31
Originally Posted by Adamantium View Post
RacerCub,
Yeah... Go here and pick your car:
http://outcat-cs1.tecdoc.net/ows/en/...dexFramesetJsp
#11 Old 09-10-2009
Chats: 171
dead link???
#12 Old 09-10-2009
RacerCub68's Avatar
Chats: 31
Search for PAGID's web site, then go to Online Catalog.
#13 Old 09-11-2009
PropDr's Avatar
Quoted: 18 Post(s)
How about the Porterfield R4-S ?
My Beautiful Black Walküre (Valkyrie)
PropDr is offline
SLK 350 replacement Brake pads & rotors SuzaFan Performance MODS for the R171 12 04-14-2014 06:20 PM
Ceramic Front brake pads for SLK55? ppower General Modifications R171 5 05-14-2008 01:06 AM
Changing brake pads dsb Performance MODS for the R171 14 03-18-2008 05:27 PM
