Can I use DAS to check proper function of ignition coils? - Mercedes Benz SLK Forum
#1 Old 11-09-2017
Vehicle: 2005 SLK 350
Other Toys: H20 V-Dubs, MK1s
Quoted: 410 Post(s)
I?m getting what feels like an old fashioned misfire. OK I admit it?s on the the e320 but still MB and basic principles are the same. The car idles smoothly but while driving I?m convinced it?s misfiring slightly. The beast has 12 plugs so I think it?s at least possible that one is not getting fire or not at the right time. I?m hoping that it?s just a faulty coil (2005 145k bone stock). I?m thinking I can use DAS to get live data while driving but honestly don?t know where to start.
Help? Advice? General hazing? Thank you in advance.
Roxanne7169 is offline
#2 Old 11-10-2017
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 897 Post(s)
If I remember correctly there is an option where the machine will run lean on each cylinder to make it easy to detect a misfire.
i860 is online now
#3 Old 11-10-2017
Quoted: 2213 Post(s)
Just had this on the 350.
Eventually started missing at tickover too.
Started with O2 sensor, slight improvement.
New plugs cured the issue.
The plugs that were in were relatively new and have been returned under warranty.
Swapping plugs, coils and seeing if the fault changes cylinder is the way to go if you have a reader.
(Don't tell Sarge that I have not yet got one)
#4 Old 11-10-2017
Quoted: 410 Post(s)
Thanks for this input. The plugs and wires are new Bosch. That didn?t show much improvement. I replaced the camshaft sensor and it straightened up quite a bit, coupled with a new MAF (probably was not necessary). However I?m still not satisfied and wish to diagnose the coils. At $50/each fir Bosch I?m not too inclined to replace them all just yet.
Again, THANKS. And I won?t say a word to Sarge I promise.
#5 Old 11-10-2017
Quoted: 410 Post(s)
I will poke around in STAR and see what I can find. MChild has advised me to look in the engine ECU area. Any and all information, advice, or guidance will be most welcomed as I?ve not yet done anything like this. I am a ?babe in the woods?, as the expression goes.
Just popped a SmartTOP v2 into my '07 SLK280 MojitoLoco General Modifications R171 346 05-21-2019 11:18 AM
SLK pick up list ierax SLK R171 General Discussion 13 02-05-2018 10:15 AM
A and B Service Questions HBK SLK R170 General Discussion 7 06-25-2011 10:15 PM
Check Engine Light AaronHartwell General Discussion 2 05-23-2010 10:38 AM
Check Engine AaronHartwell SLK R170 General Discussion 2 05-23-2010 12:58 AM
