Thoughts on a hardtop problem. - Mercedes Benz SLK Forum
#1 Old 06-02-2009
Hey all, for those of you have dealt with hardtop issues, perhaps you can help me diagnose this problem.
First, I have a 1998 SLK 230. The hard top will not go down. When I push the switch to activate the convertible top, the windows all go down and then the trunk starts to lift a few inches on the passengers side, but it will not lift much on the drivers side (maybe an inch).
I assumed it was the hydraulic system, but heres the deal.... I used the allen wrench and depressurized the hydraulic system and took the top down manually. I screwed the allen screw back in, and allowed the hydraulic system to repressurize. I pushed the hardtop switch up and then the top went up perfectly: the trunk lifted, the top unfolded and it locked into place, windows up. It seems obvious it isn't the lifters... can anyone speculate as to what switch/relay it is. It is kind of throwing me for a loop... It will go up but not go down, and its not the hydraulic system.
Thank you in advance for your help.
SpectreNCSU is offline
The Following User Says Thank You to SpectreNCSU For This Useful Post:
#2 Old 06-02-2009
thechidz's Avatar
Vehicle: 2009 Monterey Blue 370z
Other Toys: someday I will own a boat
I've recently had some problems with my hard top as well. The trunk seems to get stuck when trying to lift. I've noticed this especially happens if I am not parked on an even surface, and realized this is probably my problem. Could that be it?
thechidz is offline
The Following User Says Thank You to thechidz For This Useful Post:
#3 Old 06-02-2009
Hmm, I can't say that has had an effect. I have been trying to operate it on some very flat grades, and it hasn't worked. Thanks for the suggestion though.
#4 Old 06-02-2009
There is a limit switch in the trunk for both sides. It is located under all the plastic panels near the main arm for the trunk. If i can find the link with all the switch's i'll post it for you.
#5 Old 06-02-2009
Vehicle: 96 SLK 230K
Other Toys: Samurai
Chats: 39
Gabus is offline
#6 Old 06-02-2009
Other Toys: Samurai
Chats: 39
Gabus is offline
#7 Old 06-02-2009
#8 Old 06-12-2009
WESTERN BILL
Western Bill's Avatar
Vehicle: 2001 SLK 320 Sunburst Yellow, custom wheels, custom seats
Other Toys: 2009 hybrid Camry
Send a message via AIM to Western Bill Send a message via Yahoo to Western Bill
top won;t retract
I HAVE THE SAME PROBLEM THE TOP WON'T GO DOWN I TOOK IT IN FOR A DETAILING AND WHEN I GOT IT BACK THE TOP WON;T GO DOWN WHAT IS FIRST THANT I SHOULD LOOK FOR ANY FUSE OR RELAYS SORRY ABOUT THE cAPS I DIDN'T NOTICE WUTILL I WAs finished thanks for any help
Western Bill is offline
#9 Old 06-12-2009
Vehicle: SLK32
Your caps crack me up...
Check fuse 24, 40 amp - hydraulic, fuse 25, 20 amp - pneumatic
Tslick is offline
#10 Old 06-13-2009
Vehicle: 2017 Yellow 718 Boxster
Other Toys: 2018 Tesla Model 3, 2018 Toyota Tacoma
Any update on the fix(es) for this problem?
atebit is offline
#11 Old 06-13-2009
Thread Hijacker
dmjonez's Avatar
Chats: 1599
May be obvious, but make sure the guard in the trunk is fully closed...
dmjonez is offline
#12 Old 06-16-2009
Checked fuses today, all are intact. Guess its a switch?
#13 Old 01-04-2012
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
Okay so, I am 15 and just bought my first car (slk 230) top didn't work, come to find out the front 3 cylinders were leaking. Bought a kit on ebay for 34 dollors. I fixed it and than ran the top up and down about 7 times, worked perfectly. Than i had the exact same problem. So than i went to the hydraulic pump, took off the aluminum allen next to the depressurizing allen, than i took off that allen (be careful theirs a spring on the end) and there was a little nylon seal on the end of that, and it was all broken up. I put a small o-ring in replacement and cleaned out the hole with WD-40 and than it worked perfect! Take a look at yours. It maybe this or you might just have leaking rear cylinders. Or it might also be fuses like they said above. My back passenger side is leaking also and i just sent them out to a guy in Oregon to get them fixed because the seals are machined in. Heres a link for the guy in Oregon if this is the case. http://www.tophydraulicsinc.com/en/20-r170-slk
Bradley61496 is offline
#14 Old 01-04-2012
Quoted: 6492 Post(s)
Bradley,
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last.
Thank you,
Founding Member/Moderator
Pontiac G6 Hardtop clu1234 General Discussion 14 10-18-2008 08:17 AM
NEW Z4 Hardtop HwoALanG Off Topic 17 03-17-2008 12:00 AM
R171 SLK Convertible RC Car w/Retractable Hardtop Sid SLK R171 General Discussion 4 07-04-2007 09:32 AM
Other Hardtop Convertibles -1- Off Topic 15 10-05-2006 12:09 PM
