Star Diagnostic(error: B254C24), need help with vario-roof error fault. - Mercedes Benz SLK Forum
#1 Old 05-25-2017
Vehicle: 2013 SLK350 Diamond White
Quoted: 13 Post(s)
Send a message via AIM to BrownMagician
Sometimes I was having issues closing the convertible roof. I suspected it had everything to do with the parcel shelf blocking the roof from going and closing the car .
I brought the car to the dealer, and I just wanted your guys information on this.
The dealer told me they connected Star diagnostic, and found a fault code stored in the vario-roof control unit (error: B254C24 ). They said it was a software malfunction, and it needed an update?
Anyone have any idea what that error code actually means?
Thanks for your help everyone!
Last edited by Avel Du; 05-27-2017 at 10:15 AM. Reason: Adding error code to title.
BrownMagician is offline
#2 Old 05-27-2017
Quoted: 2213 Post(s)
A weekend bump.
I'll add the error code to your title as that may help elicit a response.
Avel Du is online now
#3 Old 05-27-2017
Quoted: 13 Post(s)
hopefully someone can tell me what the means here
Thanks for updating the thread to gain users attention for a reply
#4 Old 05-28-2017
Star/DAS Registered Owner
Quoted: 500 Post(s)
In Star the description is in German but as Google translates it: Showing translation for der endschalter 'hutablage oben' hat funktionsstörung.keine: spannung pegel niedrig Translate instead der endschalter 'hutablage oben' hat funktionsstorrung.krinr: spannunspegel niedrig The limit switch 'hat shelf above' has function failure.not: voltage level low If a software update resolves it I would not worry about it.
mchild is offline
r170 vario roof odd issue ii3 SLK R170 General Discussion 23 08-20-2016 02:00 PM
R171 vario roof problem nebuddlho SLK R171 General Discussion 3 07-03-2015 06:21 PM
vario roof failure mailbill60 SLK R171 General Discussion 2 04-14-2014 05:10 AM
Vario roof not working. solution is found nobody99 SLK R171 General Discussion 1 03-06-2014 03:20 PM
Vario roof opened halfway, sank and can't get back up! dauntless3 SLK R171 General Discussion 40 03-13-2013 12:41 AM
