just received but not correctly configurate - Mercedes Benz SLK Forum
  • 1 Post By Avel Du
  • 1 Post By i860
#1 Old 05-15-2018
Eddy86's Avatar
Vehicle: SLK 280 2007 Edit10n
Quoted: 11 Post(s)
hello,
I've received a Cf30 and sdconnect but impossible to use them together.
xentry see sdconnect, sdconnect toolkit can perform test buy when I try to use it for diag, it doesn't work. I don't understand what happens, of course no help from the seller.
Maybe those photos can help ?
Thanks for your help and sorry if this is a stupid noob question
Eddy86 is offline
#2 Old 05-15-2018
Quoted: 2213 Post(s)
@Terminal @i860
Any ideas chaps?
i860 likes this.
#3 Old 05-16-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 897 Post(s)
Check the ip on your Ethernet card it should be like :
ip address : 172.29.127.119
subnet mask : 255.255.0.0
If no luck PM me and i can try to look via team viewer.
i860 is online now
#4 Old 05-16-2018
Eddy86's Avatar
Quoted: 11 Post(s)
hello,
ok i will check that tonight. I'll keep you informed asap.
should this address be the same as the sdconnect adress ? (the one we can see on the sdconnect lcd display)
Eddy86 is offline
#5 Old 05-16-2018
i860's Avatar
Quoted: 897 Post(s)
That is for lan, for WLAN is a different IP.
If you are stuck send me a private message and I will try to help you via TeamViewer.
i860 is online now
#6 Old 05-18-2018
Eddy86's Avatar
Quoted: 11 Post(s)
sorry really busy actually, so forgot to give you some news.
A friend help me yesterday, but we do not finish to check and make the correct configuration.
All the stuff have been delivered without be configured correctly, I'm not really happy but I knew about the risk when I ordered it...
If we don't meet more problems, it would be ok sunday evening and I will come back to give the solution for this error message.
Eddy86 is offline
#7 Old 05-22-2018
Eddy86's Avatar
Quoted: 11 Post(s)
hello.
some news, it works perfectly. But don't really know why... suddenly the sdconnect launch a firmware update.. found the slk....
Eddy86 is offline
How to CORRECTLY reupholster your headliner for $15 ! dropped headliner solved! Arachnyd SLK R170 class DIY 24 06-30-2018 03:00 PM
Aston Martin Received 3,000 Orders For the DB11 Berliner Heckflosse Off Topic 1 09-29-2016 04:57 PM
Tesla has received 325,000 preorders for the Model 3 Berliner Heckflosse Off Topic 0 04-08-2016 12:38 PM
Received a postcard today - eurocarphone.com jbanks15 SLK R171 General Discussion 2 09-26-2006 05:34 PM
