Vediamo - Mercedes Benz SLK Forum
 7Likes
#1 Old 02-15-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
Vediamo
After weeks of frustration, I manage to make Vediamo work.
I don't know much about it so I need to read, a small change and you screw your car in vediamo.
I test the version on my w204 c280 and remove v max
Michael Stavrinos likes this.
i860 is online now
#2 Old 02-15-2018
LeonardoDaBenz's Avatar
Quoted: 1011 Post(s)
Maybe give us a bit of info about what you're talking about?
"Vediamo" means "We see".
I don't have a clue but am always open to learning something new
Eeyorewolf likes this.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#3 Old 02-15-2018
i860's Avatar
Quoted: 893 Post(s)
@LeonardoDaBenz
Mercedes Vediamo Software is used by the plant engineers to develop diagnosis and engineering software, which is now used by Xentry and DAS, is based on the Mercedes Benz super engineering version developed and delivered to the general customer service dealers’ use.
Vediamo, works with MB star C3, is a factory development and engineering tool for Mercedes Benz vehicles. It is capable of doing offline configuration (coding*no SCN needed), flashing, programming control units, changing configuration.
Russ1 likes this.
i860 is online now
#4 Old 02-15-2018
Now it makes more sense to me
LEN
(Moderator)
#5 Old 02-16-2018
i860's Avatar
Quoted: 893 Post(s)
I start to backup all my modules ( still need some cbf files for some modules )
For example, I back up my ecu me9.7 with all the scn coding string.
I this one fails, I can buy a second hand one and transfer the data on.
Same on transmission tcu, in case of conductor plate gets damaged.
So far i manage to finish
engine ecu
transmission
central gateway
esp
overhead panel
the upper control module
To follow
airbag
automatic headlamps
the electronic selector module
ezs
front and rear sam
vario roof
ewrvt and Michael Stavrinos like this.
i860 is online now
#6 Old 02-16-2018
Vehicle: 2013 SLK 55 amg (all-black)
Other Toys: 2006 E280 CDI (tanzanite blue) ecu optimized.
Quoted: 29 Post(s)
Welcome to the Dark Side.
os62 is offline
#7 Old 02-16-2018
i860's Avatar
Quoted: 893 Post(s)
Yes, now digging through a 15gb cbf files....
i860 is online now
#8 Old 04-10-2019
Vehicle: 2005 R171 SLK350
Other Toys: 1992 Mitsubishi E39A VR4
I also managed to get myself Chinese knock-off C4 and D630 laptop. I managed to get Xentry working but yet to get Vediamo worked out. Which version you are using?
Also I got myself a KTAG and couple of spare ME 9.7 ECUs for this. Just like what you did I am going to get my ECU backup so that when it's time for the current goes I will have something in place to keep the card running
I saw some places selling brand new China virgin ME 9.7 ECU for cheap. Together with transfer cable and KTAG, they claim that I can program it without SCN. I am ordering one set to see if it works. If these work out it could be an alternative to Vediamo
Looking forward to mess around with them when I get some spare time
jet_fl likes this.
yiuwa is offline
#9 Old 04-11-2019
Quoted: 205 Post(s)
Will this allow you to change the values in the ECU for fueling and timing so we could do our own tunes?
jet_fl is offline
#10 Old 04-13-2019
Through KTAG? It's a tool that allows you to extract and write EPROM data from and to ECU. So supposedly yes we can use it to change anything we want in ECU, including those you mentioned
jet_fl likes this.
yiuwa is offline
#11 Old 04-13-2019
Quoted: 6433 Post(s)
i860 is on holiday until the 18th
#12 Old 04-15-2019
Quoted: 90 Post(s)
Is that how much they 'weigh' when backed up or did you find a global pile of them that a person can pick/choose and install at will ?
marvin-miller is offline
#13 Old 04-15-2019
I860 is on holiday until the 18th
#14 Old 04-15-2019
Quoted: 90 Post(s)
I saw that
#15 Old 04-15-2019
I saw that
Sorry, been updating his holiday in other threads n didn't realize it was also posted here 2 posts up
#16 Old 04-15-2019
Quoted: 90 Post(s)
That's OK - as I get older I find I'm asking the same questions twice!
#17 Old 04-18-2019
i860's Avatar
Quoted: 893 Post(s)
Hi
You can find the cbf in xentry.
i860 is online now
#18 Old 04-19-2019
Quoted: 90 Post(s)
Hi
I'm assuming cbf's are firmware files for the modules on the car? If so then it sounds like there is a full database of them for off-line updating? (ie, no need to have MB account). If so, does that mean I can update all the modules?
#19 Old 04-19-2019
i860's Avatar
Quoted: 893 Post(s)
Most likely you need scn after updating.
Did my w204 comand update with Vediamo but the update changed the coding. So i had to do online scn in the end.
i860 is online now
#20 Old 04-19-2019
Quoted: 90 Post(s)
SO it sounds like the Xentry software contains all the firmwares for all the cars?
Can't wait for that pass-through interface to arrive (slow boat from China) so that I can see it all first-hand.
Help needed - how to begin with Vediamo? os62 SLK R172 General Discussion 8 11-20-2017 10:08 AM
Offline Xentry pretty useless for R172? JudgeMing SLK R172 General Discussion 5 12-06-2014 04:08 AM
