What do I need to program my ecu? - Mercedes Benz SLK Forum
  • 1 Post By os62
#1 Old 04-07-2018
Vehicle: 2005 Slk 350 White
Quoted: 36 Post(s)
Hi all,
What do I need to access and program the ecu?
I saw lots of combination on eBay.
I just need to get the C4 multiplexer, the Xentry software, and install in onto my own laptop, correct?
If not, what do YOU use to program the ecu or what else do I need?
Anyone in Philly have it?
Not sure if posting these pictures are allowed or not, if not, please let me know and I will remove it.
Edit: seems like there is a new program called: Mercedes Vediamo 4.2.2 - engineering software for diagnostics, coding, programming via Star or SDConnect + CBF CFF files (10 GB)
What are those CBF CFF files?
File Type: jpg Screenshot_20180407-150248_1523128307272.jpg (23.1 KB, 22 views)
File Type: jpg Screenshot_20180407-150321_1523128329171.jpg (31.3 KB, 16 views)
File Type: jpg Screenshot_20180407-150302_1523128344435.jpg (33.9 KB, 12 views)
riceball4u is offline
#2 Old 04-07-2018
Vehicle: 2013 SLK 55 amg (all-black)
Other Toys: 2006 E280 CDI (tanzanite blue) ecu optimized.
Quoted: 29 Post(s)
That depends what you mean by "programming".
If you want to change variant coding (parameter values), you'd use DAS (older cars) or Vediamo (newer cars), and C4 would be optimal for that.
On the other hand, if you want to do remaps or other software alterations, it'd be more prudent to acquire BDM100 tools and associated software (WinOLS or ECM Titanium).
i860 likes this.
os62 is offline
#3 Old 04-07-2018
Star/DAS Registered Owner
Quoted: 499 Post(s)
@i860 has done it to his car. He should be by in a bit to let you know.
mchild is offline
#4 Old 04-07-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
What exactly do you want to do?
Remapping ecu, scn coding on ecu's, update ecu's?
i860 is offline
#5 Old 04-07-2018
Quoted: 36 Post(s)
I want to modify the air fuel ratio.
I want to (planning stage now) to add a super charger on it so I need a way to increase the fuel injector output.
What does SCN coding do?
Thanks both for the replies
#6 Old 04-07-2018
i860's Avatar
Quoted: 893 Post(s)
That is ecu remap
To read/write the ecu you need ktag and you need to open your ecu for that.
Post a picture with the back of your engine ecu may be i can help you with with original file.
If my file matches your ecu you can use kessv2 to flash wia obd so no need to open your ecu.
To modify the map you need winols or ecm titanium
i860 is offline
#7 Old 04-07-2018
Quoted: 36 Post(s)
That is ecu remap.
To read/write the ecu you need ktag.
To modify the map you need winols.
Thanks, I'll read up more on it.
Any suggestions as to where is a good starting point?
#8 Old 04-07-2018
Quoted: 36 Post(s)
That is ecu remap
Please see attached.
Wouldn't the parameters be different with difference in air intake rate?
#9 Old 04-08-2018
i860's Avatar
Quoted: 893 Post(s)
Yes, mine file will work on your ecu.
This is the base map that the car came from the factory ( Bosch 0 261 209 015 ).
In order to remap and checksum ( change any parameters, afr, delete lambdas, modify injection,part throttle, full throttle, spark advance, torque limiter etc) you need the base map from the car widout the base map you can't do anything.
The ecu me9.7 can't be read to obtain the base map only on the bench you need to open the ecu and read it. It will save you the horror of opening the ecu.
i860 is offline
#10 Old 04-08-2018
Quoted: 36 Post(s)
Cool, that's good to know, this will definitely be helpful having that.
I could reply to your pm as it exceeded my limited.
I didn't realize there is so much to do before I can even start playing with the ecu.
Thanks.
#11 Old 04-08-2018
i860's Avatar
Quoted: 893 Post(s)
If you want the file pls contact me on pm.
i860 is offline
#12 Old 04-08-2018
Quoted: 36 Post(s)
Thanks, pm send.
R170 Ecu Flasher Relay Repair Roberto_Rodrigues SLK R170 General Discussion 1 08-29-2017 04:16 PM
SLK R171 not starting duncanadamsxxx SLK R171 General Discussion 12 04-06-2017 04:53 AM
I had to replace the ecu... SuzaFan SLK R171 General Discussion 9 02-12-2014 10:15 PM
R170 230 ecu immo info mbz7228 SLK R170 General Discussion 9 06-25-2013 07:41 AM
P1236 Code alone. Bad ECU? Katz New Members Introduce Yourself Here 20 01-13-2013 10:10 PM
