Help needed- DAS/STAR menu setting for disabling Canada DRL? - Mercedes Benz SLK Forum
  • 2 Post By Seanhump
#1 Old 10-03-2017
Vehicle: 2005 SLK 350
Quoted: 17 Post(s)
Exclamation Help needed- DAS/STAR menu setting for disabling Canada DRL?
I have my 2005 SLK 350 at the dealer here in LA- I asked them to shut off the Canada spec DRL which forces the headlight low beam to be on all the time regardless of headlight switch position. They were not sure what I was talking about as far as "DRL settings" in the system. Do any of you know the menu setting path so I can tell the MB tech where to look and what to set it to?
LA_BENZ is offline
#2 Old 10-03-2017
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 423 Post(s)
Morning
I think changing the country is one way of doing this .. I changed mine to USA a while back when trying to get to the bottom of the TPMS saga and that enabled the side markers (and I couldn’t find an easy way to disable only those, but I didn’t spend that much time looking)
Changing away from USA removed the errors
I’m guessing that a change to a different location will change the functionality to suit ...
Avel Du and LA_BENZ like this.
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#3 Old 10-04-2017
Quoted: 17 Post(s)
Originally Posted by Seanhump View Post
Morning
Thank you - I was not aware you could do that in the system. I'll ask the tech to see what it is presently set to.
LA_BENZ is offline
Question- Headlight DRL setting options for canada spec 2005 SLK350 R171 LA_BENZ DAS/STAR Coding 23 10-13-2017 09:31 AM
