DAS/Xentry cheap alternative - Mercedes Benz SLK Forum
DAS/STAR Coding Any links or posts leading to pirated software will be immediately deleted. SLKWORLD is not responsible for any damage caused by miscoding, use at your own risk.
 49Likes
#1 Old 03-08-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 859 Post(s)
Hi
I installed today xentry/das with vas5054a ( not sd connect c4 ) device 55 ( a chap from California ), and we tested on a c230.
It has the full functionality of my 500 sd connect c4, take 2 days but what a great result.
Moderator addition-->Per a PM I sent re equipment needed (at post 13), reply received: You need a vas5054 oki chip, a laptop with windows 10 or 7 64x and i can do the rest remotely.
File Type: jpg Screen Shot 03-08-19 at 05.12 PM 001.jpg (51.3 KB, 67 views)
File Type: jpg Screen Shot 03-08-19 at 05.27 PM 001.jpg (58.1 KB, 42 views)
frogfoot, M4rCu5, Avel Du and 2 others like this.
i860 is online now
The Following 6 Users Say Thank You to i860 For This Useful Post:
#2 Old 03-08-2019
Moderator/RoTMorganiser
Quoted: 2137 Post(s)
Hmm. Interesting.
i860 likes this.
#3 Old 03-08-2019
i860's Avatar
Quoted: 859 Post(s)
For 55 hardware + installation you can have a fully das/xentry system on any laptop, no brainer.
frogfoot, M4rCu5, Avel Du and 1 others like this.
i860 is online now
#4 Old 03-08-2019
There in lies my issue.
All the gear, no idea.
But... so tempting.
i860 likes this.
#5 Old 03-08-2019
i860's Avatar
Quoted: 859 Post(s)
You can lear
i860 is online now
#6 Old 03-08-2019
Quoted: 851 Post(s)
I love Dexter
i860 likes this.
efair is offline
#7 Old 03-08-2019
Now, that's an option NOT to go for!
i860 likes this.
#8 Old 03-09-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 324 Post(s)
Hmm. Interesting.
Remember Myk as good as Das is it will tell you whats wrong and point you in the right direction , clear codes ect
But it will not pull the car apart and hands on fix it for you......but will leave you with that nagging thought of
Now I know my car is xxxxxx
A cheap OBD reader from euro parts ect is a handy little thing to keep in the boot for road trips ect ( turn light off limp home )
frogfoot is offline
#9 Old 03-09-2019
i860's Avatar
Quoted: 859 Post(s)
I just order one my self and I will try it on my cars, it should be with me in one week.
I will install all from scratch and compare with my sd connect c4.
frogfoot and laidbackgolfr like this.
i860 is online now
#10 Old 03-09-2019
Trev5's Avatar
Quoted: 291 Post(s)
Interesting alternative - So what do You get for 55...??
i860 likes this.
Trev5 is offline
#11 Old 03-09-2019
i860's Avatar
Quoted: 859 Post(s)
Actually is 58 just order one now.
That is the hardware is a pass-thru device instead of sd connect c4 and then you need the software. The newer the car the better.
Next week I will receive my device, install all software and do extend testing gon my 2 cars.
Again if an old c230 can be read ( all modules, air bags ezs module ) plus the ability to do all the testing and actual startup on modules.
frogfoot likes this.
i860 is online now
#12 Old 03-09-2019
i860's Avatar
Quoted: 859 Post(s)
Just finished a 1h session ( in California ) playing with this and very impressed with the cheap obd tool. So far seems to see/do exactly like sd connect c4.
File Type: jpg Screen Shot 03-09-19 at 06.18 PM 001.jpg (44.5 KB, 44 views)
File Type: jpg Screen Shot 03-09-19 at 06.50 PM 001.jpg (45.0 KB, 18 views)
i860 is online now
#13 Old 03-09-2019
LeonardoDaBenz's Avatar
Quoted: 992 Post(s)
Is this the setup you got?
https://www.aliexpress.com/item/Newe...426806859.html
LEN
(Moderator)
I cant give you a sure-fire formula for success, but I can give
you a formula for failure: try to please everybody all the time.
Herbert Bayard Swope
LeonardoDaBenz is offline
The Following 2 Users Say Thank You to LeonardoDaBenz For This Useful Post:
#14 Old 03-09-2019
i860's Avatar
Quoted: 859 Post(s)
Yes vas5054a oki chip.
i860 is online now
#15 Old 03-13-2019
Quoted: 188 Post(s)
Excellent, I had been looking at the bigger kits but if this will do what I need that is great! Thanks for the info.
jet_fl is offline
#16 Old 03-13-2019
Delucas's Avatar
Quoted: 1124 Post(s)
Is this only for merc connection only or other manufactures ?
Delucas is online now
#17 Old 03-13-2019
i860's Avatar
Quoted: 859 Post(s)
I can't comment on that after I receive the device I will try also with BMW ista-d and ista-d
i860 is online now
#18 Old 03-13-2019
Delucas's Avatar
Most list vw spec as in audi - vw - lambo - skoda ive seen so far .
#19 Old 03-13-2019
i860's Avatar
Quoted: 859 Post(s)
Is not listed for MB but working fine for the models with CAN, Kline is not supported on MB.
i860 is online now
#20 Old 03-16-2019
i860's Avatar
Quoted: 859 Post(s)
Vas obd arrived today, I had all prepared windows with xentry/das and I test it on my slk and my w204 c280.
As you can see all the module can be read and accessible.
So anyone can own a star system now.
If you are for it buy the vas obd oki and I can help you with the installation, please PM me for more info.
DAS
Xentry
i860 is online now
The Following 3 Users Say Thank You to i860 For This Useful Post:
Rear view mirror cheap alternative part ThinkRob SLK R170 General Discussion 0 09-04-2014 09:31 PM
Happiness is being smart or call me cheap Berliner Heckflosse Off Topic 0 06-16-2011 04:01 AM
