park advanced at idle - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Mensra
  • 1 Post By Turdo2
  • 1 Post By Mensra
#1 Old 3 Weeks Ago
Vehicle: slk55 05 fab design
Quoted: 16 Post(s)
Send a message via AIM to samir
i have park advanced at idle -16 ,and with live data go to -26 !!!
its normal ?
pls if can someone help if you dont mind,,
regards
samir is offline
#2 Old 3 Weeks Ago
Mensra's Avatar
Quoted: 363 Post(s)
At idle, most cars retard timing in order to smooth out the idle. The numbers you’re looking at are perfectly normal.
samir likes this.
Mensra is online now
The Following User Says Thank You to Mensra For This Useful Post:
#3 Old 3 Weeks Ago
Quoted: 16 Post(s)
while driving in several conditions rpm reach 5000 and more ,sometimes reach -26 !!
its ok ?
thx a lot
samir is offline
#4 Old 3 Weeks Ago
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 346 Post(s)
That's 16 degrees before top dead center. Ignition advance is never a positive number or the engine will not run. this is how all engines work.
same with -26. most engines are happy at higher RPM's from -20 to -35 (degrees before Top Dead Center)
samir likes this.
Turdo2 is offline
#5 Old 3 Weeks Ago
Mensra's Avatar
Quoted: 363 Post(s)
@Turdo2, I have actually seen some modern engines with diagnostic hooked up to it where occasionally I can sometimes have as much as 5° after TDC. It depends on load, fuel, altitude and a number of other factors. But generally, the numbers he is getting look to be correct.
samir likes this.
#6 Old 3 Weeks Ago
Quoted: 16 Post(s)
thx so much for yr kind reply ,,,
regards
samir is offline
#7 Old 3 Weeks Ago
Quoted: 16 Post(s)
thx so much for yr reply
regards
samir is offline
