Slk 300 vs 2006 350z - Mercedes Benz SLK Forum
Driving Stories Politically correct way of saying Kill stories
#1 Old 02-24-2009
nbarcelo's Avatar
Vehicle: 2009 SLK 300
Other Toys: 96' Yamaha Waveventure
Chats: 3
Send a message via AIM to nbarcelo
Ok, so it was me versus my buddy's friend's 2006 350Z. His car is a 6 speed manual, coupe and the only mods he has done that I know of is an exhaust system. He claims to have 255 rwhp if that sounds right. We were on a side road with two lanes around 11pm, no other cars, well lit and reasonably wide.
We started from a 20 roll up to around 80, I forgot the exact speed we shut down at, but it wasn't in the triple digits. We did two runs and he slowly walked me both times, but only up to 1 car length, then we shut down. Both his and my car had a passenger and my car was loaded to capacity with luggage. Does this sound about right or could I have done better? Either way, i'm pleased with the way my car performed against a car with more power!
nbarcelo is offline
#2 Old 02-24-2009
It sounds about right given all the facts, but you could have done better with less weight in the car -- even if he had less weight in his because less weight always benefits the car with less hp and torque.
Did you take advantage of your "shift at red line" feature by holding the shifter toward you one second before the "drive"?
Dolebludger is offline
#3 Old 02-25-2009
alroumi's Avatar
Vehicle: Kleemann K2
Quoted: 11 Post(s)
Isnt 255 whp too optimistic on the Z ?
06 SLK55 AMG (Kleemann K2)
alroumi is offline
#4 Old 02-25-2009
Sulley007's Avatar
Chats: 444
I think the 06 with a 6 speed was rated at 300 gross. I'm not sure of the net but I would expect a 20% drop off to the rear wheels. Alroumi might be correct that 255 might be a touch optomistic on his estimate.
Sulley007 is offline
The Following User Says Thank You to Sulley007 For This Useful Post:
#5 Old 02-25-2009
I think 255 RHP was measured over a few beers, and not on a dyno! And again, to the OP, did you use your "shift at red line" function?
#6 Old 02-26-2009
Chats: 2
Hi, can you explain a little bit on this shift by redline function thing? thanks.
andlee is offline
#7 Old 02-26-2009
Sure. With your car at a stop or going very slowly, simply hold the shifter toward you for about a second. Without doing anything else, the 7 sp. auto will shift at red line. This function also allows an up-shift by flicking the shifter toward the passenger side. It was use of this function that let my SLK 280 out run my Honda S 2000 0 to 60.
#8 Old 02-26-2009
Chats: 2
Oic..so you mean just using the paddleshifters instead of normal auto mode..?
andlee is offline
#9 Old 02-27-2009
Cat
Vehicle: 2006 SLK55 AMG Black
Other Toys: 2005 HD RoadKing; Ford F150 Shorty Stepside 4x4 manual; 2003 PT Cruiser
Chats: 26
Interesting. Do the R171s have the "shift at red line" feature?
Cat is offline
#10 Old 02-27-2009
Vehicle: 07 SLK200K
Other Toys: Ducati 848
Chats: 1189
does this work with the SLK 200 5sp?
and does that mean when you say flicking toward the passenger side it means the driver side for me?
RaihaX is offline
#11 Old 02-27-2009
aka Denny
carver's Avatar
Vehicle: 2008 SLK 350
Other Toys: 2011 E550
Chats: 3
Correct me if I'm wrong, but doesn't this shift at readline feature work any time you are in a numbered gear as opposed to "D"? In other words, I thought you could be driving along at say 40mph, downshift from "D" to whatever gear it puts you in, and from then on out if you don't touch the shifter it will shift up at redline. At least that's how I thought it worked.
For that matter, doesn't this work in "D" if you have the accelerator in absolutely all the way the whole time?
carver is offline
#12 Old 02-27-2009
Vehicle: '05 SLK350 Sport
Other Toys: '91 300SE
Chats: 61
Interesting. I'll have to try this out!
discoduck is offline
#13 Old 02-27-2009
Vehicle: 08 SLK 350
Other Toys: MB
Chats: 6
I've tried also from around 30 MP/H rolling start with a 335i (both automatic, 2nd gear launch) for 5 times, and everytime the slk keeped taking distance from the bimmer.
bogdanmb is offline
#14 Old 02-27-2009
jameslk55's Avatar
Vehicle: 2005 SLK55 AMG
Quoted: 17 Post(s)
i'm not a big fan of rolling starts. did you guys do that triple honk thingy? have you tried driving with dyno mode enabled (esp/abs/bas off)? also, is a sprint booster available for the slk300? should fit i think.
jameslk55 is offline
#15 Old 02-28-2009
nbarcelo's Avatar
Chats: 3
I don't know all about 350Zs, he said it was dynoed at 255 rwhp... I just found out from my friend that he also has throttle body spacers, whatever gain that's supposed to give. Keep in mind, I don't know the owner of the 350Z and he could of likely been making these numbers up!
I didn't use the "shift at redline" function as I didn't know about it at the time. I just clicked the paddle shift + whenever it neared 6500 rpms. I'll have to try this function later on.
Algrensan; yes we used the three honk thingy, . I don't usually like that as the person honking knows exactly when to go as opposed to the other driver having to "listen" for the last honk therefore being all reaction based. I was the guy honking
Last, what is the sprint booster that you speak of? Honestly never hear of it.
nbarcelo is offline
#16 Old 02-28-2009
nbarcelo's Avatar
Chats: 3
You know I forgot to add, this wasn't exactly a kill story on my part, .
nbarcelo is offline
#17 Old 02-28-2009
jameslk55's Avatar
Quoted: 17 Post(s)
it's a relatively cheap modification for your car-some people like it, some people think it's a waste of money. i have one on my '05 slk350 AT.
#18 Old 02-28-2009
Yes, shift at red line works anytime you are in a numbered gear, and not drive. On acceleration, the same thing will happen in D at full throttle, but will shift to a higher gear when you release the throttle. If you are on a road course, you might not want that.
#19 Old 02-28-2009
Vehicle: '05 489 rwhp SLK55
Other Toys: '93 RX-7 432 rwhp, '04 G35x (ski transpo)
255 rwhp for a stock/near stock Z is very accurate. Nearly all Z's post between 249 - 259 rwhp in stock configuration. BTW, the OP indicated a manual tranny. As a rule of thumb, subtract 15% crank to obtain rwhp for manual equipped car...the subtractor is ~ 20% & 25% for automatic & 4WD configurations respectively. Hope this helps.
-Matt
Blown SLK55 is offline
The Following 2 Users Say Thank You to Blown SLK55 For This Useful Post:
Go Back   Mercedes Benz SLK Forum > General Discussion about Mercedes Benz SLKs > Driving Stories
2006 280 SLK vs 2007 350z? Paison SLK R171 General Discussion 39 07-06-2008 07:29 PM
Tsukuba Battle - Boxster vs SLK vs M3 vs 350Z vs TT vs NSX tai230k SLK Videos 15 09-25-2007 06:19 PM
Comparison: SLK, TT, Boxster, 350Z Ikarus SLK R171 General Discussion 10 04-22-2007 11:14 AM
