Fog lights/brake light - Mercedes Benz SLK Forum
  • 1 Post By i860
#1 Old 07-06-2019
Vehicle: 2005 R171 slk350
Hi everyone. Ive swapped my tail lamps for all led. I’d now like the what is currently the fog lights to act as braking lights and the tail light be tail/fog. This is as per E Class W211.
I’ve looked at the wiring (physically, I’ve not seen a wiring diagram....yet) and it can’t be done at the cluster. I’m now wondering if it can be coded using DAS/STAR?
Any help would be greatly appreciated https://www.ctd.gr/datafiles/4694.gif
File Type: jpg 8D09A356-1068-46BF-8CB1-9F59E2A6C348_1562407191499.jpg (24.5 KB, 7 views)
File Type: gif 93E8A76A-AB20-4250-ADE0-49CE95FADB8C_1562407256681.gif (49.0 KB, 6 views)
Large1968 is offline
#2 Old 07-06-2019
Quoted: 2213 Post(s)
Doubtful.
@i860 @VII7
Are the intensities the same? UK law specifies intensity for each purpose.
I think the lens configuration is also different and may cause you MOT issues.
If anyone know re coding, it's the two members mentioned above.
#3 Old 07-06-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 897 Post(s)
Don't know about that.
i860 is online now
#4 Old 07-06-2019
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 192 Post(s)
Not through programming but you can physically re pin the terminal.
VII7 is offline
#5 Old 07-06-2019
Mensra's Avatar
Quoted: 367 Post(s)
I do not think you’ll be able to pass MOT.
Mensra is offline
#6 Old 07-06-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
Are they after market lamps ? Doubt it very much that das would do anything like that. It will program led head lights ect on new Models.
Best way is to rewire the lamp unit...however if the leds don't draw same power your dash will register a bulb out error
frogfoot is offline
#7 Old 07-07-2019
My reasoning for thinking that it could be done by programming is the way that Canbus works. If a left headlamp fails then the Canbus will turn on the front left fog lamp in its place. The same goes for rear indicators, a fog lamp or stop lamp will flash instead.
I can’t alter the wiring at the lamp cluster as there is only a single wire going to the existing stop tail. Anyone know where the if there’s terminals elsewhere that may have the separate signals?
#8 Old 07-07-2019
The end result would be identical to the W211 W Class. Why would that be an MOT failure?
#9 Old 07-07-2019
Do you know if there is a terminal block other than at the tail light cluster?
#10 Old 07-07-2019
Yes they are aftermarket lamps (see my opening post attachments) They are all led so current draw should not be an issue.
#11 Old 07-07-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
R
My reasoning was that when I fitted a Led bulb to number plate lamps I had error , then when I fitted a multi Led bulb to the number plate lamps they are fine
frogfoot is offline
