Coding door module - Mercedes Benz SLK Forum
#1 Old 06-21-2018
Eddy86's Avatar
Vehicle: SLK 280 2007 Edit10n
Quoted: 11 Post(s)
Question Coding door module
Hello,
Because my door module doesn't work correctly and because it's almost impossible to find second hand r171 door module (or over 200€), I decide to look at other MB models door modules.
and it seems that w203 look excatly the same 2038209185, connectors are the same, even pins seems to be exactly at same place. So I though only firmware can be different or not....
For test, I have bought for less than 30€ a module from an english W203. Results are not perfect but lock/unlock, folding mirror, speakers works correctly. I didn't test auto dimmable mirror and heating.
But windows doesn't works correctly, both goes down but never goes up. mirror can not be setup (up down Left right).
The module I have tested is 2038201585, and after a precise inspection, windows connector pins are not the same as my door module, and english car doesn't have windows control on left door this can explain these malfunction.
So this w203 module will probably never works perfectly with my french R171, but do you think w203 LHD door module can work or can be flashed with DAS to fit my r171 ?
Thanks for your comments and sorry if this idea is completly stupid
Eddy86 is offline
#2 Old 06-21-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 897 Post(s)
In das you can copy the data from the old module to the new one.
If this does work you can try to do online scn to that module to your vin number.
i860 is online now
Common and easy to do DAS 'tweaks' Seanhump DAS/STAR Coding 102 11 Hours Ago 06:16 AM
What cool stuff can you do with STAR coding? bac SLK R171 General Discussion 17 10-19-2015 03:20 AM
STAR and coding mods (facts required) Seyley General Discussion 4 12-30-2010 02:36 PM
slk171 2006 command retrofit oscar 67 SLK R171 General Discussion 4 10-26-2007 10:53 AM
